Question about Panasonic SC-HT900 System
Sc ht900 how do you switch the optical input on?
Recent purchase of an Apple TV, unit red light is showing at end of cable. Music plays on normal TV sound but nothing on the surround sound system
  • David E UK Jan 19, 2013
    Thanks everybody so far, the unit has given very good service over a number of years, connection to the TV is via a scart cable, the surround sound comes from the SkyHD via twin audio cables also have a record deck plugged into the AUXposition.
    Thanks everybody so far on my problem, this unit has given very good service over a number of years, currently the unit is plugged into the TV via scart socket, surround sound is received via twin audio cable into the Sky HB receiver, plus record deck into the AUX input. Noticed the the Sky HD box has a Optical output for sound nad disconnected the twin cable and tried the optical - still no sound, recon its going to be a repair job
  • 47 Answers
SOURCE: How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Posted on Mar 09, 2008
tech48
  • 624 Answers
SOURCE: intermittent sound with Panasonic SC-HT900 home theater system
I will get back with you on this tommorow with more information when I can get the technical data I need from where I work.
These units are know for the problem you are describing.
If you have to connect all of your speakers to the subwoofer, then yes, you can replace the subwoofer and it will fix your problem. I just don't remember right now if this unit is the one with the amplifier built into the sub woofer, but I think it is.
Since you paid another repair center you really should take it back to them to fix it right. They probably did not test it long enough to verify if they fixed your problem.
I know it is a real pain to have to take it back, more so if it is far away, but the problem you are having is nothing you will be able to fix yourself unless you have some decent electronic troubleshooting and soldering skills.
Get back with you soon,
Dave
Posted on Jun 19, 2008
SOURCE: cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Posted on Dec 17, 2008
daniel719
  • 240 Answers
SOURCE: Adding another external device to the sound system
yes you are right you can pick up an arc aux swich box from radio shack.
will do your job just fine.
thanks
and pleas rate this, if is of help to you.
Posted on Jan 13, 2009
konzzz
  • 255 Answers
SOURCE: Panasonic SC-HT75 won't read and play DVD Movies and play CDs
you may clean the lens, then try to play dvd's again.
Posted on May 13, 2009
I have a Sony bluray surround sound and lg smart tv, I can't play my Apple TV sound through my hts, all my connections are hdmi and both systems have arc, please help?
Is your Apple TV connected to the Sony or directly to your TV? If directly connected to the Sony HTS ARC shouldn't be needed and you should have audio. If that's the case check the Apple TV settings to be sure it isn't set for s/pdif output. If connected to the TV then the TV should be able to put a s/pdif signal on the HDMI ARC pin but perhaps there's no way to assign it to the HDMI input coming from the HTS? It may be going to the ARC pin on the Apple TV HDMI input which won't give you any sound. Normally ARC is intended to put the s/pdif signal from the TV's internal tuner on the HDMI cable from the HTS so the HTS can play TV sound without having to tun a separate Toslink cable from the TV s/pdif output to the HTS. One other thing: Early HDMI cables do not include the ARC wire so be sure you have ARC capable cables. Look in your TV documentation to see if there is a way to assign the ARC output to a different incoming HDMI input if the Apple TV is connected directly to the TV. If not you may need to resort to a Toslink optical cable from your TV to an optical input on your HTS. Or actually running that cable from Apple TV to the HTS would be better since it's possible it could carry surround sound. Most TV's optical outputs are limited to the 2 channel sound the TV can accept.
Oct 22, 2014 | Audio Players & Recorders
No sound on USB
We regret to inform you the USB connection from an Apple TV will not provide you any sound. We recommend you connect the Apple TV with an Optical cable then place the home theater on the Optical input to hear sound.
Mar 15, 2014 | Panasonic SC-XH170 Dvd Home Theater System
No "red light" on Digital In
The port on the jvc is probably an input, which does not produce light. Only optical outputs will have the red light in them.
Jan 04, 2013 | JVC TH-A75R System
I have a panasonic TX P50 C3B 50" Plasma TV and want to connect it to a SC PT470 home cinema system only I cant see that I have a fiber optic connection on the tv and no matter what i try i cant get...
If you want to listen your TV on your Stereo system thru your Home Cinema receiver, you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV to "AUX input " or "Any input" of your receiver ( except Phone ) or "Optic Cable input" than just switch to respective mode corresponding your RCA or Optic connection...
