Question about Dryers
Changed battery in transmitter #sku175-776 with 7067r receiver, now nothing works and the red light stays on
Maanita
  • 1142 Answers
SOURCE: red light on receiver will not go off
there is a green button on your reciever and below the mouse.
press the connect button on both together and release them
Posted on Feb 08, 2008
renx
  • 71 Answers
SOURCE: Wireless speakers not communicating to Receiver
Speakers have a unique RF frequency that needs to pair with the receiver (kind of like a blue tooth headset with a cell phone). At times, the signal may reset, so, you may have to go through the initial pairing sequence. Try this:
1. Unplug rear speakers
2. Make sure the sound signal connector is plugged in to the back of the system properly.
3. Press and hold the ID button for 3 seconds until the blue LED light flickers.
4. Connect the power chord to the rear speakers.
Posted on May 03, 2009
  • 5603 Answers
SOURCE: I have a shure ULX-1m1 transmitter with full
First, sometimes LCD screens have an intesity/angle control and at extreme range of these characters are sometimes not visible. Check you manual to see if your unit might have such a setting.
Also this unit has some control lockouts so make sure it is unlocked so the automatic frequency selection can be made.
Verify the status of the LED in your manual. MANY Shure mics display the LED red when battery is low.
DO NOT trust a battery as being full because it is new.
ALSO DO NOT USE rechargeable batteries in these as the rechargeable battery does NOT produce 9 volts... usually only 7.2 volts (in spite of the labeling) which is insufficient and will give a low battery indication.
Posted on Sep 30, 2009
dunnbiker
  • 8546 Answers
SOURCE: Transmitter seems to have stopped working.
Have you tried holding the unit in your hand either closer or farther away from the sender while the wheel is turning to see if it picks up the signal? It needs line of sight to the sender and some units actually specify a minimum distance as well as a maximum one. On the sender it may have an arrow indicating which direction the computer should be located. Believe it or not, I have seen them work better when the sender is pointing 180 degrees opposite the prescribed orientation. You should be able to detect this with the computer in your hand. Move it around the sender to find the 'sweet' spot and direction, then see if you can manage to mount it on the bike so it will keep working.
Posted on Jul 22, 2010
  • 30 Answers
SOURCE: skyscan atomic clock weather
Make sure the battery contcts are clean of any corrosion.
-AAT
Posted on Feb 22, 2011
Red light inside the freezer part stay on for my side by side Kenmore refrigerator
Hello William;
My name is Peter. I am a retired field service refrigeration technician.
The, 'Red' light is a infra red light. This light assembly on the right hand side of your freezer is the transmitter.
Directly across is the receiver. On the receiver is a spring loaded plastic flapper.
This is a safety device for your ice maker. When the freezer door is closed, the flapper is closed, allowing the infra red transmitter to complete the signal to the receiver. This allows the ice maker to discharge ice cubes. When the door is open the signal is broken, the flapper springs out blocking the circuit signal, and the ice maker will not discharge ice cubes.
There is a On/Off switch on the red transmitter. I do not know why you would want to turn it off. If you turn it off and the transmitter stays on then you have to replace both the transmitter and receiver.
Nov 11, 2014 | Kenmore Refrigerators
What do you do if the remote does not work and tried changing the battery
Sounds like you need a new receiver for the transmitter. What make/model of fan do you have? fanman9952@aol.com
Sep 22, 2014 | Dryers
My rc939 wont work unless right next to receiver.
Your description sounds similar to the problem ceiling fan owners have with their RF remotes. Try disconnecting the power to the pool light (at the breaker), pausing, and reconnecting power. Try remote operation. If nothing changes, reprogram the transmitter to the original setting and repeat the previous test. If nothing changes, the transmitter may have sharply reduced power output or the receiver may be defective.
Jun 21, 2014 | Intermatic RC939 3 Channel Radio...
Remote for ceiling fan light stays on
Sounds like you need a new transmitter. The light is a battery indicator light.
Mar 06, 2014 | Savoy House Dryers
Changed battery and it doesn't detect transmitter. Everything else works and the transmitter gets detected by our treadmill, so I know it works.?
Transmitter Battery
The estimated average battery life span of the transmitter is 2500 hours of use. If you suspect that the transmitter battery
has run out, contact your authorized Polar Service Center for a replacement transmitter. Polar recycles used transmitters;;;
Dec 28, 2013 | Polar F6 Wrist Watch
Skytech 1410 fireplace remote (8 yrs. old) has stopped working. Replaced batteries in the transmitter. The red light lights up when
It may need to be re-synchronized:
Make sure the receiver's slide switch is in the REMOTE position.
Press and release the LEARN button on the receiver.
When you hear the "Beep", press and hold the ON or OFF button for about 2 seconds on the transmitter.
You will then hear a series of beeps that indicate that your new transmitter has been accepted by the receiver.
If you press the LEARN button on the receiver and you hear no beeps, the receiver is unable to retain any more transmitter codes
(make sure the transmitter battery is properly installed and fully charged).
To delete all of the transmitter codes on your receiver, press and hold the LEARN button for 10 seconds. Then you will hear a
series of beeps, indicating that the receiver's memory has been cleared.
It could also be dead after 8 years. A new unit can be purchased here: Skytech Remotes. I would even suggest on of the new styles with a built in timer or thermostat.
Nov 08, 2012 | Skytech 1001-A Fireplace Remote Control...
Got my brand new hobby zone champ yesterday and it will not work, charged up the battery instailed the AA batteries into controler. turn radio on red light comes on instail battery on the air plane, you...
Remote transmitter got the problem.
If that is brand new it must have a warranty, return it to the store you bought it and test flight it in front of you before you get back home.
Hope that helps.
Sep 21, 2011 | Hobby Zone Champ RTF
Remote door transmitter is not working. Changed the battery.....still nothing.
does the 2nd transmitter work
if no, then your receive may have failed
if you don't have a 2nd transmitter, then you need to take your vehicle in for service and either have the failed parts replaced or best case, have the transmitter or receive reprogrammed
Sep 08, 2010 | 2008 Honda Pilot
Akg sr 60
help me please akg sr60 , when torn on just mute
Dec 05, 2007 | Lands Phones
Dryers Logo
53 people viewed this question
Top Dryers Experts
