Philips 37PF7531D/10 37 in. LCD Television Logo
sally Posted on Jan 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
37PF7531D gone back to factory settings
Reset its self, lost controller
Level 3:
Top Expert:
  • Philips Master 76,851 Answers
  • Posted on Jan 15, 2013
Philips Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986317
Points
237762
Check and replace its main system memory IC. It is faulty.
Do i plug hte wireless rooter direct into my computer to reset password
You must log into the admin screen on the router (via a web browser connection, not being directly cabled). If you don't have or have lost this password to log into this web console for the router, you'll need to wipe the device completely and start over. Typically there is a reset button on the back of any wireless router to set it back to factory reset. Find the button, press and hold for 15 seconds or more and let go. All settings on the wireless router will be gone.
Lost my aim tv remote and the tv is stuck on usb settings and it switches off by its self leaving the red light flashing can I reset it and how
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
1helpful
The point from which you type is stuck in the middle and I cannot get it to realign to the left hand side
The Olympia 330 is the same as the Nakajima AE-830. if you have lost your operators manual you can download the Nakajima version from WWW.NADIST.COM.
First just try resetting your tabs. If that dosn't work, you can reset to factory settings by doing the following...
SwitchPower OFF. While holding down the MARGIN RELEASE KEY switch the power back on...the machine will start printing a self-test page...let it run for about 10secs then switch the machine back OFF. wAIT 10 SECS then switch back On and the unit should be back to factory default settings. ** Note..this will also clear anything in memory.
My phone switched itself off and when i switched it on again all of my contacts had gone from my phone
Sounds like your phone was reset back to its factory settings, aka a hard reset was done on the phone, unless you backed up your contacts, you have lost all the contacts on the phone and there is nothing you can do, sorry.
My monitor is brighter on the lower left side than on the rest of the display?
NOTE : steps below are only for a Dell monitor
There could be two reasons for the same,
1. The monitor settings are bad or
2. The monitor has gone bad.
Request you to disconnect the monitor signal cable from the back of the computer (cable with the blue jack)
A self test feature check would run on the screen. If the screen is bright in the feature check . The monitor has gone bad and needs a replacement.
If the screen appears ok in the self test . Press the menu button on the monitor and select factory reset.
Thanks
Proton
1helpful
HP desktop- had virus- reset computer, now no sound
Hi , to install sound driver.
open the control panel ,install sound driver and also check device driver view if the sound connect to computer.
1helpful
"check factor data" using self focus
Hi.
Not at all familiar with your tv but this sort of message comes up if you have altered eeprom settings while in engineers mode.
To put it right you will need the work shop manual to know how to reset the settings.
Maybe A tech on these forums can help you out.
http://dysonmanuals.llc.nu/
Chris..
2helpful
2answers
Lost password for wireless connection
Reset your router using the reset button. That will put everything back to factory settings.
Wharfedale dvd 400f
I had this problem, the only way I could reset it is to, set restore to factory setting, I did this and have now lost output. I have never had so much trouble setting up a dvd.
Glen
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
