Question about Nespresso Aeroccino Automatic Milk Frother
The aerocino makes only cold milk now. As soon as we press the button it turns blue (so cold milk). It just started a few days ago, before, everything was working perfectly well. Is there a way to fix this ?
    New Friend:
Just to say am having exactly the same problem!
Posted on Jan 19, 2013
On the very second use red light does not come up if pressed for longer blue light comes
read the operating instructions again and if you are following then then take it back for a warranty replacement
Sep 04, 2015 | Nespresso Aeroccino Automatic Milk Frother
Nespresso Aeroccino 3 does not heat and froth
I got mine today exact same thing happens... only blue does not warm AT ALL
Aug 26, 2012 | Coffee Makers & Espresso Machines
What does a blue light mean on my aerochino? thanks.
Means you are not heating your milk, the frothing milk will be cold (for iced drinks) because you have held the button down longer than normal. Usually it takes 5 Seconds for the blue light to go on. try turning it on or pushing the button faster, It should turn on red, for heated and frothed milk.
Nov 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
Burnt Milk at Bottom of Aeroccino
Try this - make a paste from bicarbonate of soda and water and let it
sit in the bottom of the frother for ten minutes or so. Then use a sponge
to clean off the milk stain and rinse and dry thoroughly. To prevent it from
recurring, rinse and dry the inside after each use and don't get the base
of the frother wet.
Jul 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
How do I make cold froth on my aeroccino for my lattes?
Press the and hold the button for 5sec or longer until the light turns blue. That will get you cold froth.
Jun 27, 2010 | Nespresso Aeroccino Automatic Milk Frother
My Nespresso milk frother did not come with instructions. Is there some way to froth but not heat the milk?
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
Jan 25, 2010 | Nespresso Aeroccino Automatic Milk Frother
What does a it mean if the aerocino is flashing its red light?
We had the same thing, and I think it has to do with overheating as well.
After about two goes of frothing hot milk, a little bit of burnt milk residue had formed on the bottom of the jug. I think that "fools" the temperature sensor, and makes it "think" the milk is hot before the frothing time is up (then shuts the machine off, blinking the red light).
As soon as I cleaned the bottom of the jug (had to scrape it with my nails after leaving water in for a while), all systems were "go" again......
My remedy: rinse the jug quickly with cold water after each use, making sure the bottom stays clean!
Aug 21, 2009 | Nespresso Aeroccino Automatic Milk Frother
On/off problems
Found out if you just leave it for 30 seconds after turning the power on but before activating it works fine.
Dec 16, 2007 | Nespresso Aeroccino Automatic Milk Frother
Display colour
Mine would do the same thing. What you need to do is turn the unit off and it should go into demo mode. There is an option for "reverse mode on or off" make sure it is turned off. I beleive you will have to hit the band button to change it.
Oct 17, 2007 | Pioneer DEH-P6900UB CD Player
Nespresso Aeroccino Automatic Milk Frother Logo
525 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
