Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Does not dry as good as it used to
The lenght of time it takes to dry clothes seems to be taking longer does anyone have any suggestions thanx nick
  • 67 Answers
Condensor will almost certainly be blocked with lint to clean this you would have to take the whole unit off with the fan motor attached . Ther are 2 screws at the top and 3 screws at the bottom poss 1 screw in the midddle to the right. After reconnecting make sure it does'nt leak from the bottom of the condensor
Posted on Jul 12, 2007
  • 72 Answers
Chek to see if the vent pipe is clogged with lint, reducing your air flow.
Posted on Jul 11, 2007
Timed dry dosent seem to work as well. other settings woork but not as well as used too.
Are we talking about clothes not drying ? If we are you need to check your lint duct for a restriction not just the hose behind the unit but all the way to the outside vent.turn on unit go outside to vent should feel a good flow of warm air.Over time these ducts get restricted and it happens slowly then one day you relize its taking a lot longer to dry than it used to.. To dry clothes properly you need more than just heat ,you need good air circulation to remove the moisture otherwise all you end up with is warm moist clothing......Hope this helps Good Luck
Aug 08, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer is hot when opened, but takes 3 or 4 timed cycles to get clothes dry on very dry setting and timed setting
Check for a restriction in exhaust system,not just behind unit but all the way to outside vent,should feel warm decent airflow at outside vent.If not all you will end up with is warm moist clothes,You need good airflow to take away the moisture in the clothes not just heat.This issue can happen slowly over time and next thing you know its taking two or three times longer to dry even though when you open the door its hot inside.
Good luck
Aug 08, 2010 | Amana Dryers
DLE7177WM - Seems to work ok, but it is taking
Its going to be an issue with the wall vent of your house. The dryer is not venting the air at a good enough volume and that is why it is taking longer to dry. Sometime you may have to run a second cycle and I bet there is lint on your door gasket around the 6 o'clock positon.
The flex vent behind the dryer, the wall vent, and or the vent's outlet (roof or wall) outside the home needs to be cleaned to improve the air flow.
Good Luck.
Jul 04, 2010 | LG Dryers
It takes longer to dry your clothes you have to restart the drye
first clean the pip from the unit to the outsde vent.
then inside your unit there are 2 felts that need to be cahnge, over time they go bad and the heat run out the drum and you can feel the hood is hot but it still not to good . it will save you electric bill when you fix it. :)
Dec 31, 2009 | Whirlpool LER4634J Electric Dryer
We bought our maytag washer/dryer in 2007. Washer does great, however our dryer is the problem. It seems to take longer to dry clothes, than any dryer that we have had, also the clothes "ball up", which...
are u sure the belt isnt sliping somtimes if u over load or have a lot of cloths in it that will ball up the cloths and haeting problem either the vent tube is stopping up or heating coil is going out
Oct 23, 2009 | Dryers
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
If you have'nt done it yet, my first suggestion would be to have the vent on the dryer (inside the dryer all the way to the fan chamber) and the dryer vent pipe to the outside thoroughly cleaned.
That is leading cause for dryers not drying completely.
Also, has the dryer always been a bit slow to dry cloths? If so, try leaving a window open the next time and see if it makes a difference. Some houses are sealed so tight, the dryer can't get enough air. A typical dryer will use up to 200 cu/ft of air per minute when drying. If there is not sufficient air, the cloths take longer to dry.
Good luck, let me know.
Regards,
May 12, 2009 | Maytag PYG2300A Gas Dryer
Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Jul 08, 2008 | Whirlpool ET8CHEXSQ Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
