Question about KitchenAid KFIS20XVMS 20 french door counter depth refrigerator
KFIS20XVMS2 dispenser pad or actuator is now sticking and making a clicking noise when pressed for water or ice. thought maybe something sticky (juice or pop) may have splashed onto the part, cleaned but getting worse, thoughts?
SOURCE: Noisy ice dispenser door
It could be something as simple as you might need to manually defrost your ice maker. There is a auger that moves the ice forward that could be iced up. Try that first.
Posted on Jun 30, 2007
  • 23 Answers
SOURCE: Water/Ice Dispenser Mixed Up
Do you have separate levers for Ice and water, or do you have one lever and then you slide a switch to either one and then push the one lever.
Posted on Dec 07, 2007
SOURCE: Not dispensing Ice or Water thru door
Found someone that was not going to charge me money for advice.
Posted on Sep 23, 2008
freetek
  • 5568 Answers
SOURCE: ICE MAKER WONT MAKE ICE
Water flow is governed by a solenoid valve which is controlled by a timer that sets the cycle for all of the icemaker functions. The timer is controlled in turn by the switch that is actuated when the bin is full. One of these three is malfunctioning and to determine which is at fault will require the removal of the icemaker mechanism (to check the switch) and possibly sheet metal on the back of the fridge.
You will also need a multimeter of some kind to check for switch operation and continuity of the solenoid coil. Adequate instruments can cost as little as $3 and in any case under $20, have digital displays and are normally accompanied by some instructions in Chinglish which are somtimes pretty entertaining.
Posted on Nov 25, 2008
milten1
  • 1304 Answers
SOURCE: kitchenaid no water, but ice
first thing i would check here is my water resivoir, on these models it has a tendency to freeze,, hit the tank and upper line with a hair dryer for several minutes then give the water a try....
barring that it may be time to change your water filter even if the sensor has not picked it up yet
Posted on Oct 26, 2009
Electrolux EI23CS55GSI - Water Dispenser Will Not Stop Running
sounds like the paddle you push to dispense the ice and water is sticking,if there's a rubber pad there try moving it to see if it frees it up,if not it looks like you have to replace the whole part 242100018 go here to see it
https://www.repairclinic.com/PartDetail/Dispenser/242100018/3513417
Jan 18, 2018 | Electrolux Refrigerators
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
LFX25970 Bottom Freezer Refrigerator This morning it began to make a clicking noise coming from the ice/water dispenser and cold air was coming down from the opening. I pushed the lever for ice and it...
You may have an issue with one or more of the following:
* icemaker
* dispenser actuator
* ice chute door assembly
* ice dispenser solenoid (if the solenoid is stuck in an open position, the ice chute door/flap would remain open allowing cold air to escape).
Contact an appliance service company.
Feb 16, 2010 | LG Refrigerators
Does not make ice, does not dispense water. Can
Sounds like the motor that controls the water flow is either broken or defective. Or the water valve is turned off.
Feb 03, 2010 | Refrigerators
For some reason the dispenser will stop working part of the time and more recently will stick on and overflow.I pulled the cover off the inside of the door and there is ice buitl up on the insulation.
You need to thaw out the ice machine and see if it works after you thaw it out if that does not fix the problem then the control arm for the ice dispenser is bent.
Nov 22, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Model JCD2389GEW - ice/water dispenser does not work. Until recently, it did not do anything on any of the settings (water, cube and crushed ice) now it crushes ice on all three settings but the door does...
We have a Jenn Air side by side, model JCD2389GEW. The ice dispensers work, the water does not. This started after I replaced the filter. I've checked and nothing is locked out. When you press the actuator pad to dispense water, you can hear a noise similar to a small pump which I assume is a solenoid attempting to open. Any ideas?
Oct 02, 2009 | Jenn-Air Refrigerators
Ice machine makes ice,does not dispense ice
Is it making any noise at all when you press the dispenser? If not check the switch on the dispenser on the front of the door, the actuator may be broke or stuck. The only way to see this is to take it apart, you will see levers and springs, push the dispenser lever and check that the switch is making contact. If you here noise when you press the dispenser like a relay clicking you may have a bad auger motor. Is the ice tray pushed all the way in? And check the freezer door light switch, that is a safety so you cant operate the ice with the door open, if the bulb is out replace it, some models are wired to read through the bulb (dont know why) Please let me know if this helps you out.
Aug 22, 2009 | GE Refrigerators
Water or ice will not stop after removing glass.
Although I don't have this problem, I took my dispenser apart tonight for a different reason. Moving the lever with the glass actuates a mechanical switch. It's a really simple mechanism. If I were you, I would check to see if that mechanical switch is sticking. Maybe someone had a glass of soda or something sticky, which splashed up there when they got ice. That could be enough to gum it up.
Taking it apart was not tough. The plastic border pulls right off. Then the assembly that has the buttons and lights on it can be removed by pushing it downward enough so that it clears the plastic holders, and then you just pull the top edge towards you. At that point I unplugged the fridge so I couild disconnect some connectors. Then 4 screws gets the whole glass switch assembly out. You should be able to inspect the mechanical switch operation at that point to see if it is sticking.
Good luck.
May 22, 2008 | GE GSH25JFR Side by Side Refrigerator
In door ice and water dispensing
sounds like the paddle is hanging up or the micro switch that the paddle actuates is sticking if you can see the micro switch spray some wd 40 on it open the door and work the paddle a few times
Feb 15, 2008 | Frigidaire FSC23F7D Side by Side...
Ice dispenser comes on by itself.
you need to replace the dispenser selector board.
Sep 03, 2007 | Frigidaire FSC23F7D Side by Side...
KitchenAid KFIS20XVMS 20 french door counter depth refrigerator Logo
67 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
