Question about Kenmore Dryers
Dryers starts but shuts dow after 3 minutes
Series 70
  • charles carroll Jan 15, 2013
    kenmore 70 series, electric, mdl: 110 6070 2990
  • 314 Answers
Instructions
    • 1 Unplug the dryer. Remove the top panel of the body using your screwdriver to unscrew the upward-facing screws in the door opening. Remove the front section (with the door in it) by loosening the screws that are facing forward, which you can access after the top is off to give you unfettered access to the big metal drum inside.
    • 2 Trace the path of the rubber belt encompassing the drum, following it down to the point where it runs through the motor that turns the drum. Lift the belt off the drum surface at that point as it runs through the pulleys to the motor. Put a chalk mark on the drum next to the belt, right where the belt lifts off the drum.
    • 3 Hold your belt dressing can with the nozzle pointing at the underside of the belt where it's exposed with the lifting of the belt from the drum. With your free hand, turn the drum slowly while spraying the underside of the belt with belt dressing.
    • 4 Continue turning the drum, slowly, while spraying the belt dressing onto the back of the belt. Look for the chalk mark that you made to come back around in front of you, indicating that you've rotated the drum one full circle.
    • 5 Reassemble the dryer, putting on the panels and tightening the screws in reverse order from how you took it apart. Plug it in, turn it on and test it for the noise.
Posted on Jan 15, 2013
5 Suggested Answers
SOURCE: kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Posted on Jan 05, 2009
  • 65 Answers
SOURCE: Kenmore 70 series dryer shuts off and won't restart
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
Posted on Jan 28, 2009
  • 2183 Answers
SOURCE: my kenmore series 70 dryer
sounds like you have a bad motor,it's hard starting and then it's overheating,when it cools down it will run again
Posted on Oct 16, 2010
  • 70 Answers
SOURCE: Gas Dryer not working properly
bad thermal sensor needs to be replace. But not available. sorry
Posted on Jun 07, 2012
Kenmore 70 Series Electric Dryer will not start
It sounds like the hi-limit thermostate and/or the thermal cut-off is what is causing your dryer to shut down. Basically it's over heating. You should replace these two items togeather. Also the thermal cut-off will be triggered by a grounded out heating element. Here is a diagram of where these items are located. hope this helps
Figure W-6: Dryer Rear Access
Feb 27, 2012 | Dryers
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Oct 02, 2011 | Kenmore 63942 Dryer
Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
Jul 22, 2009 | Dryers
Kenmore 70 series dryer problem
HI. This may be an issue concerning the pressure switch that is located inside the rim of the actual door.
This switch activates the main drum motor when a cycle is selected when you are ready to dry your clothes. As soon as you select the desired cycle and you load the clothes and shut the door, the last thing to do is push the start switch. if the door pressure switch is malfunctioning, it will not allow you to start the dryer. it will simply not spin.
If you can visibly see the light inside the drum/basket while the door is closed, this will confirm the malfunctioning pressure switch that is located inside the inner part of the door rim.
Its located in this position so that the actual door can make contact with it, in return, applying pressure to close the switch and complete the circuit. this will cause the dryer to spin.
You stated that you can see the drum light shinning when the door is closed and, this will confirm my diagnosis. You can preform a hard reset just to make sure of this defect. Simply unplug this unit for 5 minutes or, shut down the circuit breaker for 5 minutes as well. Any methods will work. Once the 5 minutes are up, simply plug back in this unit and try to run a normal cycle. if this problem is still and issue, it will once again confirm a door pressure switch failure and you will need to replace the switch in this unit.
I would check the wire clips and connectors as well located on this switch for lose or worn contacts. this can be a problem spot as well.
Please rate and god bless:)
Apr 26, 2009 | Kenmore Dryers
Jan 28, 2009 | Kenmore 73952 Gas Dryer
Dryer shuts off after 5 or 10 minutes
repl/ thermsitor if avaiable if not repl/ hi limit thermostat on top of ignitor
Dec 29, 2008 | Dryers
Kenmore 70 series clothes dryer
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
