Question about Samsung HP-R5072 50 in. Plasma HDTV
Broken HDMI Port for HP-R5072
The HDMI port for our plasma is not working. Have replaced the cables still no picture. TV keeps saying checking for signal. The S Video port works fine but no HD. Can you have the HDMI port replaced?
  • Anonymous Mar 21, 2014
    picture looks brighter around the frame!
  • Samsung Master
  • 1,779 Answers
The HDMI input along with others is located on the a/v control panel of which would have to be replaced. I haven't seen an input jack yet with a part number attached for any model. I would suggest call a service center for a diagnosis.
Posted on Feb 04, 2009
Lg 42" plasma
It may be that your cable box is outputting at a resolution your TV doesn't recognise or doesn't support. Do you have any other connection you can use from your cable box to your TV to check the settings?
Nov 18, 2017 | Televison & Video
My plasma TV is not getting a signal from the hdmi cables. They worked earlier today and I have not changed them. The game system is the only component functioning now.
Tries tv unplug,replug it back like about hour later.For the tv do a resetting itself,take out the tv HDMI cable out the old HDMI hub port try plug it into another tv HDMI hub port.Should work now,still have same problems,probally needed a new HDMI cable replacement,the old HDMI cable is worn out or shorted out.
May 08, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
My tv wont connect thru hdmi any longer
If you have only been using one cable it may need to be replaced or the HDMI port on the television may be broken. Check the port and make sure it is clean and if it still dose not work speak with a local tv repair shop
Mar 05, 2011 | LG Electronics 50PK750 50 1080P Plasma...
HDMI cable was removed when TV on standby and X-box off. It was then replaced and we now have a message. "No signal. Check connection" and nothing else. Please can you suggest a fix? Have checked...
Might some how got that HDMI input port shorted?Tries tv unplug and that HDMI cable input it into another HDMI port,replug tv back about an hour later.So the tv resetting itself back to factory setting.Tv on goto tv menu,goto tv PICTURE SETTING going down to do resetting.This should resetting the whole tv Tuner signal board.These steps,should help ur tv HDMI ports functions again.
Jan 21, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic home theater
switch the HDMI cable to another HDMI port (if available).
or use and AVI/COMPONENT to make sure the device (HOME THEATHER) is working fine.
Try also another HDMI cable or hook another device into it to see how it works.
If you determine the HDMI port in not working properly, then your Mainboard is damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
May 14, 2009 | LG 50PG20 50 in. Plasma HDTV
White screen when tv turns on.
First check the wire cable your using, HDMI, AV, sure the wire cable is in good condition. Check your input/output ports, see if the tv does the same on different hook-up. For example if your getting this crazy image on HDMI, see if it happens also on Component. If so first be sure the input device such as your dvd player , cable box etc, are not defective. If your wire cables are good, and your dvd, cable box are all working properly and the tv still has this problem then its an internal problem with in the tv.
This could happen because of a component defect in the tv's interface circuit, XL/XR scan circuits, or faulty sustain circuit (primary board).
How old is your tv?
Mar 01, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Aug 04, 2008 | Insignia 42" LCD Flat-Panel HDTV
TV Flashed HDMI
check samsung web site for firmware upgrade, or use component cabling, which is HD also
Jul 29, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Can't get sound through my hdmi
Try the easisest route first - unplug and replug HDMI cable into same port or the other hdmi port on the TV. Also, make sure the Monster cable isn't HDMI 1.3 - I'm not sure the HDMI ports on this tv are fully compat with 1.3.
If that fails, go to, enter your model number, click on the verison of your model ending in /37, and click on "Software & Drivers"; click on the link that says "Firmware Upgrade - Software" - read the specs and see if it says anything about audio loss on HDMI - many Philips have issues with the HDMI ports - they are not broken, but just need a software fix. Instructions are on the same page - make sure you only transfer the .upg file, not the entire zip file to a portable memory stick.
Here are the notes I see:
Following problems are solved :
• Availability cablecard channel map.
• Improved info in the service menu.
• Improved picture quality and stability on HDMI.
• Installation of channels.
Following problem is solved :
• Issue related to intermittent video loss is solved.
Jun 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
Samsung HP-R5072 50 in. Plasma HDTV Logo
585 people viewed this question
Jerry Greenberg
Jerry Greenberg
