Question about GE WBVH6240F Front Load Washer
My ge wcvh6400joww has stopped working. when put into a cycle, it does all of the test stuff locking and unlocking the door etc. then just sits there with the motor runnung..any suggestions?
I have checked the water lines, and cleaned out the filter..a cycle did run, sort of, but left water in the bottom. how do i access the test cycle on this washer? I believe it may just be stuck in a cycle, as it stops and the button blinks. then when pushed it starts again...well, it used to...now, nothing...
I am having the same issue. I have cleaned out the filter and had the pump replaced once already. I have been checking the drain/filter every time I use the washer and quite a bit of water comes out (nothing in the filter), often very soapy and if I let it stand overnight very stinky. I can get my finger into the pump and it does not appear to be frozen.
Posted on Feb 05, 2013
  • 351 Answers
SOURCE: GE Adora Front Load Washing Machine Problem
Dear Trudz,
all you need to do is clean the filter. you can get to it by unscrewing the front screws at the bottom to remove the bottom panel. Unscrew the filter but be ready to have something to catch the water overflow. Coins did it for us. There was not much lint. Hope this helps.
Cheerup and be happy always
Posted on Apr 10, 2008
  • 1294 Answers
SOURCE: Front load Washer
You have to clean-out your inlet hoses; the hose/s external of machine, the screens. You may not be getting sufficient water.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 31, 2008
SOURCE: washer stops and start button blinks
The solution is pretty simple. there is a filter located right before the water pump.
* Remove the lower panel (lower as if you were looking at the front of the machine)
* Remove the 3 screws (it is easy if you have the lower drawer unit .. you will have to 'get low' if you don;t have it)
* You will see a 3" cap right facing you (in the center)
* GET A POT. and place it below the cap (foul water will come out when you remove the cap)
* remove the cap (finger tight)
* I found coins, hair, lint, dollar bills .. etc (about the size of a roll of cookie dough)
* Take CLEAN water and dump it into the washing machine (this will clean out the tube/hose)
* replace cap
* run machine BEFORE you put the cover back on (make sure it doesn;t leak)
* replace cover/screws
Posted on Jul 09, 2008
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
SOURCE: front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Posted on Jun 19, 2009
What does error code F-90 mean on a Kenmore delf cleaning wall oven
The F90 error code indicates that the door unlock time exceeded. This will happen if the lock is in the locked position with the oven door open or if the lock motor fails. Have someone hold in the oven door light switch while you set the control up for the self-cleaning cycle. Let the self-cleaning cycle run for only 4-5 minutes then press stop/cancel. This should allow the lock assembly to reset & retract the door lock back into the unlocked position.
You can also try resetting the appliance by disconnecting it from the outlet or switch off the circuit breaker for 20-30 minutes. Once power is restored run a test cycle. If this does not work I suspect a door lock assembly failure. This type of diagnosing will require accessing the lock assembly & using a volt/ohm meter for testing
Nov 03, 2016 | Kenmore Ovens
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
Started to self-clean, locked the door, etc. Had
Hi.
The appliance door is probably locked in consequence of the self cleaning cycle.
Unplug power cord, and allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged the door latch, or the electronic control.
Parts must be tested to discover the fault.
Call Frigidaire at the number listed on the owners manual.
Regards.
Mar 03, 2010 | GE Ovens
Water in tub and nothing happen when we try to wash cloths
usually this is indicitive of a bad pump or something stuck in it.these machines when first started they try to pump out first
the cycle will continue as long as it senses water
have them inspect the pump
good luck with sear service i hope it goes well
Oct 13, 2009 | GE WBVH6240F Front Load Washer
Un work of the doors auto control lexus
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Long beep to follow if successful.
Jun 16, 2009 | 1996 Lexus LS 400
2000 Toyota Sienna Minivan car alarm goes off.
1. Start with key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into ignition (Do not turn) and pull it out.
3. Perform these steps within 40 seconds.
A. Using the power door lock switch on drivers door perform 5 lock/unlock cycles starting
with lock. Use an even pace and try to go about one cycle per second.
(1 cycle = 1 lock and 1 unlock.)
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Turn the ignition to ON (Do NOT Start) then back to OFF.
E. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful entry
into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds the door locks
should cycle once indicating successful programming. If the door locks don't cycle or
cycle twice, repeat steps A and B, your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new transmitter.
7. Close drivers door.
Apr 25, 2009 | Chevrolet Malibu Cars & Trucks
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
GE Profile XL44 Spectra gas oven
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
GE WBVH6240F Front Load Washer Logo
56 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
