Question about Dell 948 All-In-One InkJet Printer
Cannot attach printer unit into base
Printer unit has been removed and now cannot get it back on
    Problem Solver:
  • 13 Answers
Printer information is stored in the reistry in windows, Go to regeit in the windows directory and look for you printer software, DO NOT CHANGE ANYTHING HERE AS YOUR COMPUTER MAY STOP WORKING. If the printer is not there it will have to be reinstalled unless you have a backup or restore point. To create a restore point go to my computer from the stat menu and right click, now properties and system protection. If you loose somthing you can go back to this point or date.
Phill
Posted on Jan 15, 2013
Can not remove back on vizio 42
If it has a pedestal base attached it has to come off first--set face down and on padded surface---support the frame of the screen carefully---in that position exert NO downward force as the screen unit (Display panel) is very fragile and can be destroyed.
Most of these sets the base obscures or hides screws that need to be removed to get the back off.
May 25, 2012 | Vizio VW42LF 42 in. LCD HDTV
The bottom plastic panel of my EdgeStar AP 14000 HS is cracked and leaks water. It is still under parts warranty so I expect a free replacement panel to be provided by EdgeStar. Question: how do I install...
I just replaced this pan on my unit. I have to admit it was more of an issue than I predicted. You need to remove the screws from the back cover of the unit. Then you can swing the back cover up like a hinge until it is sitting upside down on top of the front cover. Be careful not to damage the wires connecting to the circuit board. You can then remove the circuit board. After the circuit board is removed, you can remove the screws and the front cover. (note, you will have to spread the front cover to get the tabs on the center mounting locations to pop over the frame. After the front cover is removed you will see several things mounted to the base. I removed all of the fastners including the large nuts holding the compressor down. Then with some help,from a second person I lifted the unit and pulled the base away. I had to remove the yellow ground wires from the compressor in order to remove main unit. you will notice now that there are a few pieces attached to the base. I removed each piece and reinstalled it on the new base. then I assembled the entire unit in reverse.
Jul 10, 2010 | EdgeStar AP14000HS Portable Air...
Just a question as to how the base attaches to the tv?Don't have the unit, at a friends house and wants to know how to remove, looks like it attaches at the bottom, is this correct?
Most tvs have four to six screws that go in the back just above were the mount goes in at the bottom of the unit. look for a 8 to 10 inch raised area or 3 screws in a row, 2 rows. Face the tv face down on the bed with the base hanging over the edge. Some tv's like L.G.base just push into the bottom with 2 or 4 screws holding it in place. The screws will look much heavyer then the ones going around the set. maybe round top not flat topped
Nov 26, 2009 | Sansui HDLCDVD260 26 in. LCD Television
Nec 860 laser printer fuser unit
remove cartridge and leave top door open, then remove two screws in back ; open front sheet panel to find two screws to remove then remove outer case carefully AND PLACE ON LEFT SIDE BECAUSE THERE'S A RIBBON WIRE ATTACHED.
there are 4 screws holding the fuser unit in place, remove AND LIFT OUT BY ROLLING TOWARD YOU to reveal 2 screws to access the red roller assembly!
In my case there was a very tightly wound piece of paper stuck in there not visable without removing the screws on the fuser unit!
Dec 18, 2008 | NEC SuperScript 860 Laser Printer
Removal of flat screen pedestal so I can wall mount tv
Had the same issue. I turn the unit upside down and while holding panel down just pulled staight up on the base. The circular base popped off without any damage. I just needed to remove for shipping.so I didn't have to remove the cylindrical post. Once the base is removed you can see a screw that probably attaches that cylinder to the unit. Carefully removing it should work. Good Luck....j
Nov 23, 2008 | Televison & Video
Connecting hoses on Kirby G4
The hose attaches in place of the beater-bar head unit. To remove the head unit, lift the headlight assembly, then turn the square gray Kirby emblem counter-clockwise 3/4 of the way around until the red triangle on the square portion aligns with the red triangle on the base unit (this disengages the belt). Then flip the silver metal fastener that was underneath the headlight to release the head unit and remove the head unit. To attach the hose, simply line it up so that the safety button is engaged by the hose assembly and then use the metal fastener under the headlight to secure the hose to the base unit.
Nov 17, 2008 | Kirby Generation 3 Bagged Upright Vacuum
I need to remove the base from my 42 inch plasma TV to mount it onto a TV stand. How do you remove the base?
Good Day;
The base is attached by four, inset, allen screws on the back of the unit, bottom. The 'key' word is INSET (recessed).
Good Luck, Day, Big Irish.
Jun 18, 2008 | Akai Televison & Video
Battery problem MFC 7420
Tis a long way down my friend, I've never had to change one, on any brother printer, but I've never encondered them knowing not the time either. I suggest you take it to the repair agent, or get a manual but for what its worth this is what I know
I've seen the battery when I've had the scanner unit off the base printer, comes off after all covers are removed and all the cables that attach them are disconnected, then theres clips on the sides and two(four?) locking screws on back(front?) from memory. and thats all a task in itself.
Heres the best pic i can find of the left base of your printer engine displaying battery position, hope this helps.
Cheers
Soulvisitor
Jan 11, 2008 | Brother MFC 7420 All-In-One Laser Printer
How to change lamp in AGFA Arcus 2 flatbed scanner?
http://www.uktsupport.co.uk/scanner/agfa/arcus.htm#a2lamp
  • Turn off the scanner power switch and disconnect the power plug. Wait at least 15 minutes to allow the unit to cool down.
  • Unscrew the two screws at the back of the base.
  • Pull the SCSI board out enough to disconnect the ribbon cable that threads through the opening in the base (on the right).
  • Remove the two screws from the upper portion of the back of the base.
  • Remove the Transparency Option (TPO) from the base.
  • Remove the two screws from the top back of the base. These screws will be visible when the Transparency option is removed.
  • Remove the two screws from the top front of the base and lift the plastic housing off the scanner.
  • Move the carriage optical assembly backward until you can reach the lamp.
  • Remove the two screws from the top of the optical assembly that covers the bulb and remove the black cover.
  • Lift the lamp from the socket, working one end, then the other.
  • Replace the lamp with a replacement lamp. One replacement lamp is provided with the scanner and others are available through Agfa Parts Order.
  • Return the lamp cover the original position and replace the two screws.
  • Replace the plastic housing and replace the four screws holding the housing.
  • Thread the ribbon cable of the Transparency Option through the base and plug back into the SCSI board.
  • Return the board to the base and tighten the two screws. This insures a slack cable that won't be punctured when screws are put in to attach the transparency module to the base unit.
  • Replace the two screws in the back of the base to secure the Transparency Option to the base.
  • Nov 16, 2007 | Agfa Arcus II Flatbed Scanner
    Dell 948 All-In-One InkJet Printer Logo
    13 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
