Question about Kyocera Mita CS-4035 Maintenance Kit Black MK-707
Where do i put the grid cleaner on my copier
Not sure where to put my "grid cleaner"
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
Just below the main corona unit.
The instructions come with/on the toner cartridge box.
Posted on Oct 24, 2013
AFTER I CLEANED THE WASTE TONER BOTTLE ON OLLIVETI 18MF D COPIA NOW ITS PRINTING DOTS LINES
Check if you have put the little pwb inproperly or, in worst case, you have loose it. This pwb is in the left side of the processor unit. You will see a black circle tape near the grey tape of the grid cleaner.
Mar 22, 2014 | Kyocera FS-1118MFP Laser Printer
Copies and prints all black
Sounds like you may not have the main corona pushed fully home or you cleaned the grid with the grid cleaner that comes with the toner cartridge.When cleaning the grid you must leave the corona unit protruding out of the copier for 30 seconds to allow the grid to dry.Failure to do so can cause arcing in the machine that will give you black copies.reclean the grid and allow to dry before re-inserting
Aug 09, 2010 | Kyocera Copystar CS-5035 Copier
Exactly where is the grid cleaner located?
See steps 11-14 on page 10-5 of the Operation manual, http://usa.kyoceramita.com/americas/jsp/upload/resource/11858/0/3035-4035-5035ENOGR6.pdf. It shows placement and instructions for the grid cleaner.
Mar 08, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
How do I insert grid cleaner
don't even mess with that... I am a certified kyocera tech and I make it a point to throw the thing out...
Dec 04, 2009 | Kyocera CopyStar CS-3060 Black and White...
De powder coming back into pool water from filter
make sure your grids are properly seated and if you have a multiport valve, take it apart and make certain your spider gasket is in place and not distorted. That is the only other reason DE would return into the pool. If you have a slide valve, make sure your o-rings inside are in good condition and properly lubed.
Nov 01, 2009 | Hayward 48 Sq Ft Pro Grid Vertical Grid De...
IR5000 bloque
this is a code for detection of no or faulty charge to the drum open front door remove toner hopper take out primary charge unit see if any wires are broke on grid , then see if the wires underneath the grid are still there... if all seems ok gently clean the grid with cloth and windex then clean wires underneath dont break grid wires . put it back in let me know
Dec 23, 2008 | Canon imageRUNNER 8500 Copier
I cleaned my air cleaner and now it will not turn back on
When you cleaned your cleaner, you must be gentle with it. Wipe down with a lightly moist cloth or paper towel. make sure you dont shove any grime between the metal cleaning grid and the plastic holding it all together. that can cause lots of problems. Your air purifier probably wont start because of an auto shut off safety feature. Be sure that everything is in its proper place.... make sure hte front grill is fastened on correctly as well as the back grill. if those are not secured properly the unit will not start. also, check that your collection grid is placed all the way inside the unit and wait for the click noise that indicates that its locked in place. at that point the unit should turn on and you can once again enjoy fresh, pure air!
Dec 09, 2008 | Sharper Image Hybrid GP (SI724) Air...
Error sc 302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
In English:
I would check the roller motor for a short, frayed, or damaged wires. Use a voltometer and compare the voltage to the cleaner motor.
Apr 27, 2008 | Ricoh Aficio CL3500N Laser Printer
Metal grid came off
It sounds like the Main Charge Grid. If you are able to take it out of your machine then the grid probably broke off.
Is the grid a thin shiny metal piece about 10" long by about 1/2" wide?
Does it have a bunch of lines/open spaces on it.
If this is what i am describing, then you can purchase another drum unit, and this should take care of your problem with the copy quality and you will not have to worry about the grid.
Just to be on the safe side, where ever you place your order for a new drum unit, ask the company if the Main Charge Corona and grid come with the unit. I am pretty sure that model does have everything all in one unit.
Good luck.
Hope this helps. Please remember to post a feedback and rating if I have helped you in anyway.
Mac =)
Feb 25, 2008 | Sharp AL-1642CS Copier
Kyocera Mita CS-4035 Maintenance Kit Black MK-707 Logo
60 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
