Question about Asko W6441 Front Load Washer
ASKO W6561 Machine works on all parts of programme when put on separately but wont move from the main wash to rinse programme - it just gets to 1 minute left on main wash programme and keeps on the main wash. If you then put on the rinse/spin prgramme it all works fine - it just doesn't move on automatically. Any ideas? I assume it must be something wrong with the computer.
  • 16 Answers
SOURCE: Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Posted on Feb 08, 2008
  • 3 Answers
SOURCE: Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
Posted on Jan 21, 2008
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Posted on May 16, 2009
SOURCE: asko 10625 will not spin
it is probably the belt, take off the back of the machine and look at the black rubber belt that spins the cleaning drum. The belts break after about 5 years, you can get a replacement belt at you local Asko dealer, I recall that is was pretty easy to change, like doing a bike chain, Talk to you Asko dealer about how to change it.
Posted on Jul 13, 2009
  • 228 Answers
SOURCE: The water does not cutoff during rinse cycles
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Posted on Feb 17, 2010
The machine seems to be jumping programme, its missing the main wash and going straight to rinse. Also the conditioner is not being dispensed.
The machine seems to be jumping programme, its missing the main wash and going straight to rinse. Also the conditioner is not being dispensed. This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 23, 2011 | Washing Machines
Whirlpool AWM1019 wahing machine - what does AH code mean on display. Will do all the right things but wont move on ie wash and drain but then wont rinse. On start of any programme starts to fill then AH...
Hi! I checked both the inlet pipe and the rinse drain pipe. Both are fine. What next. The machine gets to 26 and then starts beeping. It is driving me absolutely crazy!!
Jan 23, 2011 | Whirlpool Washing Machines
My washing machine has stopped with 1 minute left on theprogrammeand the key symbol showing. It will not complete and I cannot clear it. Can you advise what I cando. I have already tried switching it off...
hello. see if it will empty there a few reasons why this could have happend. if the pump and drain hose are blocked it wont go on to the next cycle. the belt could have snaped try and select another programme see if it moves if don't the programme has a fault also make sure you've got water comming in if it wont rinse properly it wont go to the next cycle hope it helps get back to me if don't work
regards
shaun
Jan 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
My asko regardless of selected wash program stops after the main wash, it will drain the water, but then not start the rinse cycles. The washing machine will allow you to open the door. I thought it was...
When your rinse cycle does not work it is your outlet filter that is clogged. If this is a front loader the small door is in the bottom front side of machine. Be prepared for some water to come out when u open the door. Unscrew and clean out filter and refit.
Also please note
with the Asko there are several possible things that can interupt the cycle either during wash or drain/spin. Have you checked the pump insert/button trap for debris or obstruction of any kind ? ( below main door to the left ) Are you using "he" ( lo-sudsing ) detergent ? Does the machine provide any error code, i.e. If it's a mechanical timer model does it stop at "C" or "S" or if electronic a symbol in the display ? Will it complete a cycle without any items in the basket ( empty ) ? Will the unit rotate in both directions and will it spin if you try both parts of that specific cycle ? This will help determine if the problem is with the drive motor brushes.
Nov 29, 2010 | Asko W6021 Front Load Washer
How much for the repair manual and trouble shooting guide for my W6021 asko asea front loader, it will not heat, but the heater is good!
Hi.
The thermistor is located near to the heating element(pt.40) and motor(pt.6). The thermistor/holder assembly is part 31/31in picture below:
To get the full part manual click here. The assembly is at pages 4/5.
Here the part.
To test the thermistor remove it from circuit and read Ohms at its terminals. If the thermistor is good it must read zero or very low impedance. If it reads open, then it is broken.
If this solution was helpful, then please do not forget to accept the solution. Your feedback is important to us.
Regards.
Sep 14, 2010 | Asko W6021 Front Load Washer
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Washing machine wont take fabric conditioner on rinse programme
Washing machine wont take fabric conditioner on rinse programme, might be the soap drawer blocked, This video will show you how to keep your soap draw clear and how to service the parts.
a 4 THUMBS rating is appreciated for answering your FREE question..
Mar 28, 2010 | Washing Machines
Programme gets stuck on wash cycle
Most likely a defective door switch.
Mar 02, 2009 | Washing Machines
Baumatic btwm4 washing machine wont rinse and empty
If it wont empty its either a blocked pump/or filter. If it won't move on, heating element
Jul 11, 2007 | Baumatic BTWM4 Front Load Washer
Asko W6441 Front Load Washer Logo
142 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
