Copiers
Problem for Copiers
Generic problem for all Copiers
Sharp 7900 black copies and low developer
By suzolsen on Jan 24, 2009
First the copier started making more and more totally black copies, and the low devloper warning light was on. Toner had spilled inside the copier. I cleaned and vacuumed all of the excess toner.
Is developer and toner the same thing? There are separate warning lights for each. I have puechased a new toner cartirdge and a bag of developer. I know how to install the toner cartridge. What do I do with the developer?
Clarification Request
Posted by ccat342 on Jan 26, 2009
sf-7900 right?
totally black or just very dark?
totally black should be a bad copy lamp/temp fuse problem.
does it light up when you copy?
Posted by jpd8 on Jan 24, 2009
..?.. why did you buy the dev. material? Did some one tell you to replace? You will have to take out dev. unit, take apart, clean and vac. dev. unit, install new dev. matr., install dev. unit into machine and then intil. the dev.unit/ material. IS this something you can do?
If toner or dev. material in spilling into machine you may have to replace seals and/or bushings as well.
Solution #1
posted on Feb 01, 2009
Not Rated)
thesharpman
Rank: Guru
Rating: 92%, 38 votes
The problem is the drum blade is going bad.This machine is about 15 years old not worth the time or money plus alot of parts are no more.
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
What do customers think of the the Toshiba e-studio 5520c, as we are considering buying one?
Answer
shredder is clear but will not shred however i can reverse with in and turn it to shred and it does
Answer
I have a Hp Office Jet Pro L7590 All In One. The blue ink will not work. I have replaced it and... (More)
Answer
Canon Copier 2220 will not do anything and error light keeps flashing.No response to anything.
Answer
how to claen drum of toshiba coper?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copiers Experts
Top Copier & Fax Repairmen
in , KY
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
