Question about Hunter Ceiling Fan Light Remote Control
My transmitter light stays on after I changed the battery, now nothing works. Not sure what the problem is now
Transmitter sku#175-776 used with receiver model 7067R. fan is a Hunter
SOURCE: Hunter ceiling fan (model no. 25736) and light not starting
Home Depot sells universal remote systems (transmitter and receiver) for around $30 (in Delaware & Pennsylvania) -- don't know price in Chicago).
I'd just replace it. Hunter may be correct that they are the only source for the receiver, but if you get a new transmitter as well, you don't need their receiver. The labor is the same either way.
Charlie
Posted on Aug 21, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
SOURCE: Hunter fan model 25706 both the lights & fan have stopped working
Hello, I am not an electrician. I know you mentioned electricity is going to the fan and I read the other gentleman's answer if the motor component goes it bares consequence on the light working. It's plausible the motor went causing the light not to work. However I wondered if the wall switch went bad. I would change the wall switch and see if that is the culprit.
Posted on Oct 06, 2010
  • 6 Answers
SOURCE: Hunter ceiling fan 52 ",
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
Posted on May 21, 2011
  • 3640 Answers
SOURCE: Where can we purchase a transmitter/receiver kit
hunter technical support 1-888-830-1326- they will be able to help. have a good day !!
Posted on Jun 25, 2011
How to program remote control sku#33201048
I don't know what type you have but most have 4 dip switches in the transmitter & receiver. The dip switches inside the transmitter will be near the battery. Match the settings to the dip switches in the receiver.
Aug 11, 2015 | Televison & Video
My Ford Focus car doesn't centrally lock anymore, I have to use the key. It's not the fob battery because I changed it.
Sure you did put in a new battery? sure you did insert it correct? not the other way around? sure you did use the correct battery? like CR23 or AAA?
Sure all contacts in the battery compartment and on the battery are clean and shiny?
just a few things you could check.
Feb 09, 2015 | Ford Focus Cars & Trucks
Standby power does not work
The question is confusing. What did you replace the battery in, the battery back up power supply or the transmitter? The 300MC is just the transmitter and changing that battery has nothing to do with whether the main power unit will function if you unplug it. Now, if you replaced the large battery in the opener itself, it needs to fully charge before it will function properly so give it about 24 hours to charge with the power cord plugged in and then try again. It should work IF you attached the wires to the CORRECT terminals on the battery, positive to positive and negative to negative. If you did not, reverse them, allow the battery to charge 24 hours plugged in and try again. If you installed it in reverse there is a chance you fried the circuit board and that means you will not be able to use the backup feature although the opener may function normally without it.
Sep 14, 2014 | liftmaster Chamberlain Garage Door Opener...
My rc939 wont work unless right next to receiver.
Your description sounds similar to the problem ceiling fan owners have with their RF remotes. Try disconnecting the power to the pool light (at the breaker), pausing, and reconnecting power. Try remote operation. If nothing changes, reprogram the transmitter to the original setting and repeat the previous test. If nothing changes, the transmitter may have sharply reduced power output or the receiver may be defective.
Jun 21, 2014 | Intermatic RC939 3 Channel Radio...
Remote for ceiling fan light stays on
Sounds like you need a new transmitter. The light is a battery indicator light.
Mar 06, 2014 | Savoy House Dryers
Got my brand new hobby zone champ yesterday and it will not work, charged up the battery instailed the AA batteries into controler. turn radio on red light comes on instail battery on the air plane, you...
Remote transmitter got the problem.
If that is brand new it must have a warranty, return it to the store you bought it and test flight it in front of you before you get back home.
Hope that helps.
Sep 21, 2011 | Hobby Zone Champ RTF
My mouse does nothing the lights are on but there's no one home
you need to reset the transmitter receiver and the item you changed the battery , the button to reset the mouse and the keyboard is on the bottom and you can use a pencil or pen tip to push the button
first push the transceiver and then push the mouse, good strong batteries are the best.
Mar 31, 2009 | Logitech Cordless Mouse
Wireless keyboard won't work
Check the cabling from transmitter unit to the back of your pc, unplug and plug the cable back in, perhaps to another USB port. When you do the connect button I have always down the transmitter first and then the device, like they keyboard or mouse. Make sure the batteries you used work. If you have another computer you could try it as a test.
Jan 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
No connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Dec 08, 2007 | Universal Remote Control Hampton Bay...
Akg sr 60
help me please akg sr60 , when torn on just mute
Dec 05, 2007 | Lands Phones
Dryers Logo
42 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
