Question about Dryers
My dryer does not get hot
Dryer works does not get hot
  • bud park Jan 16, 2013
    is it a gas or electric dryer
  • 314 Answers
  1. Considerations
    • A dryer needs the proper voltage to produce the correct amount of heat. If your dryer isn't heating properly, it's possible that the power supply is the problem. Make sure that the dryer is firmly plugged into the outlet, and if you have a circuit breaker or fuse panel, check to make sure that everything is in working order.
    Theories/Speculation
    • Several things affect a dryer's ability to do its job. If an external source isn't causing the problem, then the dryer probably has a faulty part. Possible culprits include a damaged or burned-out heating element, a blown thermal fuse or damaged wiring, all of which will require replacing.
    Warning
    • The San Diego Fire-Rescue Department recommends having your dryer serviced by a professional repair person. If the problem is caused by something within your dryer's mechanism, you could make matters worse by trying to find and fix the problem on your own. With the exception of checking the dryer's external power supply, you should leave troubleshooting to a professional.
RATE THESE AFTER READING
Posted on Jan 15, 2013
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
My Whirlpool duet electric dryer seems to get too hot and stops working
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Oct 12, 2014 | Dryers
MY HOTPOINT AQUARIUS TCM580 CONDENSER DRYER STOPS WORKING AFTER ABOUT FIVE MINUTES USAGE AND IN SO DOING TRIPS OUT THE MAIN HOUSE FUSE, WHAT CAN CAUSE THIS PROBLEM
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Oct 05, 2014 | Hotpoint Dryers
Why does dryer gets super hot
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Aug 02, 2014 | Dryers
Kenmore electric dryer got really hot and stopped working?
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 19, 2011 | GE DVL223EBWW Electric Dryer
SAMSUNG GAS DRYER DV 328 RUNS FOR A WHILE AND THEN STOPS . I GET ERROR CODE EO. THE CLOTHES IN THE DRYER ARE VERY HOT. AFTER A PERIOD OF TIME THE DRYER COOLS DOWN AND STARTS TO WORK AGAIN. THE DRYER...
heatman101
Aug 14, 2011 | Dryers
Dryer gets too hot on regular laundry setting but seems to work ok on delicate laundry setting.All vents and filters are clean.When using regular setting when drying is done the clothes are too hot to...
heatman101
Aug 06, 2011 | Danby DCD5505W Electric Dryer
Whirlpool Estate Eelctric Dryer Serial #MS1013289. Dryer wa working got really really hot, clothes were so hot I could not even touch them...then went to use again and it would not turn on at al. They...
heatman101
Jun 16, 2011 | Estate TEDS740JQ Electric Dryer
The dryer is working but it smells like it is getting hot. any ideas?
heatman101
Mar 22, 2011 | Kenmore Elite HE4 Electric Dryer
Dryer smells hot and back panel near heating
your duct is clogged or the limit snapstat is not working. turn dryer on and go outside to the duct vent , their should be a minimum temp of 10 degrees, and a maximum 15 degrees outside. also sometimes just cleaning the lint from inside the dryer, can cause this smell for no more than 5 minutes. thanks karl
Dec 15, 2009 | GE DBXR453EV Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
