Question about Refrigerators
Frigidaire Model LFTR1814LW4 quit cooling
The refrigerator was purchased November 2011. It has worked fine but in the last few days quit cooling. Light in fridge turns on but the compressor never seems to activate any more. Trying to figure out if I have a bad compressor or if something else is keeping it from working.
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
tech master
  • 120 Answers
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Posted on Nov 10, 2008
  • 306 Answers
SOURCE: Clicking noise coming from whirlpool refrigerator
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Jan 18, 2009
farfield
  • 462 Answers
SOURCE: Problems with Frigidaire Refrigerator not cooling
In turning it off you may have only closed the air damper. Set it to 1/2 way.
If ice or frost in the air damper area on refrigerator side you may not be defrosting the freezer coil.
Inspect from bottom looking up with a mirror and flashlight. You should have no Ice buildup frost that is even and white is normal. Feel Check the back wall mid way down to 1/4 way to bottom. Push on the wall slightly. Crunching like frost or snow behind wall is not normal. I suspect non defrosting here.
Next eliminate the inside fan motor. It has to run to push air all over the freezer and refrigerator. If this fan doesn't run the results will be only the area with the refrigeration evaporator coil will cool and it may get too cold and resemble a non defrosting situation where the air is not able to circulate because of frost build up.
Next eliminate the Ice maker and light as a source of heat. Unscrew and unplug them
Next eliminate the door gaskets from not sealing. A piece of paper set tween the door and frame and pulled across it and you feel resistance all the way and the gaskets are smooth and not warped they are OK
Next inspect the condenser fan and coil by the compressor underneath. A dirty coil here will cause diminished heat removal and possible for a partial cooling of some of the freezer.
Only after inspecting all these items and determining they are OK should you proceed with refrigerant checking. Also a person with out the ability to measure the actual amount of refrigerant being put in should be shown the door. Even with topping off (adding some) refrigerant I use a scale to determine that I do not put in too much. So if you have a friend that does this and no way to tell how much is too much.... well with all due respect your getting what you pay for.
If this helps you understand your problem and need more information please post back, I will follow up. If it helped you determine your trouble please rate me as high as you can. Thank You for using fixya and good luck.
Posted on Mar 22, 2009
Frigidaire model number FRS6R5EMB8 Not cooling
Feel the top of the compressor and tell me what you feel
Oct 09, 2015 | Frigidaire Refrigerators
Model FRT045GB
Good Morning Jr. Riojas,
I see that you are having trouble with your Frigidaire compact refrigerator, model# FRT045GB, and it not cooling. I also see that you have reset your refrigerator, by unplugging it, and it works fine for two weeks, then you have to repeat resetting it. I suggest contacting either the manufacturer or your local authorized technician for further assistance. They should be able to better assist as to why your refrigerator cools for a few weeks and then you have to unplug it for it to cool a couple more. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire 4.4 Cu. Ft. Compact...
Compressor will not start on a frigidaire refridgerator
The compressor gets power from compressor capacitor or compressor relay.On some models there is capacitor and on some there is relay.May be that relay or capacitor got shorted causing the problem.
But if that checks out ok,then its faulty compressor causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Refrigerators
Freezer not cold, temp bouncing all over the place
It can be problem with compressor or problem with temp sensor in freezer compartment.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Frigidaire Refrigerators
Frigidaire side by side Freezer only freezing top shelves, warm at the bottom
Its defrost issue.
Defrost cycle is not taking place on time or its not working at all.
repairclinic.com
partsselect.com
These will help.
Thanks,.
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
I have a Frigidaire GSI 26, ffor the last couple of days it has been making a buzzing sound that lasts about thirty seconds to a minute, today the freezer quit working. the compressor is hot, as is th
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Frigidaire refrigerator not cooling at times
Click this link below for problemRefrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
---------This will help.Thanks.
Feb 09, 2012 | Frigidaire Refrigerators
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
