Question about Numark CDN95 2-Disc CD Player
Fader start Hi I have a relay closure from a mixer fader - how can I use this to fader start numark cdn-22mk4. The unit has a mini jack input on the back of it, but i can not get this to start the CD machine. Any ideas? Gary
  • 4 Answers
Hi Gary Milchar,
Have you set the player to start from fader http://www.numark.com/stuff/contentmgr/files/0/fc90d6fb8cfaeec3e6dbbe22202aabfb/file/cdn22s_refmanual.pdf? (page 12)  If so check that you have continuity across the mini jack with one end plugged into the mixer.
Happy hunting.
Posted on Feb 15, 2009
Right channel is working, but Left channel doesn't. Not speaker problem. on the mixer panel, only the right ch. signal level light is brinking.
if this is true on all right channel inputs and not just one you tried , then id look at your effects loop send jack , there is a tiny switch inside it that must reconnect the right side send back over too main right channel fader in the older units there was a switch on back that did this but in later units this function was done with a micro switch inside jack
Sep 22, 2015 | Behringer Europower PMP3000 12-Channel...
I HAVE A NUMARKKMX01 MIXER WHEN I PLUG THE RED RCA JACK IN TO THE MIXER I GET A LOUND HUM
What is plugged into your Numark mixer when this happens? Try disconnecting ALL audio inputs to your mixer, turn mixer volumes to zero and see if the hum is still present. Adjust the volume and check if the hum you mentioned returns. If it is still heard, try new cables between the mixer and amp...if not then start reconnecting inputs until the hum is heard again. It's a process of elimination but not that difficult to find the source of your problem.
Oct 31, 2012 | Numark Industries Numark DM 1200 Mixer
I can't get any sound to go through Mackie 1604-VLZ3. I've tested to insert sound to every channels and checked all button positions and nothing comes out from main output or the phones....
There is NO way to select channels to "Source"... The selections on this mixer are to send the channels to SOLO, Sub1-2 or Sub 3-4 and/or main L-R. You should have the bottom button for each channel punched down to L-R. NEVER connect ANYTHING other than an external effects unit to the INSERT jacks!!!! These jacks are combined output/input jacks with send and return on the same jack. Special insert cables are used for these. An external drum machine should be connected to a line input for one of the channels USING a TRS balanced cable. Page 28 of your user manual shows the block diagram and signal flow diagram. The trim control is the input gain control. Start with those say at 12 o'clock and advance the fader for the channel of interest...you should get signal at the main outs. MAKE SURE that the lines from the mixer to the amps are BALANCED TRS type cables... You cannot use unbalanced cables for this. The user manual explains balanced cables and what they look like. I just repaired one of these mixers that some foolish people plugged stuff into the MAIN INSERT jacks and blew out the driver that drives the MAIN insert which kills the input to the MAIN output drivers. There is one small chip between the AMAIN fader and the sub next to it and one has to remove every knob and take the unit all apart to get to it... It is a tiny surface mounted part the size of a matchhead with 8 leads... not for the faint of heart to repair. As a test of this part, you can plug a st of headphones into the RIGHT MAIN insert jack and drive audio into a channel... turn trim control up fully for the channel and the fader on full, and set the PAN control to 12 oclock and punch down the L-R button for that channel. You should hear the audio in ONLY the left ear... Now try the phones in the LEFT INSERT jack... you again should hear the audio in the left headphone only (these jacks are not stereo like the headphones). If you cannot hear anything, then likely somebody has blown that driver in your unit... It is painful and time consuming to repair this... there are hundreds of knobs to pull off and put back on... dozens of screws and cables and to get it all back together. Also make sure ALL of your interconnected equipment is powered from a SINGLE receptacle or power module. Read your user manual thoughroughly. You can get one online download if you need it.
Sep 10, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I have a Phonic Max 2500 amp and use a Numark 2 channel mixer with CDN 22 mK4 Dual CD. Just in past wekk I've been unable to fade out the track playing oin either side of the mixer (you can still hear...
If you have fader capabilities...and there is still signal "leaking" through...you may try reducing your input gain on each channel of your mixer...as well as make sure you have a good ground connection between your components.
Jun 19, 2011 | Phonic MAX 2500 Amplifier
My right channel upfader on my numark mixer is not working can this be fixed?
Yes take it to your local numark dealer and they will send it out or fix it right there. sounds like the faders blown.
Mar 15, 2011 | Nu Mark Numark Dxm06 DJ Mixer With 12...
The headphone jack broke. It is kind of pushed into the mixer. Is this repairable?
I repaired mine when that happened.... you have you unscrew all the screws on the top plare there is like 5 or 6 silver ones..Remove faders (2 volume 1 headphone) then remove the top plate. Then unscrew the the black screws on the side and front of the mixer... NOW THIS PART IS IMPORTANT..from the corners of the mixer there will be a little lifts carefully lift the top of the mixer up JUST A LITTLE BIT... have someone hold it or just rest it diagonally so you can unscrew the jack from the back MIC unless you were able to salvage the jack from the headphone if that silver and black piece are gone your going to have to borrow it from the mic... dont worry the mic will still be functional because its better set in that the headphone jack... now use the outside piece and bring the headphone component to the front where its suppose to be so you can screw the 2 back together.. then put every back together in a reverse order and you should be fine.... if you have anymore questions email me at DjAnthem222@yahoo.com
Sep 18, 2010 | Nu Mark Numark Dxm06 DJ Mixer With 12...
What lube can i use to clean numark nuvj crossfader. i'm gettin a leak while using the fader.
Usually a "leak" from one side to the other is an indication of a cracked resistance element. The fader would have to be replaced.
I lube the faders on my mixers using CRC226 availablle in the electrical dept at Home Depot. Use sparingly.
Aug 12, 2010 | Numark Nuvj DJ Video Mixer
CDMix 2 Fader Start does not work
Both decks must be on single play
regards
Jun 15, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Numark cd mix 2
Well, it's not that hard to set up. What do you need help with? If you want to know how to connect:
1) The CD units go into the back of the mixer - in the CD / LINE INPUT - Left side on CD / LINE INPUT 1 and Right side to CD / LINE INPUT 2
The output of the mixer - MASTER OUT - goes to the INPUT of your stereo, amplifier, or receiver's LINE INPUT connection.
That's it. Press PLAY on your CD players, and raise the faders/volumes, and your all ready to go.
- TWEAK AV LAB
Nov 30, 2007 | Numark Fusion 494 Complete DJ Package
Numark CDN95 2-Disc CD Player Logo
541 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
