Question about Dryers
My dyer does not get hot - Dryers
  • 314 Answers
  1. Considerations
    • A dryer needs the proper voltage to produce the correct amount of heat. If your dryer isn't heating properly, it's possible that the power supply is the problem. Make sure that the dryer is firmly plugged into the outlet, and if you have a circuit breaker or fuse panel, check to make sure that everything is in working order.
    Theories/Speculation
    • Several things affect a dryer's ability to do its job. If an external source isn't causing the problem, then the dryer probably has a faulty part. Possible culprits include a damaged or burned-out heating element, a blown thermal fuse or damaged wiring, all of which will require replacing.
    Warning
    • The San Diego Fire-Rescue Department recommends having your dryer serviced by a professional repair person. If the problem is caused by something within your dryer's mechanism, you could make matters worse by trying to find and fix the problem on your own. With the exception of checking the dryer's external power supply, you should leave troubleshooting to a professional.
PLEASE RATE THESE SOLUTION
Posted on Jan 15, 2013
My dyer gets hot then it gets e64 then my dyer stops
It could be clogged vent or faulty sensor or thermostat control board Best way is check for clogged vent or any rust or cracked components and use step by step deduction method for trouble shooting
Dec 08, 2013 | Kenmore Dryers
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Dyer only blows cold air
U may have a blown thermostat or bad heating element.
Nov 14, 2011 | Dryers
Stackable dyer gets too hot in the back and i cannot find a filter
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 05, 2011 | Samsung DV316LGW Dryer
The dyer is working, but the dyer is not blowning any hot air
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Kenmore 600 7962 Dryer
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Dyer not working
Most likely a faulty heating element or a blown thermal fuse. Both components can be tested using a multimeter. Test for continuity. A lack of resistance indicates a bad component. The thermal fuse located just inside the rear of the dryer and is usually mounted on the exhaust duct. It is about one inch long. If it has no continuity, the thermal fuse is blown. Hope this helped and best wishes.
Aug 07, 2009 | Amana ALG331RAW Gas Dryer
Dryers Logo
Top Dryers Experts
