Question about Brother DR720 Drum Unit
How to reset brother dr720 drum unit? - Brother DR720 Drum Unit
leroyal
  • 2120 Answers
SOURCE: BROTHER 8070P
leave the door open and hold down the clear button.
Posted on Nov 25, 2008
SOURCE: dr-360 mfc drum reset
Brother MFC-7345n. DR-360 With power on and door open hold down the Clear/Back button. When asked new drum 1 for yes and 2 for no. Press 1 for yes to reset drum life
Posted on May 28, 2010
djgillstudio
  • 107 Answers
SOURCE: I just replaced the drum
hello, first did you follow instructions of reseting machine when you replaced drum, if not here is the istructions, with machine in ready state, press go button and up arrow at same time, the reset parts life comes up, use up arrow or down arrow to scroll thru to drum replacement, press the ok button when you get to drum, the machine will have drum unit ok?, press okay, machine will cycle and reset drum.
Posted on Nov 03, 2010
  • 699 Answers
SOURCE: How do I reset the
On the TN-155 toner cartridge, a mechanical 'flag gear' that will reset the counter for each individual cartridge when first 'triggered'.
After each page print, the appropriate counters are incremented regardless of toner content (that is why it is still printing 'flawlessly') and after a pre-determined count has been reached, you will get a warning to change the drum as is will then be notionally (not actually) empty.
Before you decide to reset the 'flag gear' on the drum, make sure you are not actually nearing the physical empty state ... it might be a wiser decision to purchase a refill kit which should come with instruction on how to fill and reset the 'flag gear' (this needs some dismantling of the drum cartridge) or buy a compatible or genuine toner drum cartridge.
In any case, Google 'Brother drum flag gear' for more information.
Posted on Sep 20, 2011
bduxbury
  • 3512 Answers
SOURCE: I have a brother mfc9120 ,cn after replacing drum.units I cannot reset drum as told
did you pull out the power cord and then plug in back in and turn it on.
Are you following the user manual page 178
did you press menu ,6,4
did you press up or down arrow to select correct color and then ok
Did you press 1 to reset counter
http://www.manualowl.com/m/Brother%20International/MFC-9120CN/Manual/4989
Did you replace the correct color drum according to the message given on which drum was used up ?
Posted on Feb 07, 2015
I keep getting the message, "Toner error, replace drum unit". I have a MFC Brother 8460N. Jane
Have you replaced the Drum unit? Drum unit on Brothers can be reset if copy is good and you do not want to replace. If copy bad replace Drum. Rebuilt drums work as good as original at half price.
Mar 23, 2017 | Brother MFC-8460N All-In-One Printer
Tip
How to reset drum message after replacement on brother printers
Does your brother printer or fax machine have bad printing such as dark blurry pages or your machines says replace drum then follow these instructions. When you replace the drum unit with a new one reset the drum unit counter by following the instructions below:
  1. Turn the machine’s power switch back on.
  2. Press Menu => Machine Info. => Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
on Dec 09, 2009 | Office Equipment & Supplies
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
4.To clear this error message, you need to reset the drum counter as instructed below.
5.Make sure that the machine is turned on.
6.Press Options.
To confirm you are installing a new drum, press 1.
7.When the LCD shows Accepted, close the front cover.
8.Your drum is now reset.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
I have a Brother MFC-9180, it has a DR8000 in it. The machine come up on the display saying "Change drum soon" which I have done, the new drum did not come with a page to feed into the drum. I want to...
Did you reset the drum counter?
When you replace the drum unit with a new one, you need to reset the drum unit counter by completing the following steps:
  1. Turn the the machine's power switch back on.
  4. Press OK.
  6. Press Stop/Exit.
I hope this helps.
Or Try this:
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/002800/000037/faq002837_009.html?reg=as&c=au&lang=en&prod=mfc7220_us_as
Oct 20, 2013 | Brother International Brother MFC-9180
OPC Belt reset
Sir/Madam
I suggest You watch official video In Brother Printer Official Website For Your Brother Printer Issues:
How do replace thebelt unit With Video Instruction Brother
I Hope You Resolve Your Brother Printer Issue and Brother Printer Problem By Now,
Or
In case You still need Brother Printer Help assistance Then I suggest You Follow Us On For:
Brother Printer Support
Nov 07, 2012 | Brother OEM Brother OP4CL OPC Drum Belt...
HOW TO REMOVE DRUM ERROR IN BROTHER HL2140 PRINTER
Need to replace drum and reset the counter
(Essentially the cartridge/drum unit should not be in the printer when you reset it)
1) Open front door
2) Remove the cartridge/drum unit
3) Hold down front button until all lights come on
4) Put cartridge/drum unit back in
5) Close the front door
The Drum life should be reset.
Jul 07, 2011 | Brother HL 2140 Laser Printer
Replace drum, still says replace the drum and now it won't print.
  1. Turn the the machine’s power switch back on.
  4. Press OK.
  6. Press Stop/Exit.
I hope this helps.
(if you did the reset, you may need to talk to Brother Support. I'm assuming you used a Brother drum and only handled it by the handles.)
May 12, 2010 | Brother MFC-9440CN Laser Printer
Brother Intellifax 2920 / How to reset Drum Life ?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Aug 18, 2008 | Brother FAX-2920 Plain Paper Laser
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
Brother DR720 Drum Unit Logo
390 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
