Question about Kubik Digital Electronics Kubik Roca 8Gb Touchscreen Mp3 And Video Player
Kubik Roca, blue screen's my pc
When i connect my Kubik Roca to my pc it blue screens
How do I fix my Kubik Evo 8Gb? The software doesn't work. The screen is black and I can not get access to the menu. My files are ok I can see them when I plug it to my computer. Thank you
Your electronics are ng. U might try to reset unit by doing a hard reset to see if that clears up the anomaly. If not, replacement, not repair, is in order.
Aug 27, 2016 | Kubik Digital Electronics Kubik Evo 8Gb...
Hi my kubik after 1 week will not switch on or charge or do anything once plugged in to pc. can i reset it?
In answer to your question, no not in the sense that you mean (similar thing happened to mine). If it does not work at all (that is to say cannot be burned on) when not connected to the PC then I'd say that it needs returning and repacing. If it does switch on when not connected to the PC then try another cable justin case this is the fault, though I am more inclined to the "back to seller" route as the most probable outcome.
Mar 14, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
I need the driver for my kubik evo 8g mp3 player. The driver disappeared off my computer and now doesn't recognize my player.
You should not need drivers for this device as it ought to be picked up automatically by your computer (assuming that it's Windows, what version are you running?). If you have an expansion card in the player, then try removing this and then re-connecting the Kubik to your PC to make sure that the expansion card is not faulty.
Another quick test is to check the cable, both in a different USB slot if you have one available and / or by connecting another USB device that uses the same connection (in my case, a digital SLR camera has the same USB adapater so I can use the cable for either). If, doing this, the second device also is not recognised then try swapping the cable for a new one (but again, if possible test the cable and connection to other USB device in another USB slot as well).
One other quick question - does the Kubik device work still when unplugged from he PC?
Feb 17, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
Kub Has it got bluetooth
I'm afraid it does not have Blue Tooth, you can only connect speakers via the ear phone socket .
Feb 16, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
Kubik roca driver download
download easydriver and install it
Jan 24, 2014 | Computers & Internet
Have Kubik edge 8g, will not show menu screen, have format and reset factory settings can you help please
i have the same problem, when i switch on only the kubik digital logo shows and no menu page . have to reset to switch off , connected it to the computer and it does not show up, did you have any luck finding out whats wrong if so please let me knowi have looked around internet and it seems to be a common problem but dont know anyone who has sorted it out.
Jul 01, 2010 | Audio Players & Recorders
My Kubik edge 4GB won't turn on. It just keeps freezing when the words 'Kubik Digital' come on the screen when I turn it on. How can I make it work again?
Thank you for your enquiry I will be glad to assist you. Please can you make sure the player has been reset correctly. There is a reset button on the side of the player please can you press this button carefully using a pin when the player is turned on. The actual reset button is at the bottom of the hole and you will hear a faint click when the button is pressed correctly.
Please drain the battery completely and reformat your player?
To Format the player follow these instruction:
  1. Connect the player to your computer using the USB lead
  2. 2. Go to “My Computer”, your player will be shown as a Removable disk
  3. 3. Right click on this icon and select Format.
  4. 4. All files and folders will be deleted from the player
  5. 5. Once the format is complete, disconnect the player from the computer and turn the player off.
Please let me know if the problem persists.
Amy Jackson
Customer Services
Kubik Digital
www.kubik-digital.com
Mar 27, 2010 | Audio Players & Recorders
Kubik Edge 4gb 'frozen' screen on boot up.
Hey guys, I'm gonna cut to the chase, the little hole on the bottom right hand corner or the kubik edge get a sewing needle and press it 2 times! Hope it works guy xxx
Mar 08, 2010 | Audio Players & Recorders
Kubik edge
I have a touch screen Kubik player It was stucked , What I want to do now.
Jul 27, 2009 | Audio Players & Recorders
Kubik Digital Electronics Kubik Roca 8Gb Touchscreen Mp3 And Video Player Logo
Top Kubik Digital Electronics Audio Players & Recorders Experts
richie46
ray gallant
Robin Brighouse
Robin Brighouse
Are you a Kubik Digital Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
