Question about Miele S758 Bagged Canister Vacuum
Hose control fault on a miele s758 cleaner
The electronic control on the hose keeps turning the cleaner off or dropping it to min power, can I replace the electrics or replace them. or will I have to buy a replacement hose. The turbo brush only works sometimes and on full power does it need a new drive belt
  • ezappy Mar 26, 2009
    yes that's right, an intermittent fault whereby the vac cuts out from the powerbrush head controler. Apparently the hose swivel connector at the vac body contains rings and contacts like in a car steering wheel which need to be fiddled about with, cleaned and tweaked.
SOURCE: Miele S758 stops working for no reason
I have the same model and possibly a similar problem. You don't say whether the control lights for the turbo head (on the top of the suction pipe) are still illuminated when it stops. I have found that the machine will sometimes shut down with the turbo head stopping and the suction level dropping automatically to zero, and, as you say no red overheat light.
Posted on Sep 03, 2007
  • 1673 Answers
SOURCE: New Miele Red Star - Powerbrush not working
Wish you had listed the model number of the vac and of the powerhead. The plug going into the cannister, is it pushed all of the way in, also same for the plug going into the hose end? You can hook up the powerhead plug to a/c and see if it runs, if it does, then it is ok. Unhook the hose and plug and hook up a/c to that plug end and see if the powerhead will run, if not maybe the switch on the hose handle has a problem. Otherwise you have a problem in the cannister. If this is brand new, then it has a warranty, take in for repair.
Posted on Feb 22, 2008
SOURCE: Miele S326i Vaccuum cleaner hose broke
any miele warranty center can help you with ordering a new part, look on line for close center. Or try main office.
Posted on Mar 13, 2008
  • 1673 Answers
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Posted on Mar 22, 2008
SOURCE: Miele S514 Solaris Electro - won't turn on
I don't have the exact same model as you guys, but maybe my situation is similar to yours. My Miele Silver moon model won't turn on one day. I took it to a Miele authorized repair shop ( they all offer free estimate on finding the problem first, then they will tell you what the repair cost will be). They said my vacuum cord reel shim was damaged. The damage was caused by over stretching the cord while I vacuumed. According to them the shim is kind of like a clip that holds the cord inside the vacuum. When the shim is damaged, the cords are pulled apart and electricity can no longer pass through. That would expalin why it won't turn on. The repair cost was not too bad, it costed forty-six dollars. I hope this helps.
Posted on Jul 06, 2008
My Miele S 558 hose keeps powering down while vacuuming. I understand that the newer SES 125-3 hoses are supposed to correct the problem. Before I buy, I'm wondering if this has proven to be true.
Debra, Searched the net. and the problem does seam to be poor/faulty circuit board in the hose and the SES 125-3 replacement hose is to be the fix. You could dissassemble first and clean the contacts first, to see if you can correct and extend the life of old hose. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
just bought Miele s558 Silver Moon seems like it from 2000 or so If it in...
My Miele S5980 is cutting out How do repair the hose to fix it
Amazon com Miele SES125 Vacuum Cleaner Deluxe Electric Hose Miele Vaccum...
Jul 08, 2016 | Miele Vacuums
My cleaner keeps cutting out and now won't start
You can get a replacement hose from a vacuum store
Jan 04, 2014 | Miele Revolution 600 Bagged Canister...
Miele 5281 vacuum cleaner permanently on high speed
Most likely the speed control board has failed. The solution for this is to replace the electronic unit unless you know of someone who can diagnose and repair circuit boards. The part is common and easily replaced for around $60. Miele's website can point you in the right direction for a service center, or tell me your zip code and I'll look it up for you.
Nov 09, 2013 | Miele Vacuums
Manual for s758
if you mean the simple owner manual it is here
Jan 27, 2013 | Miele S758 Bagged Canister Vacuum
The vaccum keeps turning itself off.
Look for plugged hose or restriction to air flow. You may be overheating and the thermal limiter is kicking in....
Apr 16, 2011 | Miele S758 Bagged Canister Vacuum
How do I find an English manual for my Meile Vacuum Cleaner S748? Specifically looking for drawings that show the filtration system.
The problem with that vacuum is that it's never been released in the American market. Finding a manual for that specific model is going to difficult. If what you're looking for is the S758 and that 4 was a typo then you can find that on Miele's website
Aug 15, 2009 | Miele Vacuums
Hi The catch on my miele revolution has come off
Hi Sally If you download the manual this will be easier to explain:
If you look at page 22 you'll see the optional blower attachment and how to install it - ignore this - however it gives you the view of the two hinges on the actual accessory door. These clip on at either side of the front but there should also be a square partition on the back of the accessory door. Here is where the clip sits into the door and the parts hook onto two spring holders at the bottom. Once that is fitted the door should then go onto the front.
Jul 17, 2009 | Vacuums
Electrical power down while vacuuming (not a reset)
Thank you JonahBegone!
My 4 years old Silver Moon has been power down off and on for a couple of months, but all of sudden it kept doing it. Then the power won't turn on when I plugged it in ( this turns out to be another problem, see my other posting). I took your advice on taking the hose and handle apart. I unscrewed the 5 screws, but can't pull the handle apart to look inside. I was able to see the 3 metal contact on the hose that you mentioned through a 1/4 inch gap when I forced the handle apart. I cleaned the black stuff off through the little gap by rotating the hose a few times. Then magically, my power down problem also went away. Thank you once again.
Mar 25, 2008 | Miele s558 Silver Moon Vacuum
My Miele cat & dog
Mar 22, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
The problem on mine was as described by others. Miele s758 stops for no apparent reason. The first time it happened I had the hose assembly replaced under warranty. Two years later, same problem. I have found that contacts at BOTH ends of the hose were intermittent. I dismantled both ends, extracted both sets of contacts, immersed both sets of slip-rings in methylated spirits and cleaned all the black gunk away. The three PCB mounted contacts were similarly cleaned, retensioned and lubricated with Electrolube. After re-assembly the problem has disappeared. I imagine a repeat procedure will be required in a couple of years.
CAUTION: The procedure is a bit tricky, so unless you know what you are doing, it would be preferable to have it done by someone who does. It is worth fixing as the replacement assembly is $AUD400.
Sep 02, 2007 | Miele S758 Bagged Canister Vacuum
Miele S758 Bagged Canister Vacuum Logo
140 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
