Question about Sewing Machines
I have a Necchi 535FA sewing machine that will not catch either the thread, just leaves a stright line of thread not catched
I have cleaned the machine & oiled it. It worked fine last time I used it. Now I'm lucky if it will even catch the bottom thread to start sewing & if it does that's about as far as it goes as it stitches but nothing is hapening. It's like I have no thread in the machine.
  • Sewing Machines Master
  • 7,365 Answers
Try changing the needle
also try rethreading the machine top and bobbin
make sure the bobbin is turned the correct way in the bobbin case
if the suggestions don't help then it's possible that the machine
needs to be checked for a timing problem
Posted on Jan 15, 2013
2 Suggested Answers
RickE1
  • 202 Answers
SOURCE: I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Posted on Aug 29, 2009
Necchi 525FA is leaving too much thread and catching, causing to break thread. How do I correct this?
Could be - yr needle is bent. Replace it, or - I (too cheap to toss them), have gently re-straightened them. Or, I could be wrong. Love Necchi machineS!
Feb 03, 2018 | Necchi Sewing Machines
Why does'n the needle catch the bobbin thread on Necchi BU Nova
Your hook is moving correctly. Not all machines do a continuous circle. If it's not catching the thread, the timing is off. It's a great machine, and worth every penny to have it serviced.
Feb 27, 2015 | Singer Sewing Machines
I have a Necchi 4900 and the thread catches on the bobbin holder , moves the bobbin holder out of place , james , have taken it out cleaned everthing under the bobbin and takewn the underneath cover
try changing the needle to see if that helps
if it doesn't,, then I suggest that the sewing machine be checked
at a repair shop to see if the bobbin case needs to be replaced and
to see if the hook and the hook race need to be replaced
Nov 01, 2012 | Necchi Sewing Machines
Necchi model 3537 won't pick up bobbin thread
sewvacdoctor.com has a list on their site with helpful free tips. I found this site for you I think will get you on your way. Hope this helps.
Apr 03, 2012 | Necchi 3537 Mechanical Sewing Machine
Necchi 215A Sewing machine Could anyone help I have a Necchi 215A which will not catch teh bobbin thread, I have tried a new needle and checked the bobbin is loaded and fitted correctly. The needle passes...
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Sep 26, 2010 | Necchi Sewing Machines
Threading the bobbin- Necchi 535FA
Hi - I have a 510 Necchi sewing machine - how do a fill the bobbin?
May 04, 2010 | Necchi Sewing Machines
Bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
Apr 08, 2010 | Necchi 3102 Mechanical Sewing Machine
Rick
Aug 24, 2009 | Necchi Sewing Machines
How do i thread the bobbin on my necchi 539
take out your bobbin and turn it the other way
Feb 02, 2009 | Necchi Sewing Machines
Sewing Machines Logo
74 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
