Question about Sewing Machines
I do need a pedals for my Husqvarna OPTIMA 190 sewing machine which I bought 1983 ?
  • Sewing Machines Master
  • 7,365 Answers
As far as I know you do, here is a link for parts for the machine
http://www.sewingpartsonline.com/viking-190-sewing-machine-parts.aspx
Posted on Jan 15, 2013
  • 87 Answers
SOURCE: Threading a husqvarna viking 3610
This should be your machine:
http://www.sewingmanuals.com/Viking_Pics/Viking_3610i1.jpg
Sewingmanuals.com shows that they have this downloadable in Adobe PDF format here:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Viking.htm
#37 in the list as of me posting this. You can get a CD version too but you'll just pay more and wait longer for the same thing. Once you have it print the manual (preferably both sides to keep it small) ang you'll have it. You can also peruse eBay to see if anyone is selling a manual but I doubt that will yield regular results. The machine looks to be pretty basic and standard but it's best you have the manual to get the most out of the machine. Also be sure to check the cleaning and lubrication section and go through the process so that the machine is in top working order before you put it into regular use - saves a lot of headaches.
Posted on Apr 28, 2008
JeremySew
  • 65 Answers
SOURCE: need an instruction manual
Here ya go!
http://sewingpartsonline.com/viking-620-sewing-machine-instruction-manual.aspx
Posted on Dec 04, 2008
SOURCE: Viking 190 sewing machine stuck on backstitch
Found the problem (s) with Viking stuck on backstitch!!!
Two problems:
A: machine is "gummed-up" form old grease.
Solution: degrease machine with a high quality degreaser.. I used a spray electrical degreaser from an automotive store. Turn the machine up-side-down to preform this!
Then relubricate machine. Use a high quality sweing machine lubricant! Also lubricate the inner parts with a qigh quality "Sewing machine" oil.
B: Found that the return spring from foreward to backward was tired.
Soultion: Replace with slightly stronger spring from local hardware store.
If you need pictures, I took very detailed pictures of the reverse mechanism and "return to forward" spring.
Write to AApilot@comcast.net
Posted on Feb 14, 2009
  • 8 Answers
SOURCE: Need manual for Scandinavia 200 sewing machine
I have one.
Posted on May 25, 2009
  • 371 Answers
SOURCE: husqvarna sewing machine - viking 400
Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
Posted on Sep 24, 2009
How to change under tension on Husqvarna optima 190 selectronic
The bobbin has a tiny screw on the side that is the tension setting. Turn it a slight 1/8 turn and test (a small turn makes a big adjustment). Be sure to mark the original setting of the screw before making any adjustments so you can back out the adjustments if it's not working.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Aug 21, 2016 | Husqvarna Sewing Machines
Would like to get a owners manual for my husqvarna 190 selectronic sewing machine. I am having trouble with upper tension and need to make sure I am threading it properly, any suggestions
Here's an ebay that has one for $ 15.00. There are others.
http://www.ebay.com/itm/Vintage-Viking-Husqvarna-Sewing-Machine-Operation-Manual-Optima-190-180-150-/191517822256?pt=LH_DefaultDomain_0&hash=item2c975a0d30
Generic threading:
START TO THREAD WITH PRESSURE FOOT UP. AS YOU THREAD GIVE LITTLE PULLS TO INSURE THERE ARE NO SNAGS.
1. Go from right to left.
2. As you feed you will come to the tension. Make sure it is fed through the tension disc or it won't work.
3. Feed through the take up lever.
4. Feed through the final holes to the needle. Final little pull to check for snags.
5. Put pressure foot down and give little tug. It should have some resistance, but not excessive. Usually four on the tension control is a good starting point.
6. Check your bobbin for pressure. Pull out the bobbin case and let it hang from your finger with the bobbin inserted. While you bob it back and forth it should extend one inch. Adjust the tension as you need to. Put one drop on the little ring under the case. (It looks like a race track).
7. As you use the machine you may have to adjust the upper tension as you need.
Feb 28, 2015 | Husqvarna Sewing Machines
Operators manual for husqvarna viking sewinmg machine
What is the model of the sewing machine?
http://www.ismacs.net/free-sewing-machine-manuals-list.html
This site will give you 150, 180 and 190 manuals.
Jan 07, 2012 | Husqvarna Sewing Machines
My Mum has lost the feed dog for her Husqvarna Optima 190, does anyone know where I could get her a replacement as they do not make them anymore.
Feed dogs are still available for that machine. Part number is 412006601. Probably will cost you $20-$25.
I recommend that you find a dealer in your area using this link:http://webservices.us.vsmgroup.com/DealerLocator.aspx?Brand=Viking
They can order them for you from Husqvarna Viking
Nov 28, 2011 | Husqvarna Sewing Machines
\i have a viking 190 sewing machine..it was put
throw the machine away I had a riccar machine I had to throw away for the same reason I bought it used in 1983 and could not get it parts it needed
Dec 13, 2009 | Husqvarna Sewing Machines
Sewing Machines Logo
139 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
