Question about Fish
FS35 Berkley Fish Scale - Stopped Working
The digital display will not display/light up, unit acts like batteries are dead. Measured batteries with voltmeter and even tried a new set just in case. This scale was purchased only to be used to measure pulling forces in a clean dry environment and has seen little use, no water or extreme temperature ranges. It sits unused for 6 months at a time and I remove the batteries when not in use. Product is about 3 years old and has been used half a dozen times.
Jock Strap
SOURCE: low water flow from gaggia
I have now solved this problem. The lack of flow associated with the pump working but running quietly is caused by the Group Head being blocked with limescale. Normal descaling cannot remove it because it cannot penetrate the Group Head.
Removing the Group Bell can be achieved using a collection of screws (see photo) and works no matter how stubborn the thing: levering it with a screwdriver in my case was impossible as it was so well glued on. 6d47425.jpg
I figure that the advice to replace the rubber seal once per year is a good one because it forces you to remove the Group Bell and clean it out.
Posted on Aug 20, 2008
ptooshar
  • 19 Answers
SOURCE: scale appears to be inaccurate
this type of less resoluted scale hasn't repeatability. if you wish to repair it, change the loadcell. use 2 x scale capacity of load cell.
Posted on Dec 02, 2008
r321567499
  • 74 Answers
SOURCE: taylor digital bathroom scale
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
  • 33 Answers
SOURCE: Craftsman generator, several years old,
pour a little raw fuel into carb intake. try to start. if engine runs for a few seconds and quits the problem is more than likely a clogged carb. go to auto store and get a gallon can of carb clreaner and dissassemble carb and lower into bucket and let soak over nite. you'll want to get a carb kit to replace any gaskets that may get messed up during tear down. when you go back together make sure to wash any residue of cleaner out of carb and use a small nozzel air blower on air hose to blow out ALL passages any needle valves have to screw into. take a can of carb cleaner and with the small straw place over hole and squirt into hole. make sure cleaner come out some where in carb body. that way you know all the passages are open. reassemble and crank her up.also invest in a compression guage. remove pllug and screw gauge into plug hole. pull sharply at least 5 times and see what the reading on the guage is. should be at least 70 or better. if rings and valves in good condition don't be surprised at a reading of 120 or better.
Posted on Apr 21, 2009
  • 10865 Answers
SOURCE: Salter 9001 bathroom scale stopped working
Hi Pete. I don't keep receipts either : ^ )
No that I am done commeserating, try this. Remove the batteries. Use the eraser end of a common pencil to scrub and clean the battery contacts inside the battery compartment. Also pull the contacts a little closer to the surface if you can. Then reinstall the batteries and you may be up and running.
Please rate my answer as verey helpful thanks. Joe
Posted on Mar 26, 2010
Digital camera will not switch on
What do you want? You indicated the power switch is not working and that is the cause. get to it and fix the switch.
Nov 05, 2015 | Panasonic Lumix DMC-FH25 / DMC-FS35...
How much light do I need for my aquarium?
The spectrum of light is measured by the Kelvin scale (K). Natural sunlight is 5500K. Most freshwater fish will thrive in aquariums with a Kelvin rating of between 5500 and 6500K; whereas reefs and deep-water saltwater fish need a light around 10,000K.
Aug 14, 2012 | Fish
I changed the new batteries but still digital display is not shown
if the batteries are new and the battery terminals are clean and not corroded or broken, and the battery polarity is correct when they were installed. There must be a fault in the internal circuits of the scale, and a technician with the right tools, training, and experience will be needed to repair it.
Maybe time for a new scale.
Oct 05, 2017 | Health-O-Meter Health o Meter BFM681DQ-63...
DigiWeigh pocket scale showing..UnSE code..what is UnSE code?
Remove the battery - this happens when the scale tries to use a dead battery instead of the wall power supply.
May 02, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Digital panel no longer works. need source for circuit board and approximate cost
Masterbuilt Digital Smoker no longer heats up and digital display has stopped working completely. The unit acts like there is no power to it and is completely dead. By replacing the digital component will this solve my problem
Jul 01, 2010 | Masterbuilt 20070106 Electric Smoker
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
I can't get the light or the bell to stop flashig or ringing on the berkley pole tap.what do i do?
You MUST have the LED light facing down towards the reel when it is attached to the rod. If it is attached upside down with the LED facing up it will continue to flash or beep nonstop. The simple instructions for the Berkley poletap is -
1.Turn the unit to light or sound.
2.Cast your line,( it will blink or beep as you cast).
3. Set unit in rodholder or against chair,(Poletap will blink or beep about 12 seconds and then stop when still).
4. When a fish nibbles or strikes the poletap will alert with your setting of light or sound.
You may want to check out the new Berkley Poletap Pro, It has complete sensitivity settings for windy days and Tilt - angle for slow pull fish, high current and trolling mode.Awsome product!
Check it out at this Berkley site.
http://www.berkley-fishing.com/prod.php?k=299309&sk=299309&p=PURBAPPBA%20(11187809)
Oct 04, 2009 | Berkley Twist Lock Rod Rack
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Fish Logo
110 people viewed this question
Top Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Are you a Fish Expert? Answer questions, earn points and help others
