Question about Dell Latitude E4310 Laptop
Spacebar seems stuck/misfires
After computer has been booted up for a short time, the spacebar appears to "stick", even if I haven't pressed the spacebar at all. This happens when docked open, docked closed and undocked.
    Problem Solver:
  • 17 Answers
It is most likely a cleanliness issue.
Most of the time when a key 'sticks' its because its either broken, or there's some sort of dirt under it, making it malfunction.
A quick and easy way to try to fix this is to buy the keyboard cleaner at a wal-mart, target, kmart, best buy, etc...Its an aerosol that you spray like WD40 into the cracks between the keys to remove dust and such, it does not leave a residue and is basically just blowing air into the cracks.
Alternatively, you can take a water bottle, empty the water (and make sure its completely dry) and then poke a small hole in the lid, then stick a straw (I suggest a thin straw, like they use for Gin and Tonics and restaurants.) into the hole and hold it in place. Then put the straw down by the key and just squeeze the bottle hard and fast to shoot air down into the crack.
If its still failing after that, you'll probably want to take the key off and manually clean it. To do this, look up your computer on the company's website and look for the maintenance manual (or if you still have all of your computer's documentation, you can look there). It should tell you how to safely remove keys and then replace them.
That's all I got, hope it helps. If you still have problems, then I suggest getting an external keyboard (you can pick them up at a Goodwill for five bucks tops) and use that to see if its an issue with your computer, or the keyboard.
Posted on Jan 15, 2013
Ap12
  • 107 Answers
SOURCE: spacebar on keyboard not working
turn the keyboard over and tap the bottom. You may have a piece of fodder under it.
Posted on Jan 04, 2008
  • 3940 Answers
SOURCE: Dell D630 Docking Station
First option if using Windows XP is to undock the system then delete the Docked hardware profile in Device Manager, Hardware Tab, Hardware Profiles. Once deleted, power off, dock the system, boot, Profile recreated.
Posted on Jun 29, 2009
  • 150 Answers
SOURCE: Laptop screen does not turnon after I successfully
Try your power options, it may be set to hybernate or turn off after a certain length of time. Change the setting for the display to never turn off.
Posted on Sep 02, 2009
  • 309 Answers
SOURCE: dell inspiron 6400 faulty spacebar?
You need to have the keyboard replaced. If you can't get it fixed locally, contact me for shipping information, I fix these kinds of problems a lot.
Posted on Jan 05, 2010
  • 38 Answers
SOURCE: My windows xp wont boot on my dell latitude d600.
Go into system BIOS and see if the computer is configured as it should be. If you computer BIOS settings are in the default mode, your BIOS battery may need to be replaced. Go to the BIOS and make all the settings as required. Then shut down the system completely and do a cold boot restart. See if the BIOS settings are still intact. Hope this helps.
Posted on Apr 09, 2010
Logitech 350 spacebar sticking
Make your day easier-order a $30 replacement from Staples.
Jul 16, 2014 | Logitech Internet 350 USB Keyboard
Spacebar somewhat jammed
There may be something stuck under the bar like a crumb of biscuit or a bit of grit that stops the bar from free movement.
Feb 07, 2014 | ASUS Computers & Internet
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Jan 19, 2011 | Gateway 2520915 Keyboard
I recently have been having problems w/certain keys on my Apple Keyboard with Numeric Keypad. I used some wipes to clean it the other day...and almost immediately the spacebar & a lot of of other keys...
some of the fluid from the wipes must have short circuited the keyboard! you may have to invest in a new keyboard and keep it away from water based wipes this time!
May 04, 2010 | Apple Macintosh Keyboard
When i press spacebar my search results page appears
Keyboard replacement solved the problem. In my case it was a faulty Logitech keyboard. It seems that Spacebar is acting as F3 and Space the same time.
Feb 04, 2010 | Logitech 967437-0403 Keyboard
SPACEBAR WILL NOT SPACE
Inspect the spacebar paralell guide wire. When depressing the spacebar on the right or left side extreme the spacebar other side should travel down at the same time. If not the spacebar will not actuate the electronic keyswitch under the spacebar. Most likely, the keyswitch is defective and requires replacement.
Oct 12, 2009 | Olympia Mastertype 3 Typewriter
Keyboard spacebar sticking
Just solved it, after a bit of tinkering...
the prongs of the floating plastic frame need to sit inside the clips of the spacebar key, you can't just clip it back on with the prongs either up or down. It's fiddly, you need a paperclip or thin screwdriver to do it, but it's stopped the sticking problem.
Oct 25, 2008 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Spacebar stuck
Ok ya gonna haveta get a New Keyboard for ya Lappy... they are relatively easy to replace they are an "All-in-one" thing and usually have a ribbon cable that plugs into the motherboard... ya could disconnect it for now and plug in an external keyboard to ya Lappy to get ya going... But be gentle getting the old keyboard out.. maybe even go online and get a Manual to see how it comes apart.. else it's off to the shop. GL
Jul 29, 2008 | Compaq Presario Notebook
Dell Latitude E4310 Laptop Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
