Question about Electrical Supplies
How can I Fix a Light Fixture and/or the connecting Switch that's Not Working?
    Problem Solver:
  • 12 Answers
If your light is not working try removing it and connecting a pig tail socket and lamp. Connect the black wire to the black and the white to the white. Then try the switch. If the light dosn't turn on then you need to replace switch. You need to turn off the breaker or remove the fuse powering that switch first. remove the wires from switch, and put wires back at the same screws on the new switch.
Posted on Jan 26, 2009
Why is the light switch not working after i have wired up ceiling light
check to make sure you have all the white (neutral wires connected as well as the wire to the fixture. Make sure both wires from the fixture are connected to the wires in the light outlet box. White to white(maybe more than 1 in the light box) to the white (common) of the fixture an a different color (usually black or red) to the black from the fixture. Connect ground to ground wire or metal box. Turn the circuit breaker back on, if you turned it off, and turn on the switch. If this doesn't help it is time to get someone who can operate a multi-meter and understands electrical troubleshooting.
Jun 28, 2014 | Electrical Supplies
I have a dead short somewhere in the wiring for 6 recessed ceiling lights. How do I trouble shoot this to find the short
Test each light separately.
Black Hot wire arrives at one screw on the switch. The Hot black wire going to Lights connects to other screw on the switch.
The White Neutral that completes the circuit to lights is connected with other white wires that are covered with wire nut pushed to back of box.
Open up light#1, and the Hot and Neutral arrive from switch box.
The Hot and Neutral going to lights#2-6 are also located inside light#1 box.
Check each wire for signs of high heat and burning. Check each wire if the insulation has been sliced, or cut short, or if copper is visible because wire nut does not cover wires correctly
http://waterheatertimer.org/How-to-select-right-wire-nut.html
Disconnect Hot and Neutral going to lights#2-6, so switch is only turning on light#1.
Test if there is a short when turning switch ON.
Then repeat step, so switch turns on light#1 and light#2, but light#3-6 are disconnected.
May 31, 2012 | Electrical Supplies
What is the deal with the two permanent black wires that are both on the white half and switch half? The wiring diagram supplied does not address this.
You are installing switch plug combo with GFCI
Device has 4 screw terminals and 2 wires.
Look at markings on back of device to determine Line and Load screws.
If you are working inside junction box, there are 3 cables for example. Each cable has black and white wires. Cable1 comes from breaker box with Line wires, cable2 goes to light fixture, cable3 goes to next switch or receptacle box in the circuit.
Cable1 Line wires come from circuit breaker: Black wire connects to brass Line screw, White to silver Line screw.
Cable2 wires to light fixture connect to wires sticking out of device and are controlled by light switch.
Cable3 wires connect to Load screws. Black wire connects to brass Load screw, White to silver Load screw. This will put GFCI protection on circuit from that point forward. If you do not want that protection, then connect cable3 on same screws as cable1.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 22, 2011 | Pass & Seymour 1595SWTTRWCC4 COMBINATION...
I want to install a light in my garage i have a live source but how do i connect it to the light and wall switch
My first response would be to seek help from an electrician or someone qualified to perform this work.
If you are going to attempt it, you will need the following items:
- electrical box
- light switch
- light fixture
- wire ( ask you local hardware store clerk what is recommended or needed to meet code in your area.
Disconnect power at breaker to your source.
From your source,
- connect wires to electrical box. then to;
- connect wires to switch then to;
- connect wires to another box at the fixture
- connect fixture to the box.
box=====switch=====box=fixture.
Apr 27, 2010 | Westinghouse Electric Ceiling Fan 3-way...
I want to put a switch on a existing light that has a power source from the main panel then carrys on to other wall receptacles.i just want the light to go on and off with the switch, not the receptacles.
there is a simple way and a not so simple solution, the simple solution is to take down the light fixture and replace with a pull chain fixture. I would have to know the building type commercial ...residential...is it hard piped and so on. In a residential setting the solution would be to install a piece of 14-2 romex between the fixture and the switch. 14-2 with ground is a flat cable with 3 wires (2 insulated and 1 bare). do not attempt with the power source on. the white insulated wire should be connected to the black wire in the fixture box, the other end of the white wire in your new piece of romex should be attached to one pole of the switch. the black wire in your new piece of romex should be attached to the black wire or gold screw of your fixture and the other end of your wire should be attached to the other pole of your switch. Now the other wire(the bare ground)if not attached will not affect the operation of the switch or light, but it is a safety which should be installed. all grounds should be connected to insure that any faulty wiring will trip the breaker saving anyone from getting shocked.
Dec 21, 2009 | Cooper Industries Cooper Wiring 2158V 3...
I have a live 2-wire line that used to be connected to a light with a switch built into the light fixture. I removed the fixture and put wire nuts on the live wire. What I'm trying to do is to wire the 2...
As I understand it you have a live circuit going to a light fixture that had a switch built into it. You have removed the fixture and now you want to run this wire to another location and install a switch in the circuit.
You will be extinding these two wires (white and black + ground) to the new location. No problem ... Somewhere between where you start and where you finish, you will break the black wire and install a single pole switch. All connecctions must happen inside a electrical box.
So, install the new wire in the box where you will start your extension. Run to the new switch box. You dont even have to cut the white wire. You will wrap the green or ground around the ground screw on the switch, Cut the black wire . put one end under one side screw, put the other end under the other side screw. From this box run your wire to the next box where you will install your fixture.
If you are using metal boxes, they must be grounded to the circuit. You can use pig tails for this, Best deal is to use plastic boxes that dont require grounding.
I hope this answers your question
Oct 17, 2009 | Cooper Wiring Devices 1301-7B GROUNDING...
Wiring Door jamb switch
I'm going to guide you on how to create what is known as a "switch leg".
1- run a 12-2 w/ground wire to the light fixture from new switch.
2- connect black wire "hot wire" to the shiny bronze tinted terminal on switch.
3- connect the white wire " neutral " to the silver connection on switch.
4- connect the naked copper wire " ground " to the ground terminal on switch
5- Disconnect the two white wires in the junction box from each other.
6- Connect the ground to ground in j-box
7- Connect the black to one of the whites in j-box
8- connect the white to the other white in j-box
9- wire nut and tape all connections
Oh and be sure that you turn off the breaker before you start. Hope this helps. Good luck.
Jun 15, 2009 | Gardner Bender #GSW-SK Door Switch
Pull on/off switch
Put one wire from switch to black wiring coming in and the other to the black going to the ballast.
If you do not understand please post back
Dec 01, 2008 | Electric Door Light Switch
Electrical Supplies Logo
243 people viewed this question
Top Electrical Supplies Experts
Steve
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
