Question about Slendertone Flex Go Abdominal Toning System, 1 ea
Triangle displayed and beeping on slendertone
Keeps beeping and flashing a triangle Had it for a week and its playing up . The pads aren't that worn
2 Suggested Answers
  • 1116 Answers
SOURCE: I just replaced the pads
Triangle error code denotes a pad contact problem.
These are the solutions for this error:
The triangle symbol has appeared on the LCD*
Pads not covering metal stud
Pads are worn
Pads on wrong way around
Liners still on the pads
Reposition pads
Contact your local distributor for new Slendertone pads
Ensure black surface of pad is facing you
Ensure liners are removed from both sides of the pads
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 02, 2011
Hi, I own a Citroen C-crosser, I have only had this for about two weeks and bought the car from a national company. The message which keeps appearing is 'Engine system service required&#39
that is nothing ,go on youtube and learn how to reset it or if you have the manual it is there , it is just time to do a service , good luck
Dec 03, 2014 | Citroen Cars & Trucks
What does a flashing Red triangle mean?
TCO means that the tachograph does not work properly. Because the european legislation is very strict regarding the malfunction of the tachograph system, the truck manufacturers alert the driver about his critical situation with a warning sign, the red triangle that flashes.
Apr 16, 2014 | Bruder MAN TGA Container Service Truck
Slendertone keeps beeping
the beeping its becouse there is no contact between the pads and the skin (1), or the cables and the pads (2), or the cables and the controller (3).
what the manufacturer says:
try to change the pads by new ones
i did that, but still not working.
what i do:
i had the second problem, but i fix it, i cut the cloth in the back part of the pin (not in the front of the pin), and i discover that the cable that is attached to the pin was cut, i remove the the pin, then i replaced with a bolt, i attch the cable to the bolt and thats all.
i'm using it right now and its works great.
i answer on another post similar to this one, a put a link to my google account where you can see pictures of what i did.
thums up! thank you!
Dec 28, 2013 | Slendertone Fortex
Red triangle and roomba stopped
If you get a red triangle with the two tone beep, and no voice prompt, roomba 770 runs for a few minutes or just immediately goes to red triangle...if you have thoroughly cleaned moving parts and find no obstructions, you may have the problem I had that stumped me for a week. Remove the trash bin, with roomba upside down, and there are 4 silver contacts that connect to two metal tabs on the trash bin. Over time the contacts lose some of their contact pressure. Use needle nose pliers to slightly rebend them so they make good contact to the trash bin contacts. These contacts feed the vacuum motor inside the trash bin. That fixed mine.
Dec 27, 2013 | Roomba 770 Robotic Vacuum
My slendertone belt keeps beeping with a triangle next to it. I can't turn up the intensity and it won't vibrate but I'm not sure why. What's the problem?
I just replaced new pads but that triangle still appear. Can't really do anything with the belt right now. Really frustrating.
Feb 18, 2011 | Slendertone Fortex
What are the cheats of ssx triky in ps2 pls.tell to me the cheats pls.pls.pls.tellit to me.
Unlock Pipe Dreams To unlock the Pipe Dreams track, get a Medal in all of the previous Showoff levels
. Unlock Untracked To unlock the free-form, powder-rich Untracked level, get a Medal in all of the previous Race levels.
Play as Mix Master Mike To play as DJ Mix Master Mike, go to the main title screen. Press and hold L1 and R1, then press X, X, RIGHT, X, X, DOWN, X, X, LEFT, X, X, UP. Then select any character and he/she will be replaced by Mix Master Mike when the level begins.
Unlock Riders Riders are unlocked in the game by completing the following tasks: Brodi: Win one Gold Medal in World Circuit.
Zoe: Win two Gold Medals in World Circuit.
JP: Win three Gold Medals in World Circuit.
Kaori: Win four Gold Medals in World Circuit.
Psymon: Win five Gold Medals in World Circuit.
Seeah: Win six Gold Medals in World Circuit.
Luther: Win seven Gold Medals in World Circuit.
Play as Rectorator To play as Rectorator, enter your name as RECOR in World Circuit Mode. Then select any character and he/she will be replaced by Rectorator when the level begins.
Master Cheat On the title screen, hold L1 + R1 then press X, TRIANGLE, RIGHT, CIRCLE, SQUARE, DOWN, TRIANGLE, SQUARE, LEFT, CIRCLE, X, UP.
Full Stats Cheat On the title screen, hold L1 + R1 then press TRIANGLE, TRIANGLE, RIGHT, TRIANGLE, TRIANGLE, DOWN, X, X, LEFT, X, X, UP.
Mallard Board On the title scree, hold L1 + R1 then press X, X, RIGHT, CIRCLE, CIRCLE, DOWN, TRIANGLE, TRIANGLE, LEFT, SQUARE, SQUARE, UP. Elise will have a Mallard Board and a blue outfit. This code only works for her.
Sticky Board Cheat On the title screen, hold L1 + R1 then press SQUARE, SQUARE, RIGHT, TRIANGLE, TRIANGLE, DOWN, CIRCLE, CIRCLE, LEFT, X, X, UP.
Running Man Cheat On the option screen, hold L1 + R1 + R2 + L2 then press SQUARE, TRIANGLE, CIRCLE, X, SQUARE, TRIANGLE, CIRCLE, X.
May 07, 2009 | Sony PlayStation 2 8MB Memory Card - Black
- All Songs Cheat Code? Rock Band.
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } You might be playing the rythm a tad off. Try to keep it at the same pace pretty quickly without stumbling.
The rythm should be pretty quick. Like eighth notes or sixteenth notes if you're musica
Jul 20, 2008 | MTV Games Rock Band for PlayStation 2
Playing mp3 songs on the ps3 --- 80gb
Whether you are hooking up your device through a USB cable or removable memory (SD card/Flash drive) the PS3 should recognize and play the titles. Here are a few steps to help you along.
1. Hook up device to your PS3
2. Select PS3 media icon where files files should be located
3. Press triangle button on controller
4. Sub menu will show up on side of screen
5. Select the 'display all' option
6. Files should now be accessable/loadable/playable
Playing files directly from the Mp3 player or loading them on the hard drive are both do-able and both methods should work.
Jan 13, 2008 | Sony Playstation 3 (PS3) Console
Slendertone Flex Go Abdominal Toning System, 1 ea Logo
44 people viewed this question
Top Slendertone Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you a Slendertone Exercise and Fitnes Expert? Answer questions, earn points and help others
