Question about Sherwood U8M Car Subwoofer
Sherwood sp212 manal - Sherwood U8M Car Subwoofer
My sherwood rx 4109 has no sound what do i do
Pull the sherwood power cord from the wall for 20 minutes. On the back of sherwood, check all cables and make sure they are in the correct places. Check speaker wires and make sure they are connected. 1)After 20 minutes, turn power on to sherwood. 2) select an input (radio, cd, etc.) 3) Push play. 4) Turn volume to desired level.
Feb 07, 2015 | Sherwood Audio Players & Recorders
Need a manual for Sherwood RV 6030R
The manual is available for downloads but with a price tag.The best bargain is from the link below at a cost of $4.99.Click on the link if you wish to make the purchase.
www.sherwood.owner-manuals.com/RV6030R-service-manual-SHERWOOD.html
Hope this helps.Thanks!
Ken.
Jan 13, 2012 | Sherwood Audio Players & Recorders
How do I reset the defaults on my Sherwood RD-8108 AV receiver?
I just got a tip from Sherwood tech support on resetting my Sherwood receiver, and it solved my problem perfectly. It's not the same model number but here's what I did: Put the receiver on Standby. Press and hold the Setup button for 3 seconds. When you see the model # on the display, press Enter. The word "Cleared" should show on the display. Hope it works for you also.
Feb 03, 2011 | Sherwood RD-8108 6.1 Channels Receiver
FM Tuner in Sherwood RX-4105 stopped working
Check your antenna connections. Make sure your FM antenna is hooked up to the FM antenna terminal or jack on your Sherwood receiver. If you have the antenna hooked through the coaxial cable, check your coaxial cable with an ohmmeter for continuity. You can buy a volt-ohm meter as little as $12. Usually bad connection occur between coaxial cable and the the coax cable connectors. If that doesn't solve the problem, then there may be something wrong with your tuner card inside of your Sherwood receiver.
If you receivers display does not change channels or frequencies or AM or FM mode, when you try to change the channel or frequencies, or AM or FM mode, there may be something wrong with the front board of your receiver.
If there is something internally wrong your Sherwood receiver, you need to take it to a qualified technician that can fix it. Do not try to repair it yourself. If you don't know what you're doing, you can do far more damage to that Sherwood receiver to the point that would be very costly to repair.
Before you take your Sherwood receiver to a technician, try to unplug the receiver, and leave it unplugged for several minutes, and then plug it back in. If that doesn't solve the problem, then you need to take your Sherwood to a qualified technician.
Dec 02, 2008 | Sherwood RX-4105 Receiver
Who in brisbane australia is a sherwood repairer
hi almost any qualified technician in sherwood electronics. first take a look if the logo sherwood is offered for service. dont forget to visit www.google.com where you can find the exact place in birisbane servicing sherwood electronics....saludos
Nov 24, 2008 | Sherwood Audio Players & Recorders
RD-6500 Sherwood amp
What model RC? Doesn't its manual give some clues?
Jan 08, 2008 | Sherwood RD-6500 Receiver
Sherwood U8M Car Subwoofer Logo
Top Sherwood Car Audio & Video Experts
xxxxxx xxx
Are you a Sherwood Car Audio and Video Expert? Answer questions, earn points and help others
