Question about Radio Communications
How to program realistic pro 2027 scanner - Radio Communications
SOURCE: I have an old realistic pro 34 scanner that I need
http://support.radioshack.com/support_electronics/26441.htm
try this site
Posted on Sep 11, 2009
BillB-SA
  • 2761 Answers
SOURCE: how do i program my realistic pro-2025 scanner
PROGRAMMING CHANNELS
1. Turn on your scanner by turning the volume clockwise.
2. The scanner might start scanning. If so, press MANUAL to stop the
scanning.
3. Enter the channel number that you want to program and press MANUAL.
4. Enter a frequency including the decimal point. The decimal point shows
up on the display as a -- (dash).
5. Press Enter to store the frequency.
6. To confirm the proper entry, press REVIEW. The programmed frequency
appears on the display one digit at a time.
7. To program more channels repeat steps 3-4.
Posted on Dec 01, 2009
BillB-SA
  • 2761 Answers
SOURCE: who to use a realistic pro 2020 20 channel scanner
Wow -- that's an oldie! You can download/print operating instructions for the PRO-2020 here:
http://support.radioshack.com/support_electronics/doc45/45530.htm
If you need more info, I have a PRO-2020 in my collection, and I have the full manual for reference.
For a comprehensive database of active frequencies in your area, and a lot pf other useful scanning info, visit:
www.RadioReference.com
Bill B
Posted on May 16, 2010
BillB-SA
  • 2761 Answers
SOURCE: I need a manual for
Your manual is no longer available as a single document, but you can download and print individual sections of it, at no cost, here:
http://support.radioshack.com/support_electronics/28537.htm
Bill B
Listening in since the 60's
Posted on Oct 13, 2010
BillB-SA
  • 2761 Answers
SOURCE: Is the Realistic Pro 20-20 Scanner obsolete? I
Your PRO-2020, circa 1982, is old and tired, but not quite obsolete. The receiving bandwidth of this oldie is wide enough that you can just ignore the fourth digit. In some cases this may result in interference from an adjacent frequency, but it will usually work just fine. The 2020 is further limited in that it will not receive 800MHz frequencies, and it is not capable of tracking trunking systems or receiving digital transmissions, but what it does, it still does well. The PRO-2020, by the way, was one of the first keyboard-programmable scanners, and the first used in military intelligence surveillance operations.
Bill B.
Posted on Nov 17, 2010
Testimonial: "Thank you, Bill B. That was great information, and I appreciate the timely response. Again, Thank You."
How do i program realistic pro-59 scanner
http://support.radioshack.com/support_electronics/8567.htm
don't know what you will pickup. Nearly all law enforcement, ems, fire have gone to digital trunked systems that are encoded. The above link has a link to the operating manual. You will need to know the frequency of whatever you are wanting to listen to.
Aug 28, 2016 | Radio Communications
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
Can a realistic pro 55 model 20 124 be programmed to different frequencies?
Hello, your scanner appears to be a 10 channel crystal controlled scanner. I'm estimating it to be around 30-40 years old. I think there is a couple companies still making custom crystals but you have to find the freq's #'s to give them. Here is the freq. range it will pick up. Frequency range RX 30-50 / 144-174 / 450-512 MHz I personally would take the money spent for crystals and apply it towards a newer scanner that is programmable so no crystals needed. Here's a link to some more info;
RadioShack Realistic Pro 55
Sep 07, 2015 | Radio Communications
Looking for a manual for a Realistic Patrolman Pro 40 UHF/VHF Scanner. I don't even know what kind of power supply it needs.. LOL
Hi, that unit looks to be a mobile scanner and if I'm seeing right then you would need a Base power supply that could supply 12volt to it. Course you could also use a computer power supply and find the 12 volt line out on it. Here is the link to some spec's for it. Looks also to be crystal controlled so it cannot be reprogrammed. Good luck.
RadioPics Database RadioShack Realistic PRO 40
RadioShack Realistic Pro 40
Sep 06, 2015 | Radio Communications
Realistic patrolman pro16A radio scanner, do not know how to program freq, this scanner does not have crystals, does anyone know how or have a manual??
I have checked several sources, and they all show that the PRO-16A is a 16-channel VHF/UHF CRYSTAL scanner. Remove the bottom cover and you should see the crystal sockets.
http://radiopics.com/RS-Realistic/PRO-16A.htm
Bill B.
Oct 14, 2010 | Radio Shack Radio Communications
How to program scanner
http://www.repeater-builder.com/radio-shack/pro-2004-5-6/pro-2006-om.pdf
Hope this helps.Good Luck!
Dec 14, 2008 | Uniden BC60XLT Handheld Scanner
Realistic pro 2010 scanner
to program
turn on unit, press program button, key in frequency ###.### press enter. keep advancing thru the channels with the program button until finished
Jun 24, 2008 | Audio Players & Recorders
Radio scanner not receiving
i ha ve realistic 2032 which is doing the same thing and was wondering because everything else including all the functions work fine including hearing white noise and being able to control it with the squelch could this be the end for it or is there stuff yet to do
Feb 28, 2008 | Uniden BC248CLT Base Scanner
Realistic pro-54 scanning reciver
this unit requires crystals for each freq.
Oct 21, 2007 | Radio Communications
Radio Communications Logo
166 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
