Question about GE Dinamap Pro 300 Monitor
Pnet nibp fatal error
System error pnet_nibp module in fatal state
The blood pressure monitor works on my husband and not on me
If your nibp is high or you are very fluffy, the kerchoff sounds are harder to detect for cheaply built units. Sorry..portly,rotund?
Sep 25, 2014 | Samsung Health & Beauty
How do i unsubscribe from PNet?
T the bottom of each email or newsletter you receive, there should be a link at the very bottom titled "unsubscribe" it may take a few tries, but if you are still receiving them, you may have to contact them via email.
http://www.pnet.co.za/contact_jobseeker.php
Sep 09, 2014 | Google Chrome
Nibp is not recording ,
What do youmean by not recording ? Is it actually getting the pressure but not recording on paper ? If it is not getting a pressure at all , does it give an error on-screen ? (time-out etc. ) These NIBP units use a pump and there may be a leak somewhere in the line from pump to cuff . If you have another unit or any Mindray unit with NIBP , you can troubleshoot using another NIBP line . Unplug the exisiting and try another line . If not verify the cuff does not have a leak and you can run a leak test withing the unit itself . If you do not have a manual , you can get one online from Mindray or other sources to describe in detail how to run the leak test .
Jan 25, 2011 | Medical Specialties Mindray Pm9000vet...
Compaq Preario V5245eu cant get past scrolling xp window just restarts and doesn'r get anywhere have had a c000021a fatal error warning- help please Rodger
If you attempt to install a piece of hardware or software on your PC computer that is incompatible with your system, you may see a blue screen with a C000021a fatal error warning. The easiest way to recover the Windows operating system from this type of error is to restore your computer to a previously working state.
1.Press the "F8" key on your keyboard when prompted during the boot process.
2.Use the up-and-down arrow keys to highlight the "Last Known Good Configuration" option. Then hit "Enter.
3.Use the up-and-down arrow keys to highlight the operating system version that you wish to boot up to, and then hit "Enter" again. The system will now restart to the last working version of your operating system, which will eliminate the C000021a fatal error.
Hope this helps
Mar 13, 2010 | Computers & Internet
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
Fatal error
Fatal Error K (for BLACK) - Black toner or drum problem, Drum life exceeded? Display would of said black drum near life before failing.
May 15, 2007 | OKI C5100n Laser Printer
"Fatal Application Error"
This problem may occur if the user allows the batteries to discharge to a state where the MobilePro must shut itself down. This state may cause the system storage memory to become unstable requiring a "hard" reset after the system has been fully charged again. Failure to perform the hard reset may result in data loss at a later time. The user manual states that if you receive a message indicating that the batteries are low, immediately connect the AC adapter to the device. The solution is to perform a "hard" reset after fully charging the internal batteries, and then install the service packs, software updates and user software.
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Sep 14, 2005 | NEC MobilePro 880
Sep 14, 2005 | NEC MobilePro 750
GE Dinamap Pro 300 Monitor Logo
113 people viewed this question
Top GE Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a GE Health and Beauty Expert? Answer questions, earn points and help others
