Question about Storagetek L80 DLT Tape Drive
Service required led blinking
In my Storegtek L80 DLT Library "service required" LED is blinking all the time. I have tried cleaning all the tape drives using cleaning catridges. what I have to do to make it right. Pls answer me immed. Regards Hari
You will need to get a StorageTek engineer out onsite to have a look at the problem, the light will not dissapear until resetted by a engineer.
Posted on Jul 26, 2007
SOURCE:
I was trying to backup my server while exchanging DLT tapes, the tape in use light stayed on and the serve would then alternate to four flashing lights and then back to flashing "Tape In Use...
Try the following action to resovle your issue:
1. Run the Drive Assessment Test in HP StorageWorks Library and Tape Tools.
CAUTION: Running the Drive Assessment Test overwrites the tape. If it is not possible to
overwrite the tape, run the logs-based Device Analysis Test instead.
2. Check the backup logs.
3. Verify that a supported configuration is being used.
4. Check for media damage:
o Incorrect label placement
o Broken, missing, or loose leader pin
o Damaged cartridge seam
o Usage in incorrect environment
5. Check for software issues:
a. Check the backup software.
b. Check that virus scanning software is not scheduled to run at the same time as the back-up.
6. Verify that a tape can be formatted.
Tape Error LED is flashing:
1. Reload the suspect tape. If the Tape Error LED stops flashing, the problem has cleared.
2. Load a new or known good tape. If the Tape Error LED stops flashing, the problem has cleared.
3. Reload the suspect tape. If the Tape Error LED flashes, discard the suspect media as faulty.
From my experience, most of the time it is a bad tape, using a new tape usually solves the problem. If after inserting a new tape and the problem exist, you may need to update your firmware/backup software.
Good Luck
C2Solutions
Jan 13, 2011 | HP Compaq ProLiant ML350 G3 Server
Tip
HP Tape Library Maintenance
Do Not clean the tape drives in a HP tape library unless and until the cleaning LED blinks. It is strictly recommended by HP.
Also do not fill all the slots with media, always leave 2 slots free apart from the male slots. This helps to avoid media struck in the library.
on Mar 21, 2010 | Computers & Internet
HP StorageWorks 1/8 Tape Autoloader SDLT 320 - tape library - Super DLT - SCSI Displayed Error! Code: A0 When you try to import or export are displayed error code 90
The library picker arm cannot move to the home position. There could be something blocking it. Try the Reset option from the Configuration menu. This is detailed in the library user guide.
Jan 11, 2011 | Quantum ValueLoader SDLT 320 Super DLT...
DLT-S4 tape is stuck in Quantum drive all 3 LEDs flashing together. Eject tape button does not work, how to get the tape out?
Hello, on some of the older DLT drives, if you press the 'eject' button several times the drive firmware attempts an unload operation. I'm not sure of the number of times you have to press it though...try pressing it in and releasing it 3 times (in quick succession). If that doesn't do anything, try 7 times.
It's worth a try!
Regards
nicam49
Nov 01, 2010 | Quantum DLT-S4 DLT Tape Drive
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
What can cause a 2680 Error code on a Quantum M1500 tape system?
Drive 1 has reported a hardware error, Check with your drive 1 is it blinking with any amber led.
Dec 15, 2009 | Quantum M1500 (m1-2/21-s6l) Super DLT Tape...
My Storegtek L80 can't recognize all of its tape drives
That thing required a SCSI terminator pack doesn't it.
If so, is it working properly.
I've had those things go out on me before leaving me to pull my hair out many times.
Jun 14, 2008 | Storagetek L80 DLT Tape Drive
Quantum ATL SuperLoader
If you cannot physically load a tape into the drive it is a hardware problem and the drive requires service. It is not a software problem.
Of course, the library could already have the maximum tapes it can hold. If this is the case then eject a tape from the library to make room for the tape you want to add.
I hope this helps.
Apr 17, 2008 | Quantum ValueLoader SDLT 320 Super DLT...
DLT VS160
red LED blinkin suggests the drive is reporting some sort of internal error, if you can see no obvuios problem (something jammed in the mechanism, ect ect) take it to someone who can dismantle it and check for dry joints, jamming things like that
Dec 06, 2007 | Dell PowerVault 110T DLT VS160 DLT Tape...
StorageTek L40- Service required Led Blinking always.
Remove the server connection from the library.
power on the library, follow the display in the front panel. The library will do some checks. Note where it fails. Press the select button, it will display the some code message. With the error code refer the manual.
Sep 18, 2007 | Storagetek L40 DLT Tape Drive
Storagetek L80 DLT Tape Drive Logo
333 people viewed this question
Top Storagetek Computers & Internet Experts
Ekse
Alun Cox
Are you a Storagetek Computer and Internet Expert? Answer questions, earn points and help others
