Question about D-Link DGL-4500 Wireless Router
Can not install D-link dgl-4500 router
Hello can you help i am trying to install the above router but it will not work i follow the instructions word for word on the cd rom and when it gets to i think step 3 its says waiting for router it does nothing then it pops up Error 322: New Router Not Detected even tho its there, and connected i am also in the UK is this the problem many thanks
  • 5 more comments
  • deanhully Jan 24, 2009
    I have done what the quick install guide and cd rom says word for word, is the network cable same as the ethenet cable?
    Hello can you help i am trying to install the above router but it will not work i follow the instructions word for word on the cd rom and when it gets to i think step 3 its says waiting for router it does nothing then it pops up Error 322: New Router Not Detected even tho its there, and connected i am also in the UK is this the problem,
    how do i find out if its my network card not working properly as i know its not the cables as i am using them now with my old router
    Also when i type in http://192.168.0.1 to configer it online it just says im not conected to the internet etc etc but i am as i am talking to you at same time.
    ben thanks mate but i am not that good with computers how would i check that the router have their DHCP enabled and/or sharing the same IP address?
    oh it has said i have 4 drivers not up to date its just updating them now so i will wait till thats done then try and install the router again fingers cross also thanks guys i am not god with this sort of thing so thanks.
    Every one i did it it was some thing to do with my static ip address on pc i just changed that to auto or what ever and it works thanks every one for you help.
  • 535 Answers
Error 322 mines ur router has not connected properly u have to check thee cable its working or not check the all connection see the Manuel for the connection details
then u have to configure your router u need to this plug one lan cable in the computer & antoher is in router then open your internet exploer type there 192.168.1.1 its router defout ip press enter its will ask u user name & password put there admin & admin then press enter
then confuger your router
Posted on Jan 24, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, check/replace the networking/Ethernet cable. Thereafter, remove the modem and do not connect yet. Proceed with the installation of the router. If the router will install then correctly, then connect the modem and see if it will work, otherwise, check the possibility of both the modem and the router have their DHCP enabled and/or sharing the same IP address.
Pls post back results. Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 24, 2009
    The connection/system works. As you have posted if they are not, then you would not be on line.
    I still believe that a conflict of some sort exist between the modem and the router. Pls post back your modem's brand and model.
    Additionally:
    • press your Windows key + R;
    • type "cmd" less the quotes, OK button;
    • new window, type "ipconfig /all" again less the quotes;
    • press enter;
    • list/post the IP addresses/details.
    Cheers.
  • 144 Answers
Error 322 is Ethernet Related - Make sure your computer is plugged into the router via an ethernet cable and that you have the latest ethernet drivers installed for your computer
  • Alex Smallwood
    Alex Smallwood Jan 24, 2009
    yes , network cable is ethernet cable
    Try resetting the router back to factory defaults , unplugging everything and starting again
  • D-Link Master
  • 19,396 Answers
You need to connect the router to computer using a network cable to configure it for the first time.
  • 1 more comment
  • Ginko
    Ginko Jan 24, 2009
    You need to use an ethernet cable to connect the router, then follow the instructions starting from page 12 on the manual below.
    Untitled
    There are two ways to configure this router, one is web configuration, the other one is using a disk.
    Better to use Web configuration.
    In any case you need to use an ethernet cable to configure.
    An alternative way to configure the router is opening the Web configuration panel, calling your ISP (internet service) support nuber. Thy will guide you step by step through the configuration process.
  • Ginko
    Ginko Jan 24, 2009
    Ethernet cable is a kind of network cable, it is the one enclosed in modem box, with a squared RJ45 plug.
    If yyou used cables and you get the error then
    1. Cable is broken
    2. Network card on computer is not functioning (most likely)
    3. Router is faulty.
    Go to device manager and check if LAN card (not wireless) is listed unde re network devices, and does not have a yellow mark.
  • Ginko
    Ginko Jan 24, 2009
    I told you, that is probably a network card on computer that is not working, see my previous comment.
Hello, My D-Link DGL-4500 router won't work properly. The wireless portion will not work. I know the Username & Password. But no device I have will connect to it wirelessly. It'll connect...
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 03, 2011 | D-Link DGL-4500 Wireless Router
How do I get into the routers homepage to change some settings so I can run a wireless internet connection to my laptop while my Playstation is hard wired. I have DGL 4500
To get into the D-Link DGL 4500 router homepage, simply open an internet browser window and type in the following address:
http://192.168.0.1 and press Enter.
When the login window appears, set the user name to Admin and leave the password box empty.
Then, click Login to continue.
Here is the link to the PDF version of the User Manual:
http://www.dlink.com/-/media/Consumer_Products/DGL/DGL%204500/Manual/DGL%204500_Manual_EN_US.pdf
Jul 29, 2011 | D-Link DGL-4500 Wireless Router
I just bought a D link dgl 4500 router and it works fine most of the time. Tonight and one other night before it will reset my wireless network almost every five minuets. I have reset both the modem and...
Make sure you have the latest firmware as this might help with your dropped connections. Also try to make a DHCP Reservation for each computer connected to your network (p. 32 in the User Manual), as that can also help prevent dropped connections.
Download the latest firmware ver. 1.23NA to your local computer. Connect your DGL-4500 router via a wired connection (ethernet) to your computer and install the firmware update following instructions in the user manual.
Firmware link:
ftp://ftp.dlink.com/Gateway/dgl4500/firmware/dgl4500_FW_123NA.zip
Here is the PDF link to the User Manual:
Feb 23, 2011 | D-Link DGL-4500 Wireless Router
My husband bought a dlink router (it says dgl-4500 on it) and i cant figure out how to use it to get wireless internet for my new laptop....i have three "codes" he wrote down- a "router pass", a "network...
Router password is the password to access the router settings.
SSID is the network name. When you try to connect to the wireless network on your laptop, you will see this network name.
If your network is secured network then it will ask you for the network key or the password. You need to enter the ' security key '.
Click Here for step by step by instructions
Sep 11, 2010 | D-Link DGL-4500 Wireless Router
I have a D-Link DGL 4500 wireless router. I have
If you don't see any devices connected in the DHCP client list on the router interface even when you are sure of the devices being connected, only a firmware update or a re-flashing of firmware can help. You can find the latest firmware available on the d-link support site. You can verify the model and version numbers and download the corresponding firmware. This is only fix.
Feb 05, 2010 | D-Link DGL-4500 Wireless Router
I am trying to get my laptop connected wirelessly to my dgl-4500 router. It keeps saying connection time out?
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 11, 2010 | D-Link DGL-4500 Wireless Router
Problems connecting to DGL-4500
This can be a firmware problem so upgrading the firmware of the router should fix this issue on it, so I advice you to upgrade to the latest firmware of your router, you can get it from Dlink web site...
Oct 19, 2008 | D-Link DGL-4500 Wireless Router
D-Link DGL-4500 Wireless Router Logo
175 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
