Question about Pride Mobility Products Pride Mobility Maxima 4 Wheel Hd Scooter with 55AH Battery & Charger + Flat Free Tires 22x18 Hi Back Deluxe Fabric Seat
Scooter stops after about 3 mile as if battery dead
  • Pride Mobili... Master
  • 1,263 Answers
Hi, okay now does this happening every time ? or is the distance variable ?
check the batteries are fully charged, if possible check the batteries with a electrical meter when it stops again , insert the probes in the charger socket the outside ones , the middle on you can ignore , check the voltage , below 23 or 24 volts this means that once you start going again the voltage will drop causing the controller to cut out , they normally cut out at about 18 volts .
Satisfied that's okay now the brake could be breaking down ? do you hear it click when going along ?
At worse your controller could be breaking down
Regards
Posted on Jan 20, 2013
My piaggio MP3 3 wheeled scooter won't start after I stopped it thinking starter fuse
Is the battery dead, they do just go open circuit with not warning, very common in compact batteries. Check the voltage at the battery.
Sep 08, 2016 | Piaggio Motorcycles
I have a pre-used mobility scooter. It suddenly stopped dead so hard I slipped forward on my seat. Does this sound electrical? surely if it was flat batteries I would have slowed to a stop? thanks Deb
It sounds like it did an emergency stop. any beeps or flash codes.
Check your user manual for possible causes.
If the batteries do go flat, they get to a certain voltage level and the scooter cuts out for safety reasons.
Apr 02, 2015 | Health & Beauty
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
Feb 07, 2015 | Razor E100 Electric Scooter
Hi moves foeward & reverse approx 6 feet stops dead ?
It can be any number of things.
1. Batteries are bad. Just because they are new, does not make them good or batteries you placed in the scooter are a lower (a.h.) than what is recommended by manufacturer.
2. short in the front/rear harness.
3. short in console.
4. park brake issue.
5. Thermal rollback.
It is an issue that a Technician should look at.
Aug 29, 2014 | Pride Mobility Hurricane Personal Mobility...
How can I fix This problem. after about 1.5 miles the scooter comes steadily to a stop. waiting for a few minutes it will go again Ok.
The motor is overheating. The service manual will tell you how to test. Pride has a service manual you can download from their website.
May 20, 2014 | Pride Go-Go Ultra X 4-Wheel
Scooter problems
Hi ,then there must be a broken connection link the batteries ?
Regards
Rob
www.gewizrepairs.co.uk
Feb 08, 2014 | TRX Scooter - 3 Wheel Electric Scooter -...
I have a 3 wheel falcon. Its wonderful but all of a sudden I'm going along and it stops short for no reason
When the failure occurs does a light flash on the tiller. If you see a flashing light count the number of flashes get back to me, your controller has found something wrong. When the scooter stops short do any lights light or is the scooter completely dead. Take the batteries to a battery shop.Have them load test them. I have a Rascal 600t my batteries will put out 500 cranking amps. If the batteries test good have the shop charge them up for you. Does it work right now. Yes, check your charger. No, check the freewheel mechanism when its in freewheel mode it electrically disconnects the motor. Well this thing gets wet at times i have to WD40 mine to get it to work right. The last thing to do is but the back end up,run it, while wiggling wires. Pay particular attention to connectors. The toggle switch in the tiller often gets intermittent. On my scooter the plugs on my get loose causing my scooter to fault out or to stall.Hope this helps
Jun 01, 2012 | Pride Sonic 3 Wheel Portable Scooter
Motor stopped dead during slow turn on grass, neons light up,but it immediatly shuts down again lights ok motor stays dead.
Hi roybruce
Sounds exactly like a brake problem.
To check this run the scooter as far as it will go untill it shuts down or 10 minutes which ever occurs first.
Then being careful not to get burned touch very carefully with your finger the brake. Located at the end of your motor attached to the free wheel lever.
This could be very hot so be careful.
If the brake or motor is hot replace the brake. If the brake is cool to the touch you could have low voltage. Have your batteries load tested to make sure. Replace batteries if needed.
Good Luck
Tim
May 03, 2011 | Invacare Supply Group Invacare Scooter...
Why does scooter start then stop suddenly
battery dead or dieing , charge it up and if the problem is still there replace the batteries
May 01, 2010 | Lynx L-3X Compact Scooter
Pride Mobility Products Pride Mobility Maxima 4 Wheel Hd Scooter with 55AH Battery & Charger + Flat Free Tires 22x18 Hi Back Deluxe Fabric Seat Logo
78 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
