Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
S# K56A88B23 motor bad looking for replacememt
3450 RPM
3 Suggested Answers
  • 3600 Answers
SOURCE: I am looking for this motor or an eqivalent:mod.#
can't tell if it has the 48F frame but here is a web site withthe motors your ;ooking for. You will have to pick RPM for it since you did not list.
http://www.google.com/products?q=AO+Smith+1+1/2+HP+electric+motor&rls=com.microsoft:en-us:IE-SearchBox&oe=UTF-8&sourceid=ie7&rlz=1I7ADSA_en&um=1&ie=UTF-8&ei=6hdsS4TmD4usswPi9-GxDQ&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCAQrQQwAA
Posted on Feb 05, 2010
john224
  • 1378 Answers
SOURCE: Looking for a wiring diagram for an A.O. Smith
Thank you for posting your question here on Fixya.com.
That actually appears to be part of the serial number, not the part number at the end of your post. What are you trying to accomplish? With a description of your terminal board and the current wire arrangement I should be able to tell you what you need to know. Another option would be to contact us through our site at www.arrowmotor.net and send a picture of the board.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Mar 17, 2010
I hav a Powermatic model E16 planer, the motor has been changed to 1 phase 220 amp , the speed sees too slow, what speed should the cutters turn
If it's got the 3-3/4" three-knife cutterhead, it should run pretty near to 5000 RPM. If it's got the 1-7/8" two-knife cutterhead, it should run at nearly 10,000 RPM.
That planer should take a 3600 (3450) RPM motor.
Dec 29, 2013 | Powermatic 1352001 3520B 20x35" Wood...
How do you wire a type b 3450 rpm mod.c48k2pa105c5 motor to electrical box
two red wires means 220 volt those are both hot green is ground
red to L1 2nd red to L2 then green to ground ( to case) make sure on side of motor it is wired for 220 volt
Apr 03, 2013 | AO Smith A O Smith Motors Century 1hp 115v...
I have a 60 gallon husky air compressor with a bad 3.2hp motor. Will installing a 3hp motor hurt anything? Same rpm's(3450).
Should be just fine!
Any smaller, however, you might find the motor is laboring to run the compressor, as the motor may have been factory matched.
Be blessed.
Mar 21, 2013 | Air Tools & Compressors
What should the gear ratio be for a belt drive table saw?
you need max 5000 rpm for 10" blade
if you have a 1725rpm motor and 1.5" pulley on saw,with a pulley of 4" on motor the saw rotate at 4600 rpm if the motor is 3450 rpm 2" pulley give 4533 rpm
Nov 20, 2012 | Saws
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
Can you put a bigger Hp and a smalll plully onit
There are quite a few variations of motor and pulley combinations. You can change the motor and pulley based on your needs, however do not over-clock the recommended rpm or the pump. Check the specifications of the pump to determine the max rpm . Usually the pulley on the motor will depend on the rpm of the motor. Check the rpm of the present motor to determing the rpm of the pump with current set-up, and compare to the motor you are considering. Motor rpm vary from around 850 to 3450 so pulley size is quite important. Good holidays
Dec 18, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Motor & pulley
It would take 6" pully w/ a 2.25" which would not fit on that machine, no room for the 6". Replace with the same RPM motor is the proper way, unless you simply want a slower speed sander, duh! You cannot change the motor rpm without a defenant power issue, if you change the rpm your sander will power out, sorry?
Mar 30, 2009 | Tools & Hardware - Others
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
335 people viewed this question
Top AO Smith Plumbing Experts
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
