Question about HP PhotoSmart Office Equipment & Supplies
Why is my printer not printing right
For example, if i was printing the french flag, it would only print a pink colour were the red is supposed to be. the cartriges are the right ones and are definatley in the right place. the cartiges are new and will definatley have at least 75%-80% in each as only been used about twice. the strange thing is all other colours work. Help would be appreciated
    New Friend:
    Problem Solver:
  • 13 Answers
This sounds like the chip on the ink cartrige, try cleaning the chip or replacing the red magenta ink. How a printer works, information from the Dynamic Link Libary is sent to the printer driver, this information is where to print on the paper and what colour to print, ie turning the ink jets on and off, the depth of colour comes from each ink by mixing the inks from the information in the photo or text. All ink problems are usually from ink faults, miss printing comes from driver information. Phill
Posted on Jan 15, 2013
  • 52 Answers
SOURCE: Canon PIXMA iP4200 - not printing in colours
hi i am a Canon certified tech for this machine.the orignal problem you had most likely was not your printhead but since you washed it most likely it is ruined. the problem most likely is the purge unit. the purge unit is the unit to the far right of the machine. this unit cleans and purges ink from the ink tanks to the printhead. to do this it uses 2 pads one for black and one for color. these pads can be flushed with water to soften up any ink. i would also replace the printhead which can be ordered by calling 1-800-OK-CANON or by going to their website. one other tip, refilled ink cartridges cause more clogging of printheads and purge unit then OEM ink. this is because the ink is thicker then the OEM ink. hope this helps to clairify.
Posted on Jan 05, 2008
gwbm
  • 353 Answers
SOURCE: epson stylus photo 830 my printer is only printing red wwith the word new zealand at the top
Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of ink? Yes, but not perfect cyan-magenta-yellow and black? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head
parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Posted on Feb 28, 2009
SOURCE: my printer is printing colour red faintly.
Sherry, in all probability it is the "scanner assembly" HP can fix this for $279 in the US using HP Express exchange 1 day ship, this was the result of their active chat. I am having the same problem and am going to dismantle the printer myself to see if I can't clean the scanner mirror myself. If you search the following words on google you will find some info, fading red tones laser jet 2605, one of the first results is a page on the HP site specifically on laserjet printers. I wish I had a quick fix that would help; however, a new cartridge won't help!
Posted on Mar 17, 2009
  • 3 Answers
SOURCE: print keeps fading, even though using new ink
check your printer settings, make sure color only is not checked off, or if you mainly print black and white documents, you should have that option checked, you may have to go into advance printer options to do this.
Posted on Apr 07, 2010
joeguest2
  • 2080 Answers
SOURCE: Hi. My Epson SX510W
Next time you print something out, try selecting BLACK AND WHITE mode in your PRINTER PREFERENCES in the PAPER QUALITY tab.
See if it will print something at all in black with this settting. This might help indicate whether there is a physical problem with the printer.
If that doesn't work, comment back here and I will suggest other options if you are interested.
Good luck.
Joe.
Posted on Feb 18, 2011
I have replaced all ink cartridges n black will not print n when I change it to colour it prints everything in pink
The color combinations (order?) of different printers are not the same. Make sure that you have the right cartridges for your printer.
Mar 08, 2015 | Office Equipment & Supplies
The color on the computer screen is different than what the printer prints. example a red/white/blue flag the blue is hot pink. on a christmas tree the green is blue
Is this a recent problem, or old quirk?
Best, to completely remove printer prog.
Go to www.hp.com search/enter your printer specs, and update/download your printer's latest update?
Nov 12, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
MP 160 IS PRINTING ONLY BLACK AND PINK COLLORS
Maintenance your cartridge with head clean or deep clean. If you don't get full colour, then change the colour cartridge.
Sep 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I bought new ink black and color but i try to print in pink and i can't how can i print in pink
Hi alexgallo01
Do you get other colours except pink?
If that is the case,reasons could be:
1. there is not enough RED or BLUE in the cartridge.
2. you haven't selected pink colour on the text or images you are trying to print.
If you are typing a document highlight the text you want in pink, and choose PINK color for the font.
Then print the document. The printer will use color closest to your choice, if it does not have the exact color.
Hope this will help.
If it help you, please give a rating
Cheers
luciana44
Sep 14, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
I recently installed new black ink cartridge. Since doing so, the colors on anything printed are incorrect. For instance, anything red prints as pink. Anything deep yellow prints as a gold. MY...
Hi maryryherd - yes the C64 is in the list - don't know why you couldn't see it.
The inkjet colour system can be quite confusing. The colours in the cartridges are cyan, magenta and yellow, plus black. Other colours require a mixture of these basic ones. For example, to produce "red" requires a mixture of magenta and yellow. Your problem sounds like you are getting insufficient yellow, and maybe insufficient black.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are all the 3 colour bands plus black printed OK. If not, try up to three cleaning cycles. If ink is now flowing pretty well, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back with a new comment.
Apr 18, 2009 | Epson Stylus C86 InkJet Printer
Won't print correct colour
Try printing a test page. If it comes out missing colors, the you color cartridge is bad. HP test pages will print each of the 3 colors by them selves, so you can see if you are getting all colors. If this prints ok, the I would think it is not a printer problem.
Mar 06, 2009 | HP D1560 Deskjet Printer InkJet
I have a hp desk jet model 710c printer. I have cleaned and aligned the printer. The color red does not print. A test print will not print RED. Do you have any suggestions on what to try?
simple.the ink in the colour cartridge is over.usually pink and yellow mix to form red any of the 1 colour is over.just get your cartridge refilled or buy a new cartridge.the printer is absolutely perfect.
thanks.
Nov 14, 2008 | HP Office Equipment & Supplies
Colors not printing right
Without a model for the printer it is hard to say. But is if is a standard bubblejet printer with a colour and a black cartridge, then chaces are your colour cartridge is low on red (magenta)
Apr 13, 2008 | Office Equipment & Supplies
Problem in colour
If the printer is old, then maybe there's dust on the mirrors that the laser bounces off of. See my step-by-step instructions on how to clean it on my website.
Feb 17, 2008 | HP Color LaserJet 2600n Printer
Colours are not correct on Kyocera C5016N
My Color is off My shirt is suppose to be bright BLUE and it is turquiose and the jacket is suppose to be RED and its Orange.
Feb 04, 2008 | Office Equipment & Supplies
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
