Question about Apple MacBook Pro with 17" Display
Macbook pro battery does not charge
Battery does not charge
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
You will need to replace the battery.
Posted on Nov 10, 2013
2 Suggested Answers
  • 91 Answers
SOURCE: macbook pro won't start/charge
It appears as if your power supply is dead. The power supply is inline with your power cord and has a light on it, if I am correct. Since the green light was dim, then went out all together on your power supply, that would indicate that it would not take a charge any longer, and the dim light, down to none, was the rest of your battery draining. Assuming you tried multiple power outlets, my suggestion would to borrow a power source from a friend and check it, or go to best buy/Apple store and have them use one of theirs to see if it comes on.
Posted on Sep 25, 2012
My macbook pro won't charge, why is the charger not working
make sure that the connection between the charger and macbook is clean.
If the charger lights up green and doesn't change to orange, then it may not be connecting. If it stays green, the battery might be dead or improperly inserted. It may need a different sized cord -- check for proper wattage.
Apr 30, 2014 | Apple MacBook Pro Notebook
Any tips on extending the life of a Macbook Pro battery?
My suggestion would be to buy a new battery.
After that you should shut down your computer at night (or every other night) and make sure you don't leave it plugged in for a long time (only charge until it is 100% then unplug).
These are two of the most important things towards ensuring significant battery life.
Hope that helps!
Dec 13, 2011 | Apple MacBook Pro Laptop Computer with...
My MacBook Pro shows the message "Not Charging"
It could be either. Your best bet is to just take it to Apple and let them run a battery/adapter tester. That'll verify everything. Otherwise you can use a different battery and see if the same thing happens.
Jun 16, 2011 | Apple MacBook Pro Notebook
When I plug the charger into my macbook pro "intel duo" the charger light is green, but turns oranges after several seconds
it means its charging hte battery , when it turns green again it means its completly charged , hope this helps in some way.
Dec 03, 2009 | Apple MacBook Pro Laptop Computer with...
Unexpected shutdown with fresh battery ...only cycled 23 times so far. Mac shuts down after about 3 minutes....then shuts down on boot sequence after that. No warning...just shuts down instantly. Macbook...
"Shuts down instantly without warning" is the hallmark of a faulty battery. "All five lights on" is meaningless, as batteries with this fault go from 100% to 0% in a finger-snap. Assuming your battery is under warranty, it should be replaced at no charge.
Nov 08, 2009 | Apple MacBook Pro Notebook
Macbook goes to sleep and doesn't wake up unless I do a hard reboot.
I have seen this caused by having a mouse plugged into mine. I have removed the mouse and touch the touchpad and it has come up from sleep.
That very well may not be your problem.
Here is the procedure that is recommend from Apple to help with the not waking from sleep problem. I included both methods as it is not clear which macbook you have. I also included the link to the article at the bottom.
The System Management Controller is an integrated circuit (computer chip) that is on the logic board of the computer. As the name implies, it is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Over time, the settings in the System Management Controller may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, not charging the battery, or not recognizing the AC Adapter, among others.
MacBook (13 inch, Late 2008), MacBook Pro (15-inch, Early 2008), and MacBook Pro (17-inch, Early 2008)
  1. If the computer is on, turn it off.
  2. Disconnect the AC adapter and remove the computer's battery.
  3. Press and hold the power button for 5 seconds and then release the button.
  4. Reconnect the battery and AC Adapter.
  5. Press the power button to restart the computer
Note: Starting with MacBook Pro (Late 2008) and MacBook (Late 2008) models, you may instead use the reset method for MacBook Air (below) to reset the SMC. All earlier models of MacBook and MacBook Pro must use the method described above, which involves removing the battery.
MacBook Air and MacBook Pro (Late 2008 and later)
  1. If the computer is on, turn it off by choosing Shutdown from the Apple () menu.
  2. Connect the power adapter to a working power source.
  3. On the built-in keyboard, press (left) Shift-Control-Option along with the power button once.
  4. Wait 5 seconds and press the power button to start the computer.
Note: You must use the keys on the left side of the built-in keyboard.
Here is the link to the article at the Apple support site.
http://support.apple.com/kb/HT1411
Aug 28, 2009 | Office Equipment & Supplies
Macbook pro unexpected shut down
After determining the battery health:
http://support.apple.com/kb/HT1519
Then calibrate the the battery:
http://support.apple.com/kb/HT1490
Apr 14, 2009 | Apple MacBook Pro Notebook
Macbook pro start up problem
First remove the battery, then plug it into your AC adapter. Hold the power button for 5 seconds or until you either hear and beep or the activity light on the front of your laptop lights up. Start up normally.
Aug 02, 2008 | Apple MacBook Pro Notebook
Apple MacBook Pro with 17" Display Logo
64 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
