Question about Palm Tungsten T3 Handheld
Palm Tungsten T3 cannot hot sync.
Last successful sync was Nov 2012. Battery was low so I put it in the cradle to charge and it zapped back with a hard reset. Lost everything on the Palm. Desktop still shows all info (from Nov 2012 and before.) Cannot reestablish connection with hotsync.
  • Steve Cieslinski Jan 17, 2013
    Installed Desktop 4.1.4e when I switched to Win 7 OS. Initial sync and setup went fine. I use Cradle/Cable and Local USB setup. This has happened once before (at airport security, where when they x-rayed my luggage, the Palm blanked out). The difference was I was able to put it back in my cradle and sync. The connection is obvious there because I'm able to charge just fine. I just can't get the sync connection. I tried reinstalling the Desktop software (of course, while backing up first), but to no avail. Let me know what specifically you need to know, so I can be more helpful.
  • 473 Answers
SOURCE: Tungsten E and Outlook 2003 sync problem
I also have encountered this: The issues, however, started after our enterprise at work switched the backoffice server from Win2K pro to 2003 server. All users received new Outlook profiles. I know there are hidden services for Palm bundled into the outlook profile so I simply edited the old profile to point to the new server and proceeded as follows: CPU was an HP Pavilion DV1000 laptop with Windows XP Pro SP2 with Outlook 2003 to a Palm Tungsten E PDA. Unit would not synchronize contacts or calendar, producing "Calendar Synchronization Failed" and "Contacts Synchronization failed" errors. Creating entries in outlook contacts and calendar did not show up on the Palm. Creating entries on the PDA did not show up in Outlook. To rule out windows profile corruption, I backed up the users profile data, deleted her windows profile and logged back in to create a new one, copied all of her favorites, documents and desktop information back to the new profile and tried again. No joy. I created a new palm profile to rule out issues with the users original Palm profile being corrupt or damaged. I verified the hotsync app was pointing to the correct palm and outlook profiles. To rule out issues with her outlook profile being corrupt or damaged I backed up her contact and calendar data, wiped that too and created an all new one and re-imported the contact data from a personal folder not connected to an exchange server. No change. I deinstalled and reinstalled the Palm software as well as the conduits for outlook. No change. I downloaded the new and improved conduits that were supposed to fix issues with outlook synch problems. No change. I finally backed up all of the data on her palm by creating a new outlook profile that was not connected to our exchange server at the company but rather a personal folder on the PC and once the data was saved there the data was imported back to the users mailbox. This didn't work but it allowed us to back up all the data on the palm and let us perform some experimentation with formatting the palm clean as a plate and trying anew with her account and profiles - no change. I found the errors only occurred when logged in as the user herself. If I logged in as me and started fresh from a reinitialized palm on her computer it would work. Amazing. I even found that creating a new local user account on the PC and pointing at her own outlook account on the mail server wouldn't work either.. But it would work for my own. After some brainstorming.... I believe that the issue is related to a corrupt e-mail box on the actual mailserver itself rather than an issue with the workstation or the palm itself since if I log in as myself, I can set it up and make it work. I can use a different account. It works. But it ALWAYS fails when we attempt to attach to the users mailbox on the server itself. So, some of these issues could be related to changes or problems on an Outlook mailbox th
Posted on Sep 11, 2005
  • 4102 Answers
SOURCE: Palm M515 hot sync problem
Hi you could either have a problem with the lead witch is the cheapest problem to solve the other problem is with the palm top itself if this is the case then you will need to send it off to get the firmware updated you cant do this yourself because you cant get the correct software to do this you might even need to put the device in recovery mode to install the latest firmware so it will need sending off to do this if you contact customer support number for your device then they should tell you the best way of doing this ok
Posted on Feb 11, 2008
I have a similar problem with my m515. I have 3 palms and 2 sync fine but the 3rd isn't even getting to the computer. There is no recognition from the computer that the palm is trying to sync even though I use the same cradle for all palms. The ensuing message is, "the connection between your handeld computer and the desktop could not be established. Please check your setup and try again". My settings are set Local and Cradle/Cable.
SOURCE: MY TREO 650 KEEPS TRYING TO HOTSYNC(and its not connected to computer)
how to hard reset my palm treo 650
Posted on Nov 29, 2008
  • 14 Answers
SOURCE: palm centro wont turn back on to do hard reset
Follow the below link to perform a Hard reset on the device.
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=406,E=0000000000194928396,K=1994,Sxi=14,Case=obj(887)
Posted on Dec 25, 2008
Replacement new Battery In PDA not functioning
I will be writing off the PDA as it is now over three years old and updating to more recent technology. I have not yet made my repalcement choice.
Jan 28, 2010 | Palm Tungsten T3 Handheld
My tungsten palm went black and now all of my info is gone.
The battery died. if you by chance synced your pda to your computer than you can get it all back by connecting the pda to the computer through usb or cradle and press your hot sync button or option.
Aug 26, 2008 | Computers & Internet
Tungsten t3
Please use the free chat feature that palm offers. I am not sure of any other way to charge your palm. Here is the link. Scroll to the bottom of the page and you will see Palm Chat. Click on the Chat Now link and follow the instructions. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/t3/unlocked/supportservices/page_en.html
You might be able to find a charger on Ebay too.
Nov 18, 2009 | Palm Tungsten T3 Handheld
Palm T3 frozen, tried restart in hole, nothing?
take the battery off for 15 seconds and put it back again. you need to reboot your Palm at least once a week. goodluck!!!
Jan 31, 2008 | Palm Tungsten T3 Handheld
Help Dead Battery
When you recharge the palm, sync it again with your computer.
If the Palm has been synced with this computer, it will pull up a list of profiles for you to choose from.
If you select the profile name given to it before, it should restore everything you had on it from the last successful sync.
Jan 07, 2008 | Palm Tungsten E2 Handheld
Synchronizing Tungsten T3 with desktop or laptop
I recently re-installed my T3 program
What do you mean?
  • Did you restore your T3 from a backup on the PC?
  • Did you install programs on the T3 using the PC's "quick install"?
Is Palm Desktop showing the correct Contact/To-do/Calendar Data?
How are the conduits set up? (From Palm Desktop, select Hotsync->Custom)
Nov 15, 2007 | Palm Tungsten T3 Handheld
T3 sync with Outlook works except for Tasks
A hard reset of my T3 and sync with 'Desktop overwrite HH' on all Outlook conduits seemed to have resolved the problem.
Sep 11, 2005 | Palm Tungsten T3 Handheld
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
1 palm + 2 computers = successful hotsync?
Yes and.. no.
It is possible to have one Palm synchronized to 2 PCs (I do this with my T3), just make sure that you don't end up with any "overlapping changes" - items that change on both machines.
However, since Syncing takes a full backup of the Palm, having two completely different sets of data on two different machines is complicated at best. If you are are not careful you could lose all your info by accident. One way to get around this would be to put everything on on the T3 and use categories to separate work and personal items - which is what I do.
However, if you are dead-set on keeping all of your work stuff in one place and all your personal stuff in another, I would recommend that you get a second T3.
Sep 07, 2005 | Palm Tungsten T3 Handheld
Palm Tungsten T3 Handheld Logo
50 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
