Question about Dimplex OFC2000 Oil Filled Radiator Heater
Wont turn on and glow light is dim - Dimplex OFC2000 Oil Filled Radiator Heater
Signal lights on my 2003 monte carlo blinking fast.opposite side glows dimly. Changed signal/cruise/high beam lever, changed all bulbs, changed flasher and all fuses. still doing same thing.
4 way flashers work fine but when operating either signal light, they flash fast and side not turned on lights up also, although more dim than the side that should be functioning..
Apr 02, 2017 | Cars & Trucks
Driving along lights dimmed, instrument panel died, loss of power then engine cut out & wouldn't start. Starts with a jump but when i turn key to heat glow plug, instrument panel goes mad
I assume there's a problem with alternator. Check the grounding to engine, check continuity of a positive wire between alternator and battery. the energizing voltage should be checked as well. Might be the bad connection between battery and vehicle body grounding. Diesel cars are sensitive even in a little loss of connection and rust in the connection points.
Feb 18, 2014 | Cars & Trucks
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
Aug 17, 2012 | 1993 Nissan Sentra 4 Door
Its a Ford F150 1982 model and my reverse lights wont come on, my turn signals are also not working. I replaced the fuses and bulbs but it didnt fix anything. What do I do?
these bulbs will insert into the socket both ways. Only one way is correct. If it glows dimly, turn that bulb around. If they dont work at all, you have a bad ground.
Feb 27, 2011 | 1982 Ford F 150
Signals and brake lights dim when brakes applied
it could be a bad connection in the stoplight wiring most likely the earth wire check all the wiring connectors to make sure they are plugged in properly.....hope this helps.....cheers
Jul 09, 2010 | 2004 Chevrolet Silverado
2003 Chevy Impala - radio, instrument lights/displays go very, very dim when headlight turn on (auto on feature...sensor on dash). Turning dimming knob up does not help.
There are two possible cause of dim display.
On the deluxe trim level of the Impala the is light sensor. When the sensor mis-calibrated the light will not be at the level you want.
As a test,use a small flash light and aim to the sensor and see is the circuit act according it.
The dimmer light is a VERY CHEAP component. I will glow it out with compress air 1st. Turn the dial back and forth 20-30 time in rapid motion will help remove unwanted carbon,
Use a eletrical contact cleaner to clean all contacts.
Is the headlight in OEM specification?
After market headlights may draw more amperage and cause low power for smaller bulbs.
Jul 16, 2009 | 2003 Chevrolet Impala
My head lights wont come on but parking lights will
there could be a shorted headlight bulb. have some one check which headlight bulb is not glowing when you turn on the headlights.
that could be the shorted bulb.
tnx 4 using fixya,
drcool
Nov 16, 2008 | 1991 Chevrolet Cavalier
I have a hyundai elantra 2001.. the brake light and the battery light both turn on.. what could be the problem...
Your alternator is probably not charging at full capacity. The brake light is next in sequence with the battery light, and will glow dimly. (Set your parking brake, and it will glow brighter.) I replaced the alternator, and cleared up the problem.
Oct 26, 2008 | Hyundai Santa Fe Cars & Trucks
Dimplex OFC2000 Oil Filled Radiator Heater Logo
44 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Andee Goacher
Andee Goacher
Level 1 Expert
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