There you go..Your TV sound is on the Receiver..
Take care and pls remember to rate me..If you cant succeed you can contact me for more solution..
Thanks
Jun 19, 2011 | Audio Players & Recorders
I have an LG DVD Reciever HT462 which i want to connect to my PS3. My PS3 is all set up correct as I have spoke with Sony. I have the PS3 connected via a HDMI cable to my TV and an optical cable running...
It would appear from what you have said that you have everything connected properly. Maybe a silly question, but make sure you select the digital input on your LG to get the sound from the PS3. If there is still no joy, unplug the optical from the back of the LG unit. Look at the end of the Optical cable that should still be connected to the ps3. Is there what looks light a red light there? if so it means that the optical is getting to the LG system and the LG sytem's digital in port is Duff. If there is no "Red Light", unplug it from the PS3 and look directly at the optical out port on the ps3. Is there a Red Light there? if there is, you need a new optical cable. If there is no red light, you need to enable the digial output on the ps3. If you have and it's still not "red". the optical port is duff.
Jan 07, 2011 | LG Audio Players & Recorders
How do i properly connect my nintendo nes sytem to my direct tv. when i use the av cables i just get a blue screen. can u give me step by step to connect correctly.
Note: This type of connection is not possible with the newer-style NES.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the AV cable into the Video "in" on the back of the TV. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
On the other end of the AV cable, plug the yellow end into the "Video" (yellow) input. Plug the white or red end into the "Audio" (red) input, on the back of the NES.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Press the Power button in on the front of the NES.
Turn on the TV and locate the input select. It is often called: TV/Video, input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Installation Steps:
Place the yellow end of the AV cable into the Video "in" on the back of the VCR. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
After system is connected to the VCR:
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Turn on the NES by pressing the Power button on the front of the Control Deck.
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen.
Recording Game Play
Set up the NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
Sep 06, 2010 | Nintendo NES Console
Connecting fiber optic cable with ''SC'' type connectors
No it should clip in, however you have the wrong connector on the end, usually these cables come adapters with them to suit you source or TV.
Get your self another cable with adapters, try eBay...!
Thanks
Oct 09, 2009 | Televison & Video
How do i use it so my tv programming is in surround sound?
if the Comcast cable box has an HDMI output, it should connect directly to one of the TV HDMI inputs. Then connect the LG DVD unit HDMI output to the second HDMI input of the TV. Use two HDMI cables. Do not buy the expensive Monster HDMI cables. If you have already done so, I recommend you take it back for a refund, then buy the low cost HDMI cables which will work just as good and then you can bank the savings toward a new Porsche Boxter!! Now we have the video connected from both the cable box and the LG system.
Now--what do you do if the cable box does not have an HDMI output--just use its component output and your component cable (red, blue and green) to connect to the TV component input. This will still get the video to the TV and good HD pictures. Hum--do you have an HD cable box? You did not say and I just assumed that you did since you got the HDTV. If not, let me know with a follow up question and I will assist in that area further.
Now for the audio connections--The DVD player will not need any connections since it in the LG unit. The sound will come out the speakers when you start playing the DVD. The cable box is where we get the TV audio to feed the LG unit. If the cable box has an optical output, use an optical cable (again the low cost one)and connect to the optical input on the LG.
This will get the TV audio to the surround system. If no optical output, use the red and white (left/right) audio connections and connect to one of the two the LG audio inputs. To hear TV audio on the LG speakers, just switch to that input or the input associated with the optical input.
To watch DVDs, switch the TV to the HDMI input to which you connected the LG unit. For TV, go to the other HDMI input (or component input).
Switch the LG to the audio input to which you connected the cable box to get TV sound.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Sep 11, 2009 | Audio Players & Recorders
Surround help
Hmm. let me see if I get U correctly. you use u'r theater system with a TV and the audio is fed via optical or U have DVD player that you can feed the audio via optical or coax. I think it is the later, if it is U could be having trouble with sound decoding setting of the DVD player itself. It's like mpeg out or PCM out instead of full DTS or 5.1 dolby digital decoding. If this is the case just use u'r dvd remote and check the audio play back settings. If this does not solve u'r problem, pls state u'r set up briefly, so tht I can understand the type of connection u use. Happy troubleshooting Rifaa
Jun 11, 2007 | RCA RT2390 System
Panasonic SC-HT900 System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
