Question about Samsung RSH1DBBP (19.1 cu. ft.) Side by Side Refrigerator
Samsung rsh1dbbp fridge operating correctly but leaking water from inside fridge compartment? What could be the cause?
Traced the leak, seems to be coming from around the evaporator fan. Quite a bit of ice around inside of panel but nothing major, i assume this is melting and leaking out the fridge. What do you think needs changed or checked?
SOURCE: Cooltech super xflow not circulating
hi
there is problem with x flow motor which is located inside the ref temp. assy. in frige section.this problem dosen't affect the cooling of fridge.this problem can resolved by replacing the x flow motor
yours
sandesh
Posted on Jun 01, 2008
  • 58 Answers
SOURCE: ice maker leaks inside freezer
check the water discharge hose which fills the ice maker after ice is dumped into the bin. the line is located in most cases at one end of the ice maker and allows the water to flow into a funnel like device above the ice maker mold. the hose has the diameter of a penny, it is probably misaligned with the ice maker itself/
Posted on Sep 13, 2008
localwonder
  • 6784 Answers
SOURCE: pure water dispensor leaks around the edge.
hi, this is a seal leak. its located behind the water release point. it could also be cracked, the assembly that is, but im sure its just a seal issue.
Posted on Feb 12, 2009
SOURCE: Samsung RS2534 Freezer works but fridge side isn't very cold
replace the sensor and the main board
Posted on Jun 07, 2009
  • 97 Answers
SOURCE: RS253BAWW Samsung Side fridge water leak
I would not be too alarmed about this. Most refrigeration systems will drip water off of the condenser coils while in use. This can most often be seen by cars that appear to "leak" only when the a/c is on. All that this "leakage"is is condensation. This is the same reason that window air conditioners need to have a slight downward tilt to the outside. This is also why they unfortunately, often freeze up.
If you're only noticing leakage while the refrigerator is running then I would bet even money that this is what's happening especially if the refrigerator is still staying cold. Most normally this condensation is caught in a drip pan which lets the water evaporate. However, during periods of extended use, especially with periods of high humidity i.e. the summer, sometimes the condensation is higher than what the drip pan can hold and you get leakage over the sides.
Unfortunately while this is a relatively minor problem about the only way you are going to eliminate this is to install a dehumidifier in your home, or simply tolerate it for a month or so during the summer. I would bet dollars to peso's that after mid august this won't be a problem.
One thing to note however, is that if you start to see that it is running constantly, or if you notice that it's not keeping cool, then it may be time to call in a service person. But for your particular problem I don't think that will be necessary.
Actually a pretty common concern... second time in two hours I've seen it. :D
Posted on Jul 29, 2009
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
Nov 27, 2017 | Samsung Refrigerators
A refrigerator that I bought second hand but has worked remarkedly well and still does with one exception. Is it worth fixing.
Of course it is worth fixing! This leak is cause by a defrost drain that is blocked with ice and sludge. I really can't tell you how to remove that rear panel unless you provide a model number. This problem is worse with the Samsung dual evaporators as the evaporator inside the fresh food compartment is usually the one that causes problems on those models. There are a few GE dual evaporator refrigerators also that are really a Sumsung with the GE brand name. Here is a link that may help but you need to pay close attention to the videos and focus especially on your Brand
Leaking Refrigerators
APPLIANCE 911
Aug 29, 2016 | Refrigerators
Samsung refrigerator problems
Well you will have to trace out the water line and see where leak is coming from .If you disconnect everything and pull on that water hose it would come out BUT do it slowly
Dec 22, 2017 | Samsung Refrigerators
Samsung model rsh1dbbp: fridge running at 19 degees. have cleared ice build up in lower left hand side. freeer and water ok. no ice build up in freezer
The accumulation of ice on one side indicates a refrigerant problem. Basically there is a refrigerant leak and some of the refrigerant has been lost.
A technician can repair the leak and re gas the refrigerant for you.
Apr 01, 2011 | Refrigerators
My Samsung RS253BAWW has been collecting water underneath the bottom drawer for some time now. It eventually winds up in the drip tray underneath and then runs out onto the floor. I've replaced the...
Depends if there is plastic tubing running inside fridge compartment. Shut off water to fridge. If that stops it you will have to look inside to see if there is visible plastic water tubing or if you can get to it from inside the fridge. Maybe the water line has a defect or got pinched and somehow split. Then turn on water, find leak and splice in a replacement section.
Jan 28, 2011 | Samsung RS2534 Side by Side Refrigerator
Hoover Contour refrigerator HE383TF. Water is leaking inside the fridge. It appears as a puddle under the vegetable compartment and then leaks onto the floor. I have completely defrosted and then poured...
Could be the little red stopper at the back of the fridge on the inside has come off, and this is where the water is coming from, look inside on the lower shelf and you will see a round opening which should have a red stopper in it.
Dec 30, 2010 | Hoover Refrigerators
Leaking water
the water reservoir tank could be your problem, take out the drawers and operate the dispenser and see if water is leaking from it. if so replacement of the tank is very easy
May 21, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Fridge has water in it which freezes into sheets.
see if there is a drain line going up the back if there is you should be able to take if loose to see if its stopped up
Apr 24, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung twin door fridge water leaking onto floor
I have a Samsung side by side - model RS253BAWW.
Water was leaking onto floor from main refrigerator, not freezer. It was determined to be a blocked defrost drain.
The repair technician removed the trays and food from fridge, remove the screws from the panel at back, disconnected everything and remove panel.
The stainless tray at bottom of fridge as well as panel itself had solid ice blockage.
He placed panel in sink and used something similar to a blow dryer with narrow hose on it to defrost both the panel and drain in fridge. Took him maybe 15 minutes and charged $99 total for the visit.
In future I will do this myself now that I know how but thought it may be useful information to others who are having similar problems.
Jan 09, 2009 | GE Profile PFS22 33" Artica French Door...
Samsung RSH1DBBP (19.1 cu. ft.) Side by Side Refrigerator Logo
131 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
