Question about Canon NP 6050 Copier
"E212" Lens problem (sensor, motor) - Canon NP 6050 Copier
  • Canon Expert
  • 1,326 Answers
You have a very old copier..... Try taking the copy board glass off and the lens cover (black box) off. Try to move the lens with your hand, will it move? Move it out of HP and turn the power ON. Will the lens move, if so look where it stops.... I believe there is a drive gear that may of cracked... You have to watch were it stop moving....Good Luck
Posted on Jan 16, 2013
When you turn the printer on the number E212 will appear and the printer says Switch the power off and on again. I did that several times getting the same reply. There is no manual with the printer for...
  1. Remove the glass
  2. check the Lens Y home position sensor (clean it properly), or replace it
  3. check the Lens Y Motor
if you change the sensor and the error code still, you need to change the Lens Y motor. this is the picture of the Lens Y Motor and Lens Home position Sensor (good luck) mabroukmedal_35.jpg
Dec 10, 2010 | Canon NP 6230 Copier
Tip
ERROR codes Canon 6230
Canon 6230 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controllerE711 DC controller E712 Document feeder IC failure. E716 DC controller. Sorter. E800 Auto power off function (DC controller) E901 Pedistal motor. E902 Jogger side plate sensor or motor.
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 6035
Canon 6035 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controller
What's the mining of error 212?
E212 : fault in lens Y direction drive system check the sensor clean it or replace the motor:
Dec 05, 2010 | Canon NP 6230 Copier
Code error E212, with 3 options: Command card Initial detector Moving device somethig like that
E212: problem with the optical section
  1. Home position sensor is defective
  2. Motor Lens move iis defective
  3. Control board is defective
Oct 16, 2010 | Canon NP 6551 Black and White Copier
Tip
ERROR codesCanon 6030
Canon 6030 E000 Fuser did not heat up E001 Fuser temperature too high E002 Fuser temperature not rising at correct pace E003 Fuser temperature drops E004 SSR shorted E210 Lens home problem E212 Lens home problem E220 Exposure lamp problem E224 Blank shutter home problem E240 DC controller or composite power supply problem E400 Data communication problem E401 Pickup motor problem E402 Belt motor problem E403 Feeder motor E404 Delivery motor E411 Document detect sensor E500 Communication problem with copier E510 Feeder motor E530 Home sensor E531 Staple swing sensor problem E540 Bin shift motor rotation problem E541 Bin motor E710 DC controller E711 Document feeder IC failure E716 Cassette feed IC failure E800 Auto power-off circuit problem E901 Cassette feed motor E902 Paper guide home sensor problem
Have an error code on Imagerunner 105 of E0005f2-001. Anyone know what it is and/or how to resolve. Thanks!
E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire E002 Fuser temperature not rising at correct pace, same possibilities as E000 E003 Fuser temperature drops. Same as E000 E004 Fuser problem: AC driver, SSR bad, wire shorted E005 Fuser cleaning web, or problem with sensor, lever or connector. Service mode 6 is the probably reset for this E006 Fuser feed connector E010 Drive problem. Main motor, gears, etc E013 Waste toner drive problem, or waste toner sensor switch has been actuated too many times E015 Pickup motor power supply. Could be bad motor or motor board, or DC controller E020 Problem with developer unit, toner hopper, hopper motor, connection, sensor or DC controller E030 Total counter E031 Option counter or total counter E050 Holding tray (duplex) home position sensor motor or board E051 Holding tray (duplex) home sensor motor or board E202 Panel locked up, but might be no Код ошибки, scan motor problem E203 Scan problem or scan sensor E204 Scan problem or scan sensor E210 Lens sensor or motor problem E212 Lens sensor or motor problem E213 Scan lock sensor or lock solenoid E220 Exposure lamp regulator board E240 DC controller or composite power supply problem E243 DC controller E400 RDF to copier communication problem E401 RDF pickup motor or pickup sensor E402 RDF belt motor or pulse sensor E403 RDF feed motor or pulse sensor E411 RDF tray sensor or registration sensor E500 Sorter main board or communication with copier E510 Sorter feed motor E522 Sorter push bar motor
Jan 13, 2010 | Canon imageRUNNER 105 Copier
Canon NP6050 E212 -lense problem
change the small gear located (inside in lens drive assambly motor)
Feb 02, 2009 | Canon NP 6551 Black and White Copier
E212 Error code
"E212" Lens problem (sensor, motor)lift document feeder and look inside. is the lens stuck? when turned on it goes back and forth to check where it is
Aug 11, 2008 | Canon NP 6545 Copier
Problem with my copier
Mesin Saya 6035 Error 224 gimana atasinya
Jun 27, 2007 | Canon NP 6035 Copier
Canon NP 6050 Copier Logo
old marine
old marine
