I REQUIRE A COMPLETE LIST OF REMOTE CONTROL CODE LIST
I HAVE A PANASONIC TV MODEL NO TX-L26X10B AND A PANASONIC DVD RECORDER MODEL NO DMR-EH50. MY HUMAX REMOTE (RM-F04) CONTROLS MY PANASONIC TV USING CODE NO 129. NONE OF THECODES LISTED IN THE HUMAX CODE LIST OPERATES THE DVD PLAYER. CAN YOU HELP?
3 Suggested Answers
SOURCE: setting humax foxsat hdr remote to control panasonic tx32lxd60 tv
Had the same problem with my panasonic - it would appear that none of the codes will actually turn the TV off because they need a longer signal to turn off. I eventually found that code 0650 works for mine - input the code as instructed in the manual and then selected OK - holding down the standby button on the humax controller then turns the TV off. Try all the codes and see which gives most control functions. Hope this helps.
Posted on Feb 14, 2009
  • 1274 Answers
SOURCE: I recently purchased a Panasonic DVD Recorder
You said you have the operating instructions, try this,instead of doing the manual entry of your code, try using the CODE SEARCH method for each one....hope this was helpful.....
Posted on May 23, 2010
Panasonic DMR EH50. Picture is dominated by the colour pink. TV not affected.
Please check your Blue and Red component cables on both the recorder and your TV. One is probably loose.
Apr 07, 2014 | Panasonic DMR-EH50 DVD Recorder
Pan DVD Recorder DMR-EH50
Press enter and 2 at the same time for more than 3secs
Oct 29, 2009 | Panasonic DMR-EH50 DVD Recorder
Actually I have a 4 yr old dmr eh50 panasonic dvd recorder
Make sure remote is set to unit code ex: press enter and 1 at same time see if this matches try enter and 2 or enter and 3 see if this matches and works
Oct 03, 2009 | Panasonic DMR-E50 DVD Recorder
How do I copy a programme I have recorded on the HDD to a DVD-R. I have a 1 hour TV programme recorded on my Panasonic DMR-EH50 hard drive that I want to copy to a DVD-R. Can you help me do this please.
On your machine or on the r/control you should have a copy button,if you press this you should get a menu come up on screen.It should ask you which way you want to copy,so you will go HDD-DVD-R,then press copy again and it should do it automatic,hope this helps.
Jul 11, 2009 | Panasonic DMR-EH50 DVD Recorder
Looking for the region codes!
I want to make my panasonic dmr-eh50 to multi dvd region player. How to get the dvd multi region code?
Jun 24, 2009 | Panasonic DMR-EH50 DVD Recorder
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Check your user guide for the answer.
Nov 08, 2008 | Panasonic DMR-EH50 DVD Recorder
DVD Recorder Screen keeps saying HOLD and not switching on
CHILD LOCK:
The Child Lock Deactivates All Buttons On The Unit & Remote Control.
To Deactivate Press & Hold (OK) & (RETURN) Simultaneously Until "X HOLD" Disappears.
Oct 28, 2008 | Panasonic DMR-EH50 DVD Recorder
Does the DMR EH50 work with satelite tv
Yes Connect using Scart
Sat to EH50, Sat to TV as per page 15 of the manual and it should work fine mine does
Dec 05, 2007 | Panasonic DMR-EH50 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
