Question about AOC 2236VW 21" LCD Monitor
Goes to sleep and won't wake up - AOC 2236VW 21" LCD Monitor
My kobo is in sleep mode and won't wake up
Turn it off by pressing and holding the power button for 5-8 seconds. Restart it.
When it's up. Update the video driver. You can find the driver in the manufacturer's website. However, if you want to cover all possible driver-related issues like what you are currently experiencing then use RadarSync.
I hope this helps!
David
Apr 30, 2013 | Computers & Internet
Asus laptop won't wake up
please provide what model this is, different series has different solutions.
Mar 26, 2013 | ASUS 15.6" Laptop - 4GB Memory - 500GB...
Dell d520 hibernates, won't wake up
When you get access, go into power options, select hibernate top right, and uncheck the box to the left to disable it, this will free up more disc space and get rid of microsoft worst idea.
Jul 20, 2012 | Dell Latitude D520 Notebook
I just added a LCD monitor to my eMachines ET1331G desktop computer. Everything worked fine until I left it on for a day. The computer went into sleep mode and now I can't get it to wake up. I've trie
You should be able to just press the main system unit power button to wake up your 'sleeping' computer which will then resume your Windows desktop and bring you back to the Login panel if you have a password set for your account.
Dec 29, 2011 | eMachines D Computers & Internet
My HP w2007 has started clicking to Monitor Going to Sleep and then going blank. I have never known how to wake it up so I have to turn the whole computer off and restart. HELP
Hey there, Normally simply pressing a random key on your keyboard or moving your mouse should wake it up, if it doesn't though I think the easiest way to solve this is to simply turn off the sleep mode after x amount of time.
If you have windows 7, press the start button and type in "power options", go ahead and open power options and there you will be able to set the time it takes before your PC shuts down, and you can also set it to never.
If you still wish to use this feature but just want to be able to it's a bit tricky and it won't even work for all PCs but if the keyboard waking isn't working, then it's probably because your pc does have this feature. When your PC is off, boot it up again and enter the bios by pressing F10 i believe it is for HP. And somewhere you should be able to set which devices are allowed to wake up your computer, all devices are probably disabled now, so go ahead and enable the keyboard to wake up your computer. Now save and exit, and the next time your PC goes to sleep mode you should be able to wake it up by pressing a key on your keyboard.
I hope I was able to assist. If I was, please don't forget to rate this solution.
Jul 28, 2011 | HP Pavilion F1523 15" LCD Monitor
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
AOC 2236VW 21" LCD Monitor Logo
18 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
