Question about Tamron 28-75 F2.8 XR AF Lens
Green tint using a AF28-75mm F/2.8 XR Di LD Aspherical (IF
Hi, am using a borrowed AF28-75mm F/2.8 XR Di LD Aspherical (IF on my Nikon D70 , shot side by side comparos (outdoors)with my Nikon 70-210. The Tamron needed corrections to get rid of a "green tint" Is this normal in any circumstance known? Outside of that I like the lens. Thanks, Alan
  • alpamgabe Jan 30, 2009
    Randy,
    Thanks for the suggestion. There were no filters on either lens. My original test was done for sharpness and detail. The Nikon 70-210 is a 4D the camera was set to auto WB for both and the Tamron was way off, but not the Nikon.
    I have since re run the test setting the WB individually for each lens using the 70-mm feature against a white paper. Both F-stops were the same as was the focal lengths=70-mm. Now they look almost identical, in color, detail, sharpness, and exposure.
    What thru me was how different the Tamron responded to auto WB. Lesson learned, non Nikon lenses might not function as Nikon lenses do.
    Thanks again for the response.
    Novelist:
  • 121 Answers
Alan, Does one of the lenses have a solar or polarized filter on it?  It sounds basic but it would alter the type of light brought into the camera, that is a nice lens.  Are you shooting the smae F-stop for both side by side photos?  The 70-210 is a 3.5 or 5.6 right? Just a thought. randy320sgi
Posted on Jan 30, 2009
I have dust particles inside my Tamron 17-55 LD XR DiII SP Nikon mount lens. Is there an easy way to remove them?
No. There is no easy way to remove them, to do so requires an expensive strip down and overhaul in a clean dust-free environment.
Unless you have the dust equivalent of boulders in there, then they are highly unlikely to show on your images and you can ignore them. Even if they do show occasionally you can usually easily correct the faults using commonly available processing software.
Jul 12, 2011 | Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP...
On attempting to take shots at a basketball game inside a school "Gym", the result viewed on the camera monitor gave a very grainy yellowish image with some shadowy figures of the players. I'm...
Hello!
From what you described, there are several issues, no problem with the camera itself, but just settings to adjust:
- grain effect - it's because you have high ISO and low light
- yellowish tint - because of the ambient light
- shadowy subjects: again because of low light, the camera cannot properly focus the subjects correctly.
To fix these issues you basically need more light. And the only way you can obtain it, not being in a studio is to fire up the flash.
Please also provide some exif information from a photo if more assistence is needed.
Regards,
katharsys_i
Mar 02, 2011 | Cameras
28-200mm F/3.8-5.6 LD Aspherical autofocus does this lens fit Canon 40 d?
Tamron makes their lenses available with a variety of mounts. A lens with a Canon mount will fit Canon cameras but not Nikon cameras. A lens with a Nikon mount will fit Nikon cameras but not Canon cameras. As long as you buy a lens with a Canon mount, you shouldn't have any problems.
Jul 04, 2010 | Tamron 28-200mm f/3.8-5.6 LD Aspherical IF...
Loose lens
Hi, I have the same problem with the same lens. Did you fix it yet? Mine is the Tamron Aspherical LD XR Di II SP 17-50 f2.8. I'm thinking about getting the screwdrivers to it.
Nov 28, 2009 | Cameras
Tamron 28200mm f/3856 LD Aspherical IF LD 138 58
you may find a good camera shop can help you get some replacments for it from there repair chapy,
Oct 17, 2009 | Tamron AF 28-200mm f/3.8-5.6 Di (IF) for...
D300, SB-800 fires but no exposure.
Thats is odd.
When you hook everything up, do you turn on the flash last?
It sounds like the battery pack is giving the flash a different voltage then it should have causing incorrect readings and exposures.
I would send the pack back to Quantum(located in Ronkonkoma, NY) and have them check it.
Jul 13, 2009 | Nikon Speedlight SB-800 TTL Flash
I need a manual for Tamron Camera Lens 28-200/3.8-5.6
You didn't supply what kind of Tamron lens it is. I'm gonna go ahead and give it my best shot on a guess: Tamron 28-75mm f/2.8 XR Di LD Aspherical (IF).
If I'm correct, you can download the manual here: http://www.tamron.com/assets/pdfs/A09.pdf
Hope this helps!
/Chris
Jan 17, 2009 | Cameras
Nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Sep 21, 2007 | Nikon D70 Digital Camera
Tamron 28-75 F2.8 XR AF Lens Logo
213 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Tamron Camera Expert? Answer questions, earn points and help others
