Question about Kenmore 500 3.5 cu. ft. Top-Load Washing Machine 2952
Washing machine will not move from cycle to cycle unless you move it along yourself each time. I think it is washing okay, but would go and go until you move it along.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Needs a timer motor on rear of timer
Posted on Jan 15, 2013
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
TheMobilian
  • 8220 Answers
SOURCE: My Kenmore 90's series washing machine will not
The timer you have has a bunch of small gears inside. The case is made of plastic. Yes the timer is most likely shot.To get the timer off you grab the black plastic rod in back out and this releases the knob. Then you can access the screws holding the timer on.ec1c7f4.jpg
Posted on Mar 14, 2009
SOURCE: my washing machine will not work on any of the spin cycles, it seems to just sit there until the timer moves the dial to the next mark
It's likely the safety switch in the lid which keeps the machine from spinning when the lid is up. If the switch is bad it sends a false signal that the lid is up.
Posted on Apr 28, 2009
localwonder
  • 6784 Answers
SOURCE: Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Posted on Jun 18, 2009
garing
  • 998 Answers
SOURCE: Washing machine will not change cycles unless
ONLY REPAIR IS A TIMER REPLACEMENT
Posted on Aug 04, 2009
Indesit WDG1295W. Why doesn't it drain?
The pump and connecting lines could be choked with debris the filter didn't catch.
Dec 26, 2015 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
Washer Doesn't move from cycle to cycle
this washer has a problem with the lid hinge screws coming loose. check the left hand hinge and you will find the screws loose.
this cause the lid switch to not engage and then nothing will happen until it thinks the lid is closed.
try to tighten the screws and listen to see if the switch "clicks" when you open and close the lid.
that should fix it until the screws come loose again.
Jan 30, 2009 | Whirlpool LSR6334LQ Top Load Washer
Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Dec 13, 2007 | Washing Machines
Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Nov 06, 2007 | Maytag MAT13MN Top Load Washer
Active light flashing after wash
First check the fuse. It might be blown. if so, you can Call Customer Service to replace the fuse or replace it by yourself: lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Sorry i can help u more.
Dec 11, 2005 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore 500 3.5 cu. ft. Top-Load Washing Machine 2952 Logo
20 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
