Question about HP Photosmart C4180 All-In-One InkJet Printer
Printer all connected properly not printing
While following all correct procedures on reinstalling printer i have put the cd in to the drive nd the cd is complely blank and i am unable to insatall printer not sure why or how cd has become blank, cannot even print test page even when it is showing that the printer is installed
    Problem Solver:
  • 11 Answers
What's the model of the printer?
Posted on Jul 10, 2007
SOURCE:
When trying to print more than 10 copies at a time, error code c-2558 appears and it stop printing..means it can only print 9 or 10 copies at a time but not more than that then error code appears
Code C2558 Description Abnormally high toner density detected TCR sensor
• TC ratio in the developing unit, which is determined by toner replenishing amount control mechanism, is a predetermined value or more for a given number of times consecutively. Remedy 1 Make sure that the following counter is cleared at the developer replacing. [Service Mode] - [Counter] - [Life] - [Developer Use Time] 2 Perform image troubleshooting procedure if image density is low. 3 Reinstall developing unit. 4 Reinstall toner bottle. 5 Check the contact of developing unit for proper connection and correct as necessary. 6 Check the connector between TCRSB CN29-relay CN28-PRCB CN24 for proper connection and correct as necessary. 7 Check the connector between M3-PRCB CN8 for proper connection and correct as necessary. 8 Check the connector between M4-relay CN13-PRCB CN8 for proper connection and correct as necessary. 9 M3 operation check. 10 M4 operation check. 11 Change developing unit. 12 Change TCRSB. 13 Change PRCB.
Feb 10, 2016 | Konica Minolta "Minolta Bizhub 363 Copier,...
KODAK ESP 3200 SERIES WILL NOT SCAN
I had the same problems; missing Icon and 100-2105.
This solution on the Kodak web site solved my problem.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Jan 13, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
From
Scan a document.
Sep 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I can`t get the printer to print photos or words. I have ink.nd it all looks good with printer All is connected, but will not respond.Help!
Just try with cleaning the cartridges and
first you make sure your printer is working fine just remove the test print form going to printer and faxes option just right click on it and give test print if it is print that means your application have some problem from where you removing print out if test page is not coming then you need to reinstall the drive of printer.
Make sure you install the driver properly and check the test print also .still if u fail check all this setting and follow this steps, 1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
In run window type services.msc and the go to print spooler option just stop and restart the service.
Jan 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I cannot print
there will be lot of possibilities .just follow all these steps.
kindly uninstall the printer driver and software restart the system and don’t connect the usb cable 1st install the driver cd and when it prompt you for connect the usb cable then connect it and follow the instruction. It will resolve your problem.
In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs. Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd
Nov 17, 2009 | Office Equipment & Supplies
The printer woll not print photos, otherwise OK
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Office Equipment & Supplies
Dell A940 copier works fine but will not print
Jan 04, 2009 | Dell A940 All-In-One InkJet Printer
My Epsom Stylus CX3900 series will not print
Normal 0 You have to reinstall the CD software program that came with the printer. During installation you will be asked what language and then select ENGLISH. Then follow the instructions.
But first do this.
Dec 28, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Printer wil not print
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Oct 25, 2008 | Brother Multi-Function Center MFC-665CW...
Will not print
you need to reinstall the driver to get this printer up and running again, try to find the cd from your printer and reinstall, or donload the recent driver on the web, make sure you select the right OS platform, it is usually easy to follow step by step procedure.
it is not automatic though when you make system recovery, it only repairs your pc not the external peripheral
hope this helps
Aug 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP Photosmart C4180 All-In-One InkJet Printer Logo
61 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
