Question about Dometic NDR 1292 Refrigerator
Why does the reset button continue to trip
I found out my Dometic RM 2652 Fridge had a reset button. I reset it and the fridge started back up. This lasted maybe three minutes and tripped again. I have to continue to reset it. What do I need to check to solve this problem.
    Top Expert:
  • Dometic Master
  • 14,162 Answers
Posted on Jun 14, 2015
  • 159 Answers
SOURCE: camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
Posted on May 15, 2009
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
  • 909 Answers
SOURCE: We have a 3 way Dometic fridge in our caravan.
Temperature does play a big part in the efficiency of the fridge. The condenser at the back of the fridge needs cool air flow to allow gas vapour to be converted back into a liquid.again.
Posted on Nov 12, 2009
Testimonial: "Tks Guru, BikerT. To prove that you are right - since the weather/heatwave has gone - a nice cool morning today and I have frozen milk. Cheers, "
SOURCE: have a dmetic rm 2652, have power in fridge but no
On most Dometics, When you have a cooling problem follow these steps and it will resolve your problem or at least tell you what is wrong.
Check main terminal Block for proper Voltage
Check Heating element for proper ohms, 2652 is 44ohms
Disconnect P-2 wire on board for approximately 12 to 18 hrs. This makes the unit run constantly in case there is a clog in the unit.
The only other thing you may do is check the thermistor operation, Unplug the P-2, remove the thermistor from inside the refrigerator, put it in ice, You want the thermistor to drop to about 32 degrees, Check the ohms, they should be at 8,000 to 10,000 ohms.
If all checks out, you have either a bad board, not common, or a bad cooling unit, common
Posted on Jun 12, 2010
  • 3740 Answers
SOURCE: I have a RM 2652
If your refrigerator has had a recall done on it I would check the L shaped bracket that was added as part of the recall, as it may have pinched thermal flame sensor and driving may slightly reposition it to cause an intermittent short blowing your 15 a fuse in rv panel. Remove it from the retaining fingers and slightly reposition fingers loosely around black insulation sleeve and reattach it to the previous location with the 2 sheet metal screws.
Now if the refrigerator won't come on at all check the resetable hi limit switch that is riveted to your units boiler area a few inches above your gas flame area. It has a button you can press located in between the 2 connectors.
Check for 12 VDC at the nylon terminal block in front of your main board AND on terminal J4. If power is there follow to the resetable hi limit switch on boiler. If you don't have power at all you may very well have a control board failure. You should check all 3 fuses on the control board also. So check all 4 Fuses (ONE) 15A on the RV Panel and the (THREE) fuses on the main board. If any of them are blown you can replace them ONCE only. If it blows the 15A Fuse on the RV panel again your going to have to locate the short most often from the RV panel to the main board on the refrigerator. If the fuses on the mainboard blow your going to have to troubleshoot the refrigerator wiring.
Thanks for choosing FixYa
Posted on Sep 02, 2010
How do you replace a door handle/latch on a Dometic RM 2652 fridge door?
There should be two screws holding the handle on. Remove them and install the new handle assembly.
Aug 31, 2013 | Dometic Refrigerators
I have a dometic rm 2652 in a 2003 travel trl. The propane side works. The elect side quit working. There is power to plug. The lights for auto and fridge inter. also work. The two fuses are good.
Unplug hydro plug to fridge. Remove cover on circuit board. Follow wires from heating element, to terminals on circuit board. ( probably J7 and J8 ) . With an AC volt meter or multimeter set to AC voltage, turn fridge on hydro, and leave door open on fridge so that it calls for cooling. To be sure it's calling for cool, try gas first, when it's starts, you know it's calling for cool, then switch to AC operation. Now test for voltage at the 2 terminals that the heating element were/are attached to. If you get 100-120 VAC, then replace the heating element. If not get back to me and I'll walk you through a couple more tests.
Jan 26, 2011 | Dometic RM2652 Refrigerator
Dometic refrigerator RM 2652 is not working
The fridge needs a 12 volt DC source to operate properly, which should be connected at the back of the fridge, outside behind cover. Check all fuses in your fuse panel as well. The upper controls are powered by 12 volt DC system, and that's what tells the fridge what to do.. (battery or converter)
May 08, 2010 | Dometic RM2852 Refrigerator
Rm 2652 stays on a while then cuts off and stays off
If you have the yellow epoxy filled circuit board from around 1993-1996 rather than the green newer one you can see the circuits on (take the black cover at back of fridge off to check) it is most likely just a bad circuit board. Otherwise it is most likely low voltage or a bad ground on the 12volt power coming into the fridge. Also make sure your thermostat(if available) is on maximum during testing.
Feb 01, 2009 | Dometic RM2652 Refrigerator
Oct 12, 2008 | Dometic RM2652 Refrigerator
Silhouette by Dometic RV fridge
Tuna, it sounds like your thermistor is bad. Once the fridge reaches 40 degrees, the thermistor is supposed to tell the board to stop cooling and maintain. You can test it with an Ohmmeter.
May 07, 2008 | Dometic RGE400 Top Freezer Refrigerator
Dometic NDR 1292 Refrigerator Logo
197 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
