Question about Lucent PARTNER18 Corded Phone
Can I change the caller ID so it shows on the first ring?
My boss wants to see the caller ID on the first ring. Currently, it does not show up until the 2nd ring. Is there any way that this can be changed, or is this this impossible?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Lucent Master
  • 102,366 Answers
The caller ID information is sent between the first and second rings, so there's no way the receiving phone can display this data on the first ring. You have to wait for the second ring (or just before it).
Posted on Jan 15, 2013
5 Suggested Answers
SOURCE: Phone does not ring or show caller ID
From extension 10 or 11.
Press feature 00
Press left intercom twice
Then right intercom once.
enter your extension number
You will see the lights blinking green on the phone, where your lines are. Touch them until they are solid green. If you want to program another extension, press the right intercom button again and enter the new extension number.
Once done, press feature 00 to exit programming.
As far as the caller ID, there is no way to turn it off on the Partner system. My guess is the provider isn't sending caller ID.
Posted on Jan 05, 2008
  • 518 Answers
SOURCE: caller id won't show up and autodial sound when answering
Could there be a button stuck down?
Hope that helps...
Geno
Posted on Mar 27, 2008
consultel1
  • 860 Answers
SOURCE: how do i get my lucent partner 18d to show caller
2 line caller id is offered on newer versions of software. On earlier versions a call id name button is used to toggle between the clid name and number.
To program a button on your set press feature 00, press a button you wish to program as clid name,
and press feature 16, press feature 00 to exit programming. Press the button to toggle from clid number to clid name
Posted on Nov 03, 2009
  • 68 Answers
SOURCE: How do I reprogram the
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Posted on Jul 05, 2011
My Uniden 8055 is shoingno caller id when I ring my mobile phone, how do I make it show caller id on all outgoing calls?
Try this .go to menu,then settings , then call settings ,then press' Show caller Id.'I hope this works for you .
Feb 09, 2015 | Uniden DECT 6.0 Cordless Phone ID
Is there a way to setup caller id on a Nortel system that show when the phone rings
In system programming, you can select whether the display is the name, number, or line.
F**CONFIG
Terminals&Sets
enter extension #
skip Line Access, Capabilities, Name, User Preferences
Telco Features
skip Feature Assign
at 1StDisplay use CHANGE softkey to toggle to NAME.
Mar 26, 2014 | Nortel Lands Phones
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
Line selection:
3) Press **.
Line Selection
Jan 06, 2011 | Lucent 18D Corded Phone
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
Turn off caller id
Unfortunatly the only way to do it is to take line access off that phone and have a button call pickup to access ringing line. In this scenario extension wont ring Reffer to programming manual on support/avaya.com Cheers
Jun 10, 2009 | Avaya Corded Phone avaparp18d
Caller id not working, called tele ph comp they said to change batt, have base unit with one in other room, base one and two not showing caller id, the batt are showing full.
Caller ID information is passed between the first and second rings.
Try connecting a regular corded telephone or a standalone Caller ID box. Does Caller ID information show up?
If you have multiple telephones (I don't mean a single cordless telephone base with multiple handsets) and none of them are showing Caller ID after 3 rings it would appear that the telephone company does not have Caller ID turned on for your telephone line.
Oct 29, 2008 | Lands Phones
Caller ID
Since it appears by default, I'm guessing that the phone is not ringing. It has to ring to display CID. You need to make sure that it is part of an ICD group with Immediate ring.
Carl
Sep 03, 2008 | Panasonic KX-T7630 Corded Phone
Caller id recall
To redisplay the Caller Id Number, press the Line button again.Caller ID Scrolling is possible if you have a MIF-F(C)-10 card in the system and you have a Scroll key programmed on the phone. If you need further assistance, let me know.
Aug 27, 2008 | NEC Electra Professional ETW-16DC-2
# of rings
Hi Sharon,
The rings you hear when dialing your phone number is a machine in the local telephone office that is in place so you have something to listen to while your call is being processed and not your actual phone ringing, also the caller ID requires one to two ring cycles to gather the information it displays on your screen therefore the amount of rings you hear when calling a number rarely matches the actual number of rings at the phone you are calling. There is no programming in the Samsung 100 to change this as it is controlled by your local phone company. Hope this helps explain the situation, Good Luck
Jul 29, 2008 | Samsung DCS 12 Corded Phone
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
Lucent PARTNER18 Corded Phone Logo
118 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
