Question about Candy Ovens
Element needs replacing
How do I get the back panel off my F254/3X candy oven, there appear to be no screws inside holding it on? I need to remove it to replace the element.
  • sammypookins Jan 25, 2009
    Thanks alot! I tried to explain this to the engineer over the phone as he was telling me I could take out the element myself from the inside. I think he thought I was a silly woman who wouldn't know what a screw looked like. Once again many thanks Sam
  • Candy Master
  • 3,463 Answers
You need to remove the outer rear panel of oven to gain access to heater on this model.
The element is attached to a panel at the rear of oven , which when removed gives you access to the element..
It cann ot be done from inside the oven.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
  • rge33 Jan 18, 2012
    Very helpful thankyou very much
My ovena akl887/701 element has gone how do i change it
you should get 18 ohms across an element if its ok swich off cooker remove shelf's normally 4 screws holding on back panel inside oven you can now see element 2 screws hold element in position you may see them inside oven or failing that remove rear panel of oven and undo screws pull off spade connectors refit new element it dose not mater witch way arond the cables go as long as the earth is in the right place if fitted
Dec 09, 2016 | Ovens
My neff b1421 does not heat up and has left a "chalky dust" substance in the oven?
The dust is from where the ring element has blown. remove the back panel 4-6 torx 20 screws and the blow on the element should be pretty obvious, part no is 499003. can be replace from inside the unit, one screw on the right of the ring and two on the holding bracket. Obviously, isolate from mains, be careful when you remove the element at the bracket side, so as not to let the connection wires drop into the back cavity or you will have to remove the whole oven and back of the oven to retrieve them. One tag on each prong of the element (doesn't matter which way round they go)
Best of luck
Mar 18, 2013 | Neff B1421 Electric Single Oven
Flavel milano e60 how to fit new fan oven element that is riveted
That is complete RUBBISH the screws are accessible from the rear of the oven. At the back remove the screws holding the plate and you will see the element housing. Remove the two screws and the spade connections. Get someone to hold the new element in place for you and attached the screws. Fiddly job so be patient. Connect the spade connections and replace all plates front and rear. Should be the job!!! Someone hold the element in the cooker whilst someone connects at the back. Whatever you do, DON'T TAKE A DRILL TO YOUR COOKER!!
Dec 13, 2012 | Ovens
Can you replace oven element, cannot see any screws in oven to remove plate to gain access
You will have to remove the oven from the housing, and then remove the rear cover of oven, and gain access to the securing screws for the element from the rear of the oven, you will see how it is fixed once you remove the outer panel of oven
Feb 23, 2011 | Candy FP855 Electric Single Oven
I have a zanussi built in oven model no zbf 860b which the fan is still working but the oven is no longer heating up?? Thanks
If the red light is coming on when you turn on the oven control then the thermostat is ok.You will need to remove the grids from inside the oven then remove the inside rear panel 4 screws, be carreful not to damage the thermostat as you remove the panel.When you have removed panel you will see the ring element,now remove the 3 screws holding in the element and gently pull it towards you,remove the 2 cables off element but do not let them fall into the back of cooker or you will have to remove the cooker and gain access to the rear of the cooker.Once you have element check with a multi-meter for continuity and replace if blown. Relacement is a reverse of removal.
Hope this helps.
Aug 04, 2010 | Zanussi Ovens
Oven is not heating. Fan is working and grill wor...
This would appear to be the ring element around the fan that has failed and will need to be replaced.You will need to power off unit,then remove the back panel inside oven 4 screws in corners,Be careful with Thermostat held in place by clips above or on back panel.You may find 3 or 4 screws holding ring element.Gently pull towards you,being careful that the cables come with it.Check element with multimeter to see if open circuit if its ok then it may be a thermostat fault.If it is a faulty element,
get your replacement element,remove the cables off old one and put onto new one.Then push back into place and refix all.
Hope this helps.
May 21, 2010 | Electrolux EOB6630 Ultrafan Electric...
My omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Mar 18, 2010 | Ovens
How do a change the element on a candy oven , can't get to the old element
You have to gain access to the element by removing the outer rear panel of oven, if it is built in, then this means removing it from the housing.
Once you have removed the cover, and possibly the top panel, you will see how the element is fitted.
It is a fairly straight forward repair to do.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Candy F248P Electric Single Oven
Replace element in top of oven of an f241 candy cooker.
There should be two screws at the inside back of oven. However, once you have the new element look for the holes in the new one
Mar 20, 2009 | Ovens
Oven element replacement- Simpson eziset electric
hiya
firstly make sure the power is isolated before removing any panels.
sometimes the element will just screw out from the inside of the oven and should pull through into the oven compartment with the wires attached, simply remove the wires, replace the element and refit any panels.
hope this helps
please dnt forget to rate the helpfulness of this reply thanks kj
Nov 11, 2008 | Ovens
Ovens Logo
579 people viewed this question
Top Candy Ovens Experts
ashburton
ray gallant
Dado
Are you a Candy Oven Expert? Answer questions, earn points and help others
