Question about Plumbing
Tub handle stem wont come out- 9c-23H/C 3 handle Danco for american standard
Please complete your problem description: What's your problem * Find your product * Add more details Adding details will get you a faster solution from experts * Required fields Post this on Facebook so your friends can help. Preview Area Danco Faucet Stem Problem with Danco Faucet Stem older 3 handle tub system -stem size 9C-23H/C Danco makes for American Standard (Colony I was told) 40 year old style -when we tried to remove the barely leaking stem (there is no socket that fits we were told) - The larger outside part of stem barrel came out leaving the thin longer inside still in. If it was originally soldered together there was not much there. It turns and turns and no amount of pulling, jiggling turning will bring it out.have no idea if this is a common problem. What do we do? Do we have ANY options except cutting into the wall? And if we do that can we get it free? If so how to proceed? Or does the whole system behind the wall have to be replaced? the maintenance man at the condo and online info made it out to be a simple issue and the leak was slight but wanted to completely replace including the seat while renovating since there was a leak then update the handles. Help please!
  • carol taylor Jan 15, 2013
    Alredy bought seat removal tool but with the long thin inside part of stem still in cannot get to seat. already pulled up and jiggled as much as dared without major damage. we dare not use more force without going behind the wall to see what we are doing.
I had a similar problem when looking to replace my shower valves with 9C-23H/C units. The old ones were very hard to get out, I imagine that they were the original ones that came with the house.
Do NOT cut into the wall, that will not get you anywhere. There is a nut that fits around the plumbing end of the stem; this is likely what is stuck. I had to put my foot on the wall and pull hard on the vise grips to get the stem out. You may want to use a flashlight and see if there is any scale build up which is getting in the way. Try to scrape that away if possible. Pull straight out on the stem very firmly, but don\'t yank on it, use constant pressure and avoid up and down movement as the nut has a tight clearance to make it out.
Going behind the wall should be an absolute last resort.
Posted on Jan 18, 2013
3 Suggested Answers
  • 2692 Answers
SOURCE: How to remove the corroded valve seat housing in my tub faucet
Some seats ae rremovable and some or not Some take a hex(allen) wrench and some take a square (seat removal tool)  Most of us use a seat grinder. (another tool to dress up the seat (Remove material) past the seat damage. You will find any of these tools at any hardware store that sells plumbing parts. If the seats have a square or hex hole remove and replace rather that grind(dress)the seat. All right hand threads meaning turn counter clock wise to remove. Take old seat to the American Standard plmbing supply outlet and then will match it up. Good fix-in to ya.
Posted on Feb 08, 2009
  • 18 Answers
SOURCE: When dishwasher is running, water
Is there an air gap next to the faucet that is leaking. If so, it is probably clogged. Pull the cap off of it and clean it out. This is what it may look like before you take the cap off.
b7ookdehz3uf293omx2ye0fveemyn-clsycdlpsjpi2zdtnzgmj_hhepw5uyprhfsmyzy7tnfmt6uzrk1edu-duydxm839afzrsaplofdfdjymmjvj8xncabtrcoevtu5jguw1elsvyttyypguy-89xi_btsfhkvzgvdbfbda26sii9hwd8sgq
Posted on Jan 18, 2011
9C-23H/C American Standard: Does the seat for the stem take an o-ring? I replaced the seats but the drip got worse.
There are three things to replacing a washer seat, after you turn the water off, open the valve before you replace it, most people take the stem nut out first, then putting it back over compresses it unless the valve is open.
Check the seat, this is not the rubber washer at the end of the stem. The seat is in the fixture, most can be removed with a special wrench.
Last but not least is the over tightening the valve to stop the water. Water wont stop instantly and it important to remember that. Turn the water of lightly when you are done, wait a moment to see what happens when the residual water drains. Then tighten more if necessary.
Feb 22, 2016 | American Standard Plumbing
HOW DO YOU ASSEMBLE AND INSTALL A DANCO 9S-4H/C
Turn off the water supplying the faucet. Now open the faucet. Remove handle by taking off index button and removing screw. You may need to purchase a handle puller, 10-15 dollars, and a stem wrench set. After removing handle, place appropiate sized wrench on stem and turn counter clockwise. Before installing stem, make sure it is in the open position. You may need to use the handle to turn the new stem. Screw in clockwise.
Jul 05, 2014 | Danco Faucet Stem
When I turn on the tub faucet, water comes out of the spout and shower head. It's a t215.710 model
Does it have a diverter on the spout? If so, replace the spout with the same type. If it is a new installation, did you make up the valve or was it complete and designed for tub & shower? If it's an old valve and it has a separate diverter stem, there is a spacer behind the valve between the valve housing. Replace it.
Apr 21, 2011 | American Standard Plumbing
Looking for faucet repair parts for early 1973's american standard 2separate handles
You will need to take those old parts to a store or place that handles Danco replacement parts. I wish I could direct you to a place that would have what your looking for but parts that old are just not out there. The other possibility is to rebuild what you have those old parts a really tough. I have some old stems and handles that you are welcome to just send me some pictures of what you have and we might get lucky. prb@mwii.net
Mar 20, 2011 | American Standard Plumbing
Cold water handle on my American Standard cold water control just spins around with out turning on the water
There is an adapter from the faucet stem to the handle. A small gray plastic faucet part that frequently causes problems for many owners. You will need to call American Standard and ask for a new handle stem connector. The faucet came with a limited lifetime warranty and the part should be free. While you are getting one, you might as well get another for the other handle. American Standard's phone number is 1-800-442-1902.
Sep 05, 2010 | American Standard Hampton Two-Handle...
I have a Danco 9C-23H/C stem for an American Standard shower stem replacement. I'm trying to identify where the friction ring is supposed to be placed. I've seen it in pictures going on the end where the...
there is never a fiction ring at the washer end, sometimes there is a cup shaped part that holds the washer but nothing else so it must be intended to go around the stem
Jun 27, 2010 | Danco Faucet Stem
Looking for cartridge for Tuscany Brass Tub Faucet Single Handle appears to be Ceramic Disk Type
While there are several cartridges that look similiar to what you have posted, Danco it self is an aftermarket parts replacement business. From my point of observation, your posted pic is of a Delta stem which visually has some distinctive attributes. Most every thing Danco makes is a copy or OEM replacement part packaged under their name.
Mar 16, 2010 | Danco Faucet Cartridge
I bought a replacement Danko faucet cartridge for an american standard bathroom sink and the package said hot/cold but when I installed it on the cold side the handle turns the wrong way. How do I reverse...
Thae stem you got that said hot/cold were designed to fit old style cross handle faucets. So both hot and cold turned the same way. If the cold side you are replacing turns the opposite direction then you will need to get a cold stem. Danco does make them. Ask the retailer where you purchased the H/C stem. I hope this helps..
Dec 29, 2009 | Danco Faucet Cartridge
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Feb 11, 2009 | American Standard 3275.505.099 Colony Soft...
Feb 08, 2009 | American Standard Plumbing
Plumbing Logo
160 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
