Question about Sierra Online, Inc. Counterstrike: Condition Zero for Windows
Game closes (condition zero)
I installed CS condition zero then i opened it.As i was picking my helper the game closes down.every time i open it it closes after one minute or someting.
thanks
  • 1 more comment
  • metalic_iron Jan 24, 2009
    No it doesn't have any error and it meets the requirements.it has the same problem on my other computer
  • theopai Feb 10, 2009
    I hava the same fu#$@g problem man! It was running well one day and in the other it was gone.
    I've tried to reinstall it but the problem remain the same.
    I send an msg to STEM Tech. Support but ain't got any answer.
    One thing is that my HD is almost full, as well as before the problem and I didn't installed any software on the way...
    Good luck 4 us all!
  • Amir Shukor Jun 03, 2013
    im different..on my laptop..it said low memory...but i just buy my laptop
    Problem Solver:
  • 18 Answers
Could be a corrupt file on the disk but as your aware this game is available to download from steam so as long as you have the cd key that came with your origanal purchase then i would suggest uninstalling the game and if you havnt got one yet get a free steam account and download the game from them. Once downloaded enter your cd key and give that ago. Let me know what happens then as it sounds more like a gfx card issue bu tyou seemed pretty certain your hardware is ok :)
Posted on Jul 27, 2009
  • 107 Answers
Do see a error report after it close? try reinstalling the game , check system requirements of the game if it meets your pcs
Posted on Jan 24, 2009
Bleed clutch hydraulic system John Deer 4300 Tractor - year 1998
two of you needed here ,put a big screwdriver into the operating arm and pull it back so the piston goes in ,slacken bleed nipple then helper pushes clutch down -hold it down then tighten nipple .repeat a few times and you will feel pressure on the clutch arm ,now get helper to push pedal down and hold it down ,pull bar to push piston in as it moves you open nipple then close it after a squirt of air comes out and repeat this a few times and it should have a hard pedal
Dec 06, 2014 | Cars & Trucks
How to bleed brakes on 94 firebird after putting brake fluid in
3 ways to bleed.
1) Gravity bleed. Start at the rear wheel brake farthest from the master cylinder. Open the bleeder screw about two full turns, and after a while, the brake fluid which is on top of the air will push the air out. When the brake fluid runs out, close the bleed screw. This can take 1/2 hour sometimes. You must keep checking that wheel so you can close the screw BEFORE you drain your master cylinder!
Continue this with all four wheels. P.S. Sometimes it will not work.Then you have to go to -
2) Bleed with a helper.
Helper gets in the car, and you ask them to push the brake pedal. You open the bleeder screw slowly and carefully, knowing the brake fluid may shoot out violently. Gently open it until bubbles come out. Close the screw, and ask the helper inside to pump up the pedal (about 5 times), and then hold it down medium hard. Continue to open the screw gently until only brake fluid comes out. Close that screw, and move to the next wheel. Repeat on each wheel. Check master cylinder ever few bleeds to keep it full.
or
3) take it somewhere and have it professionally bled with a machine.
Jan 06, 2013 | 1994 Pontiac Firebird
I dont know how too bleed my brakes on my 89 omni any tips
You'll need a helper to help push the brake pedal. Start at the right rear, open the bleeder, have your helper push slowly and steadily down on the brake pedal. Close the bleeder. Have your helper take foot off the brake pedal. Repeat this process until either the fluid is clean/clear or there is no more air coming out of the lines. Continue this process at the left rear, then the right front, and finish at the left front. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Nov 07, 2011 | 1989 Dodge Omni
FSX installed and activated easily (3 times) but no icon on desktop nor entry in "all programs" or MS Games. FSX plays after activation until I close program. Then cant be found.Can you help?
try to search it at program files. maybe at installation start menu folder or desktop icon didn't created but the program already installed.
open 'add or remove programs' window. if your game are listed in there, then your game is already installed at the computer. open C drive (where is windows installed) go to program files folder and search your game folder. if you find it then search the game application (.exe) right click and 'send to desktop'.
if your game is not listed in 'add or remove programs', then u need to reinstall the game. maybe there is problem with your VGA or RAM that makes the game erased after you playing the game. or maybe u have your computer 'deep freeze' program and you installed the game at frozen condition.
hope this useful.
Feb 18, 2011 | Microsoft Flight Simulator X
How do I replace the toner of my Copystar CS-1820?
Open the top door
While sliding the blue lever, pick the used cart out.'Shake the new cart well, snap down both sides.
Close door
Jun 16, 2010 | Copystar CS-1820 Copier
Copystar CS-C2525E. Paper Jam error 91. No paper
Under included device open and close the lid. Unless throw, see the condition a sensor entry and leaving the paper - can be the sensors conk. Good luck
Oct 06, 2009 | Copystar CS-4035 Copier
Requires cd key
Thanks for choosing fixya.
pick one:
5Z522-HK3KP-RPR6K-YCXP3-C6DMT
5z62e-mtxqz-z32iy-nw22l-a3c4q
5Z82E-RPGMA-YH2P2-NRZOM-3TM6Z
5Z82E-IQSAY-PTDGB-XWAJ-4LPI6
5Z62E-MTXQZ-Z321Y-NW2ZL-A3C4Q
5Z62E-79JDV-79NAM-ZGVE6-ARBWY
5RP2E-EPH3K-BR3LG-KMGTE-FN8PY
Apr 01, 2009 | Sierra Online, Inc. Counterstrike:...
Lost planet wont open
their is a file on your ps3 that installs new games where the ''save data '' is find the lost planet file and delete it. you will have to start all over but its a fun game and its worth it.
Mar 16, 2009 | Capcom Lost Planet: Extreme Conditions for...
Hi i wanna play counter strike online but i don't now how! can you help me please?
if you have counter-strike 1.6 Just download this PATCH from this web kujtesa.com/cs and install it and find a server It Work's for Me
Jan 08, 2009 | Computers & Internet
Open RAW files
1- Be sure your files from the Olympus are downloaded and stored on your hard drive. 2- Be sure you've updated Photoshop CS' Camera RAW to the latest version: go to http:// www.adobe.com/support/downloads/main.html and click on the OS platform of your choice for Creative Suite, pick the latest Camera Raw plugin to download. Install and you're ready to go. 3- Start up Photoshop CS. You can either use the File Browser to look at the directory where you have put the files from your camera, open them from there, or you can use the File->Open... menu commands to pilot your way there and just open the file you choose explicitly. Camera Raw will start automatically when you pick a .ORF file with either method.
Sep 13, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Sierra Online, Inc. Counterstrike: Condition Zero for Windows Logo
578 people viewed this question
Top Sierra Online, Inc. Video Game Consoles & Games Experts
James Wishart
Edward Talavera
Edward Talavera
Are you a Sierra Online, Inc. Video Game Console and Game Expert? Answer questions, earn points and help others
